21-04-09 09:06:34 WARNING (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
21-04-09 10:06:34 WARNING (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
21-04-09 11:58:17 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
Well, unhealthy and unsupported are not related by default… I’m running an unsupported installation (Supervised on Raspbian) also, but never had an “unhealthy” status.
Which Docker version are you running it on? It should be at least 19.03.0 (I’m on 20.10.3 atm), maybe that’s the reason for “unhealthy” state… Check here for additional info.
You may eventually encounter it because Supervisor relies on the underlying operating system’s installation of Docker and Network Manager (amongst other things) and requires them to be at a minimum version level (which is increased over time).
It happened to everyone who was using Ubuntu 18.04 (including me) because Supervisor required a version of Network Manager higher than what was available in 18.04. The quick fix was to upgrade to 20.04 (because its version of Network Manager was compliant with Supervisor’s requirements). The long-term fix was to switch to Debian 10, currently the only supported Linux distro for Home Assistant Supervised (so both “unsupported” and “unhealthy” messages are eliminated).
FWIW, I have two systems (production and test) both are Home Assistant supervised on Debian 10, one is on a laptop and the other on an RPI3.
The OP probably hasn’t run a sudo apt update && sudo apt upgrade in a long time.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
94947a1f51cc homeassistant/amd64-addon-configurator:5.2.0 "/init" 16 hours ago Up 16 hours addon_core_configurator
f0c8c8612739 ghcr.io/hassio-addons/node-red/amd64:8.2.1 "/init" 16 hours ago Up 16 hours addon_a0d7b954_nodered
3ab3650a66b2 esphome/esphome-hassio-amd64:1.16.2 "/init" 16 hours ago Up 16 hours addon_15ef4d2f_esphome
87d84b752044 homeassistant/amd64-addon-deconz:6.8.0 "/init" 16 hours ago Up 16 hours 0.0.0.0:192->5900/tcp addon_core_deconz
1465cc0b3d73 dwelch2101/dropbox-sync-amd64:1.3.0 "/run.sh" 16 hours ago Up 16 hours addon_7be23ff5_dropbox_sync
a68977b9b491 homeassistant/amd64-addon-mosquitto:5.1.1 "/init /run.sh" 16 hours ago Up 16 hours 0.0.0.0:1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp addon_core_mosquitto
899b77210f1b homeassistant/amd64-hassio-multicast:2021.04.0 "/init" 16 hours ago Up 16 hours hassio_multicast
ac2ccb3510d0 homeassistant/amd64-hassio-cli:2021.03.1 "/init /bin/bash -c …" 16 hours ago Up 16 hours hassio_cli
16083d2d4a1c homeassistant/amd64-hassio-audio:2021.02.1 "/init" 16 hours ago Up 16 hours hassio_audio
c471b83a0576 homeassistant/amd64-hassio-dns:2021.01.0 "/init" 16 hours ago Up 16 hours hassio_dns
bb33c19e09e0 storjlabs/storagenode:latest "/entrypoint" 16 hours ago Up 16 hours 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp storagenode
fe5d08dcd000 homeassistant/amd64-hassio-supervisor "/init" 3 days ago Up 16 hours hassio_supervisor
2f7f13acd62d storjlabs/watchtower "/watchtower storage…" 8 days ago Up 16 hours watchtower
c785f0d6ab6d homeassistant/qemux86-64-homeassistant:2021.3.4 "/init" 3 weeks ago Up 15 hours homeassistant
5a80720cc55c homeassistant/amd64-hassio-observer:2020.10.1 "/init" 3 months ago Up 16 hours 0.0.0.0:4357->80/tcp hassio_observer
Maybe the storagenode?
If yes, is there a way to run both home assistant and storagenode together?
@123, i did run apt-get update && upgrade yesterday.
I would assume storagenode and watchtower containers are causing it, as no “external” containers are allowed besides HA ones. Unfortunately I don’t know how to deal with it (not familiar with storagenode).
The simplest workaround I’ve come up with to run Watchtower without Home Assistant detecting it, is to run an image that isn’t called Watchtower.
I think the development team might have something to say about why this is a bad idea. Changing its name will evade the “unhealthy” message but not the potential negative interactions with Supervisor.
You may be back in the future reporting some bizarre behavior caused by that interaction … and diagnosing it may prove to be challenging because the renaming of watchtower was long-forgotten.
Users should be advised this is a hack, not a fix.
