Hi there,
I have the same issue but with the follwong error:
19-04-21 15:10:37 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/raspberrypi-homeassistant tag 0.91.4.
19-04-21 15:10:51 ERROR (SyncWorker_0) [hassio.docker.interface] Can’t install homeassistant/raspberrypi-homeassistant:0.91.4 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi-homeassistant:0.91.4: No such image: homeassistant/raspberrypi-homeassistant:0.91.4”).
19-04-21 15:10:51 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
This was my error when I had no space left. I thought that that it was odd that it said that the image couldn’t be found but once I resized my vm it installed fine.
…and last night, suddenly, the update was ok. Now I am on 0.91.4 and everything is working fine but Configurator: I cannot access it any longer.
Thanks for your help but this is really not deterministic!!!
PS df -h says /dev/root is 0% free but overlay is 30% used: I do not understand why it can’t adjust space… But yes, I’d probably need a larger card.
make sure you back up your lovelace layout.
With me no longer using the yaml file that was what I forgot to backup when I did a clean install.
What a pain
I did resently add two cameras to motionEye before this problem started.
I deleted all of the cams, motionEye and several add-on’s that I can live without. Deleted logs, old backups… That opened up about 700mb of free space.
Then pushed latest release successfully.
32 GB SD is still full. The memory overload is in the blocks.
I just wanted to close the loop on this issue (for me anyways). I decided to wait to see what would happen with upcoming updates. The next update also failed on me with the same error message. However, the update after that went through without any problems. I now have an updated system with full access to the Configurator and other add-ons again. I still don’t know why the prior two releases failed and I’m not sure why I lost access to some add-ons like the Configurator, but it seems to have fixed itself with the most recent update.
