Can't update to 2021.6.6
After about one month of downtime due to a move I finally got HA running today and I figured I could update it also.
Currently I’m on 2021.3.4.
I get an “unknown error see supervisor logs” error.
21-07-06 21:32:44 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 9.5.0
21-07-06 21:32:44 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to esphome/esphome-hassio-aarch64 with version 1.18.0
21-07-06 21:32:44 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 9.1.0
21-07-06 21:32:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-aarch64 with version 0.104.3
21-07-06 21:32:44 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to apipa169/armv7-hassio-assistant_relay with version None
21-07-06 21:32:44 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/node-red/aarch64 with version 8.2.0
21-07-06 21:32:44 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.3.1
21-07-06 21:32:44 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 5.1
21-07-06 21:32:44 INFO (MainThread) [supervisor.snapshots] Found 4 snapshot files
21-07-06 21:32:44 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
21-07-06 21:32:44 INFO (MainThread) [supervisor.ingress] Loaded 6 ingress sessions
21-07-06 21:32:44 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-07-06 21:32:44 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-07-06 21:32:44 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-07-06 21:32:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-07-06 21:32:44 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-07-06 21:32:44 INFO (MainThread) [__main__] Running Supervisor
21-07-06 21:32:44 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-07-06 21:32:44 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-07-06 21:32:44 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 1 add-ons
21-07-06 21:32:56 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 5.1
21-07-06 21:32:58 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
21-07-06 21:33:01 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 3 add-ons
21-07-06 21:33:01 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
21-07-06 21:33:01 WARNING (SyncWorker_1) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
21-07-06 21:33:02 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 9.5.0
21-07-06 21:33:04 WARNING (MainThread) [supervisor.api.middleware.security] core_samba missing API permission for /network/interface/default/info
21-07-06 21:33:04 ERROR (MainThread) [supervisor.api.middleware.security] Invalid token for access /network/interface/default/info
21-07-06 21:33:04 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-ssh with version 9.1.0
21-07-06 21:33:07 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on apipa169/armv7-hassio-assistant_relay with version None
21-07-06 21:33:12 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-07-06 21:33:12 INFO (SyncWorker_6) [supervisor.docker.interface] Starting homeassistant
21-07-06 21:33:12 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-07-06 21:33:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
21-07-06 21:33:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-07-06 21:33:42 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-07-06 21:34:09 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-07-06 21:34:09 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 4 add-ons
21-07-06 21:34:11 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.3.1
21-07-06 21:34:21 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
21-07-06 21:34:27 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on sabeechen/hassio-google-drive-backup-aarch64 with version 0.104.3
21-07-06 21:34:37 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on esphome/esphome-hassio-aarch64 with version 1.18.0
21-07-06 21:34:38 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/aarch64 with version 8.2.0
21-07-06 21:34:44 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-07-06 21:34:44 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-07-06 21:34:44 INFO (MainThread) [supervisor.host.info] Updating local host information
21-07-06 21:34:44 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-07-06 21:34:44 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-07-06 21:34:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-07-06 21:34:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-07-06 21:34:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-07-06 21:34:44 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
21-07-06 21:34:45 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-07-06 21:34:45 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-07-06 21:34:45 INFO (MainThread) [supervisor.host.services] Updating service information
21-07-06 21:34:46 INFO (MainThread) [supervisor.host.network] Updating local network information
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/a4d048a9/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/ed1c417e/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/9099a1f3/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/755d485e/info access from cebe7a76_hassio_google_drive_backup
21-07-06 21:34:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-07-06 21:34:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-07-06 21:34:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-07-06 21:34:50 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-07-06 21:34:50 INFO (MainThread) [supervisor.host] Host information reload completed
21-07-06 21:35:05 INFO (MainThread) [supervisor.snapshots] Creating new partial-snapshot with slug 6108af23
21-07-06 21:35:05 INFO (MainThread) [supervisor.snapshots] Snapshotting 6108af23 store folders
21-07-06 21:35:05 INFO (SyncWorker_3) [supervisor.snapshots.snapshot] Snapshot folder homeassistant
21-07-06 21:35:28 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-07-06 21:35:28 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-07-06 21:35:28 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-07-06 21:35:30 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-07-06 21:35:30 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-07-06 21:35:30 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
When I run the Check Home Assistant configuration addon I get errors on my HACS installed integrations.
Something like: “Browser mod does not exist”, but it’s installed in custom components folder.
But it seems as it’s not running. I can’t see the entities it should have created.
I also got an error on “ical does not exist” if I remember correctly but that is working. I can see my calendar as an entity.
I have restarted the check so that I can copy the logs here exactly
Anyone know what this could be?
EDIT: HACS is updated to latest version.
Edit2:
Here is the logs:
[22:20:21] ERROR: The configuration check did not pass!
[22:20:21] ERROR: See the output below for more details.
Testing configuration at /tmp/config
WARNING:homeassistant.components.uptime.sensor:The 'unit_of_measurement' option is deprecated, please remove it from your configuration
WARNING:homeassistant.components.broadlink.switch:The 'host' option is deprecated, please remove it from your configuration
Failed config
  General Errors:
    - Platform error sensor.ical - Integration 'ical' not found.
    - Platform error sensor.places - Integration 'places' not found.
    - Component error: browser_mod - Integration 'browser_mod' not found.
They are all installed:
And as I wrote earlier, ical works fine…
And places works also:
You are probably missing version numbers from the custom component’s manifest.json file.
In 2021.3 and before 2021.6 it used to be just a warning. But from 2021.6 if the version number is missing then the custom component is not loaded.
You need to update those cuatom components through HACS, if you got them through that.
I have missed that part.
Thank you!
Those that was not HACS installed was old. But not sure what I’m going to do with the ical sensor though.
The other versions give me a different sensor and not what I want.
Oh well… I guess I’m forced to update it.
Sorry, I have no experience with that integration. Maybe try to search for a topic about it and ask people what they did when updated before.
Everything is updated now in HACS, only some add-ons in supervisor that is not updated yet.
I get this:
But when updating I get “Unknown error, see supervisor logs”.
21-07-07 07:29:17 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-07-07 07:29:17 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-07-07 07:29:17 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-07-07 07:32:49 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-07-07 07:34:57 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-07-07 07:35:28 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-07-07 07:45:27 INFO (SyncWorker_6) [supervisor.docker.interface] Updating image esphome/esphome-hassio-aarch64:1.18.0 to esphome/esphome-hassio-aarch64:1.19.4
21-07-07 07:45:27 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image esphome/esphome-hassio-aarch64 with tag 1.19.4.
21-07-07 07:51:11 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_check_config application
21-07-07 07:53:02 ERROR (MainThread) [supervisor.utils] Can't execute run while a task is in progress
21-07-07 07:53:02 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:53:02 WARNING (SyncWorker_3) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:53:03 WARNING (SyncWorker_7) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:53:03 WARNING (SyncWorker_2) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:53:03 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:13 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:15 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:21 WARNING (SyncWorker_3) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:23 WARNING (SyncWorker_2) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:24 WARNING (SyncWorker_7) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:26 ERROR (MainThread) [supervisor.utils] Can't execute stop while a task is in progress
21-07-07 07:54:37 ERROR (MainThread) [supervisor.utils] Can't execute run while a task is in progress
21-07-07 07:54:57 WARNING (SyncWorker_3) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:54:59 WARNING (SyncWorker_7) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:55:07 ERROR (MainThread) [supervisor.utils] Can't execute stop while a task is in progress
21-07-07 07:55:15 ERROR (MainThread) [supervisor.utils] Can't execute run while a task is in progress
21-07-07 07:55:19 WARNING (SyncWorker_7) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:55:21 WARNING (SyncWorker_2) [supervisor.docker.interface] Can't grep logs from homeassistant/aarch64-addon-check_config: 409 Client Error for http+docker://localhost/v1.41/containers/c5b7c011fa7afc433d351481d3e916be4bcbd9ec941c9797234ab7dfa673fe36/logs?stderr=1&stdout=1&timestamps=0&follow=0&tail=100: Conflict ("can not get logs from container which is dead or marked for removal")
21-07-07 07:55:33 INFO (MainThread) [supervisor.snapshots] Creating new partial-snapshot with slug 0699b8a8
21-07-07 07:55:59 INFO (MainThread) [supervisor.snapshots] Snapshotting 0699b8a8 store folders
21-07-07 07:55:59 INFO (SyncWorker_3) [supervisor.snapshots.snapshot] Snapshot folder homeassistant
21-07-07 07:59:40 INFO (SyncWorker_6) [supervisor.docker.interface] Stopping addon_15ef4d2f_esphome application
21-07-07 07:59:51 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_15ef4d2f_esphome application
21-07-07 07:59:52 INFO (MainThread) [supervisor.addons] Add-on '15ef4d2f_esphome' successfully updated
21-07-07 07:59:52 INFO (SyncWorker_5) [supervisor.docker.interface] Cleanup images: ['esphome/esphome-hassio-aarch64:1.18.0']
21-07-07 08:01:24 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on esphome/esphome-hassio-aarch64 with version 1.19.4
21-07-07 08:01:25 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-check_config with version 3.7.1
21-07-07 08:05:37 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-07-07 08:10:53 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:14:53 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-07-07 08:30:48 INFO (SyncWorker_3) [supervisor.snapshots.snapshot] Snapshot folder homeassistant done
21-07-07 08:30:58 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:31:48 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:32:07 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:32:16 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:32:36 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:32:59 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:33:33 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:34:26 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:34:40 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:34:47 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:35:13 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:35:44 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:35:47 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-07-07 08:35:49 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:36:07 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:36:30 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:36:50 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:37:00 INFO (MainThread) [supervisor.snapshots] Creating partial-snapshot with slug 0699b8a8 completed
21-07-07 08:37:05 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:37:05 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/0699b8a8/info access from cebe7a76_hassio_google_drive_backup
21-07-07 08:37:06 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/ed1c417e/remove access from cebe7a76_hassio_google_drive_backup
21-07-07 08:37:06 INFO (MainThread) [supervisor.snapshots] Removed snapshot file ed1c417e
21-07-07 08:37:06 INFO (MainThread) [supervisor.api.middleware.security] /snapshots/0699b8a8/download access from cebe7a76_hassio_google_drive_backup
21-07-07 08:37:06 INFO (MainThread) [supervisor.api.snapshots] Downloading snapshot 0699b8a8
21-07-07 08:39:08 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:39:10 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
21-07-07 08:44:04 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2021.6.6
21-07-07 08:44:04 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:2021.3.4 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.6.6
21-07-07 08:44:04 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2021.6.6.
It seems it did update even though it gave errors.
I’m on 2021.6.6 now.
Sweet!
With my luck the new version will probably be released today…
Do you have an addon to make snapshot backups to Google drive?
You can try to make first a full snapshot, then backup that to Google drive and then try to do the update to 2021.6.
Otherwise have a look at the GitHub issues, you might find a solution there.
That’s not about luck, a new release is scheduled the first Wednesday of each month :wink:
I did not know that…
Oh well, I guess I have to update again this week then :slight_smile:
