Hi, i cant update supervisor from 2022.03.4 to 2022.03.5 due to running unhealthy state.
RPI4
Debian GNU/Linux 11 (bullseye)
Docker version 20.10.13
Logs:
22-03-18 12:42:14 INFO (MainThread) [main] Initializing Supervisor setup
22-03-18 12:42:14 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-03-18 13:42:14 WARNING (MainThread) [supervisor.bootstrap] Missing SUPERVISOR_MACHINE environment variable. Fallback to deprecated extraction!
22-03-18 13:42:14 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4
22-03-18 13:42:14 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 2022.03.4
22-03-18 13:42:14 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-18 13:42:14 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: [‘ghcr.io/home-assistant/armv7-hassio-supervisor:2022.03.5’]
22-03-18 13:42:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-03-18 13:42:15 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-18 13:42:15 ERROR (MainThread) [supervisor.core] Update ‘2022.03.5’ of Supervisor ‘2022.03.4’ failed!
22-03-18 13:42:15 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_ROLLBACK - ContextType.SUPERVISOR / None
22-03-18 13:42:15 INFO (MainThread) [main] Setting up Supervisor
22-03-18 13:42:15 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-03-18 13:42:15 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-03-18 13:42:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-03-18 13:42:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-03-18 13:42:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-03-18 13:42:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-03-18 13:42:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-03-18 13:42:16 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-03-18 13:42:16 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-03-18 13:42:16 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-03-18 13:42:16 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-18 13:42:16 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
22-03-18 13:42:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-cli with version 2021.12.0
22-03-18 13:42:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-dns with version 2021.06.0
22-03-18 13:42:17 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-03-18 13:42:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-audio with version 2021.07.0
22-03-18 13:42:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-observer with version 2021.10.0
22-03-18 13:42:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-multicast with version 2022.02.0
22-03-18 13:42:17 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-03-18 13:42:17 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-homeassistant with version 2022.3.5
22-03-18 13:42:17 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-03-18 13:42:17 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-03-18 13:42:17 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access)
22-03-18 13:42:17 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access) Beta (0.11.0)
22-03-18 13:42:17 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
22-03-18 13:42:17 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-03-18 13:42:17 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-03-18 13:42:17 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/ccab4aaf repository
22-03-18 13:42:17 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-03-18 13:42:18 WARNING (SyncWorker_4) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access)
22-03-18 13:42:18 WARNING (SyncWorker_4) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR (Full Access) Beta (0.11.0)
22-03-18 13:42:18 INFO (MainThread) [supervisor.store] Loading add-ons from store: 71 all - 71 new - 0 remove
22-03-18 13:42:18 INFO (MainThread) [supervisor.addons] Found 5 installed add-ons
22-03-18 13:42:18 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-duckdns with version 1.14.0
22-03-18 13:42:18 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/node-red/armv7 with version 11.1.0
22-03-18 13:42:18 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-ssh with version 9.3.0
22-03-18 13:42:18 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/aarch64 with version 4.1.0
22-03-18 13:42:18 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-armv7 with version 0.105.2
22-03-18 13:42:18 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
22-03-18 13:42:18 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-03-18 13:42:18 INFO (MainThread) [supervisor.ingress] Loaded 36 ingress sessions
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-18 13:42:18 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy
22-03-18 13:42:18 INFO (MainThread) [main] Running Supervisor
22-03-18 13:42:18 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-03-18 13:42:18 INFO (MainThread) [supervisor.jobs] ‘OSManager.mark_healthy’ blocked from execution, no Home Assistant OS available
22-03-18 13:42:18 WARNING (MainThread) [supervisor.core] Ignoring Supervisor updates!
22-03-18 13:42:18 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
22-03-18 13:42:18 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-03-18 13:42:18 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-03-18 13:42:18 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-03-18 13:42:18 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-03-18 13:42:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-03-18 13:42:18 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-18 13:42:18 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-18 13:42:19 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-18 13:42:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-18 13:42:19 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy
22-03-18 13:42:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
22-03-18 13:42:23 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
22-03-18 13:42:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
22-03-18 13:42:33 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-03-18 13:42:51 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
Anyone can help?
