Additional information: looking at the Info page seems that my system has become unsupported.
Currently upgrading underlying OS from debian 9 to debian 10… will see if it helps
You have to see if your docker version is 19.x.x. docker 20 makes problems and is marked as incompatible, I’m using manjaro as OS and had docker 19.x.x-ce installed, which gets false-positve detected as incompatible because it’s not 19.x.x. Maybe you need to downgrade docker
Well I spent all the evening trying to solve this (without results).
Tried to make the system “supported”, it was on debian 9 since two years ago, and after upgrading to debian 10 home assistant just didn’t start, as far as I could see in system logs, there was a problem starting “CoreDNS” and couldn’t find a solution for this:
So I had to go back to an snapshot just from before upgrading debian (that’s one of the greatest features of virtualbox) because the lights in the house were unusable with homeassistant stopped…
Will come back to this thread, but I will probably make a new VM using the supported virtualbox image.
