Hi everyone! While using Home Assistant OS in a VM (VirtualBox), when trying to update the supervisor, I hit this error:
Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2021.06.3: 404 Client Error for http+docker://localhost/v1.40/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2021.06.3/json: Not Found ("no such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.06.3: No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.06.3")
At first, I thought that it was because of a lack of storage, so therefore I increased the size of the virtual drive. However, it seems to be giving me the same error, even after only having 39% of the space used
Does anyone know how I could fix this? Thanks in advance!
I have the same problem on a newly installed VM (Home Assistant OS 6.5).
Home Asistant automatically tries to update the supervisor and when it fails it gives the unhealthy status. “Your installation is unhealthy”
I get the error also when manually trying to update the supervisor.
21-10-13 18:44:11 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2021.10.0.
21-10-13 18:44:23 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0/json: Not Found ("no such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0: No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0")
21-10-13 18:44:23 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
21-10-13 18:44:23 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0/json: Not Found ("no such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0: No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2021.10.0")
21-10-13 18:44:23 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
Anyone found the solution?
Trying to update from 2022.5.5 to 2022.8.6 and get the same error.
Intel NUC / Debian 11/ HA Supervised
22-08-21 01:31:24 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.6: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.6/json: Not Found ("no such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.6: No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.6")
