Just tried again and got the following log entry:
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
socket.timeout: timed out
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 976, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 308, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 167, in _new_conn
% (self.host, self.timeout),
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPSConnection object at 0x6b9d3ab0>, 'Connection to 192.168.1.101 timed out. (connect timeout=10)')
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.101', port=5001): Max retries exceeded with url: /webapi/query.cgi?api=SYNO.API.Info&version=1&method=query (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x6b9d3ab0>, 'Connection to 192.168.1.101 timed out. (connect timeout=10)'))
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 256, in _execute_request
url, params=encoded_params, timeout=self._timeout, **kwargs
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 543, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host='192.168.1.101', port=5001): Max retries exceeded with url: /webapi/query.cgi?api=SYNO.API.Info&version=1&method=query (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x6b9d3ab0>, 'Connection to 192.168.1.101 timed out. (connect timeout=10)'))
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 220, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 161, in async_setup_entry
await api.async_setup()
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 253, in async_setup
await self._hass.async_add_executor_job(self._fetch_device_configuration)
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 311, in _fetch_device_configuration
self.information = self.dsm.information
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 327, in information
data = self.get(SynoDSMInformation.API_KEY, "getinfo")
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 179, in get
return self._request("GET", api, method, params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 193, in _request
self.discover_apis()
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 114, in discover_apis
self._apis = self.get(API_INFO, "query")["data"]
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 223, in _request
response = self._execute_request(request_method, url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/synology_dsm/synology_dsm.py", line 275, in _execute_request
raise SynologyDSMRequestException(exp)
synology_dsm.exceptions.SynologyDSMRequestException: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ConnectTimeout = (<urllib3.connection.HTTPSConnection object at 0x6b9d3ab0>, 'Connection to 192.168.1.101 timed out. (connect timeout=10)')"}
2020-07-14 15:58:56 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:58:56 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 10 seconds.
2020-07-14 15:58:59 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:58:59 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 10 seconds.
2020-07-14 15:58:59 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-07-14 15:58:59 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 10 seconds.
2020-07-14 15:59:07 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:59:07 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 20 seconds.
2020-07-14 15:59:13 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-07-14 15:59:13 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 20 seconds.
2020-07-14 15:59:13 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:59:13 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 20 seconds.
2020-07-14 15:59:28 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:59:28 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 40 seconds.
2020-07-14 15:59:37 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 15:59:37 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 40 seconds.
2020-07-14 15:59:37 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-07-14 15:59:37 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 40 seconds.
2020-07-14 16:00:09 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 16:00:09 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 80 seconds.
2020-07-14 16:00:21 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-07-14 16:00:21 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds.
2020-07-14 16:00:21 ERROR (MainThread) [homeassistant.components.roku] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2020-07-14 16:00:21 WARNING (MainThread) [homeassistant.config_entries] Config entry for roku not ready yet. Retrying in 80 seconds.
Think most of this relates to waiting for devices to reconnect etc, but don’t know if first first lines mean anything??
