Cant update to 2023.1.3 on haOs 9.4
after update of core 2023.1.2, i cant see any update, even for addons.
I cant update with “ha core update --version 2023.1.3” . i try to check, ok, rebuild, ok, but cant update to 2023.1.3.
I am on intel NUC.
So i try to install the last image here : https://github.com/home-assistant/operating-system/releases/download/9.4/haos_generic-x86-64-9.4.img.xz
and it still ha core 2023.1.2, not 2023.1.3.
i still cant see the 2023.1.3 update and any other addon update.
I go under settings → Update : there is still nothing
any idea please?
i restore my entire backup except “homeassistant”
Earlier today I checked the builds and some of them failed, so I guess the releases are not ready yet and that is why your u can not update.
thanks @WallyR !
Or create a pull request after changing the version numbers on version/stable.json at 91a34828fe0f530ef4744514b636d38b71ea0884 · home-assistant/version · GitHub :wink:
The builds are there…
i think i need some more patience instead lol
i thinked i have a bug…seems not…just wait for the stable 2023.1.3 :wink:
I looks like the build came through 8h back, so now it should be available.
there is no 2023.1.3…its 2023.1.4 lol
Yeah if you look at the builds in the link above, then you can see that 2023.1.3 failed on some of the builds and it was probably skipped because it took so long that new fixes came along that needed a build too.
