i’m trying to update from 57.2 to 58.1 but i failed.
If i use the update button in hass io ui it takes forever and it does nothing, same thing i run the update command via ssh.
supervisor logs report that:
17-11-30 11:46:55 INFO (MainThread) [main] Initialize Hassio setup
17-11-30 11:46:55 INFO (MainThread) [main] Setup HassIO
17-11-30 11:46:55 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.75
17-11-30 11:46:55 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-11-30 11:46:56 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “resinos”, “version”: “1.1”, “last_version”: “1.1”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”, “hostname”], “os”: “GNU/Linux” }.
17-11-30 11:46:56 INFO (SyncWorker_0) [hassio.dock.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.57.2
17-11-30 11:46:56 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
17-11-30 11:46:56 INFO (MainThread) [hassio.addons] Load addons: 18 all - 18 new - 0 remove
17-11-30 11:46:56 INFO (SyncWorker_3) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-duckdns with version 1.0
17-11-30 11:46:56 INFO (SyncWorker_1) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-samba with version 2.0
17-11-30 11:46:56 INFO (SyncWorker_0) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-ssh with version 2.9
17-11-30 11:46:56 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
17-11-30 11:46:56 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
17-11-30 11:46:56 INFO (MainThread) [main] Run HassIO
17-11-30 11:46:56 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-11-30 11:46:56 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-11-30 11:46:56 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-11-30 11:46:56 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-11-30 11:46:56 INFO (MainThread) [hassio.addons] Startup system run 0 addons
17-11-30 11:46:56 INFO (MainThread) [hassio.addons] Startup services run 3 addons
17-11-30 11:46:57 INFO (SyncWorker_5) [hassio.dock.interface] Clean homeassistant/armhf-addon-samba docker application
17-11-30 11:46:57 INFO (SyncWorker_12) [hassio.dock.interface] Clean homeassistant/armhf-addon-ssh docker application
17-11-30 11:46:57 INFO (SyncWorker_6) [hassio.dock.interface] Clean homeassistant/armhf-addon-duckdns docker application
17-11-30 11:46:57 INFO (MainThread) [hassio.addons] Load addons: 18 all - 0 new - 0 remove
17-11-30 11:46:59 INFO (SyncWorker_5) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-samba with version 2.0
17-11-30 11:46:59 INFO (SyncWorker_6) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-duckdns with version 1.0
17-11-30 11:47:02 INFO (SyncWorker_12) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-ssh with version 2.9
17-11-30 11:47:02 INFO (SyncWorker_3) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-11-30 11:47:04 INFO (SyncWorker_3) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.57.2
17-11-30 11:47:04 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-11-30 11:49:45 INFO (SyncWorker_17) [hassio.dock.interface] Update docker 0.57.2 with homeassistant/raspberrypi3-homeassistant:0.58.1
17-11-30 11:49:45 INFO (SyncWorker_17) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.58.1.
any advice?
