Can't upgrade past 82.1
running HA on my pi and I’ve been trying to upgrade for the last few weeks. Upgrade goes fine, service will start and everything will become configured. After that access to the UI is lost. There are no errors in the logs, no warnings, no anything.
Trying a fresh install with my configs (82.1) on 84 doesn’t even work. I get the error saying that secrets aren’t included correctly.
Anyone have an idea where I can begin. It’s pretty annoying to want to use a new feature but nothing is working.
How are you installing HA?
new installs are through venv.
I upgraded to 0.84.1 in a venv yesterday, so there is nothing wrong generally - there is just something in your secrets file that it doesn’t like.
I suggest make a copy and replace every one with a simple text value ‘abc’ and see if that loads. If so it is a value that is incorrect and you can put half the values back, to see which half the problem is in.
If not, there is something wrong with the keys, and you can paste the copied file here for help, as it won’t contain any secrets.
I’ll have to look into it. I’ve had my secrets file for almost 2 years now and this is the first time its given me an error.
Things are solved.
Not sure what changed but it’s working as of 84.2
