Can't upgrade to 0.106.5 -> 0.107.7
Dear all,
I can’t upgrade HAAS on freebox delta.
Not possible via supervisor.
Not possible to install SSH editor or server via supervisor.
Any solutions ?
20-03-27 19:29:36 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-64-homeassistant tag 0.107.7.
20-03-27 19:29:45 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:0.107.7 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:0.107.7: No such image: homeassistant/raspberrypi4-64-homeassistant:0.107.7").
20-03-27 19:29:45 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Getting same error for past week and still haven’t solved either. Unable to upgrade several add-ons also.
Finally got it working by fresh install and restoring from backup. Looks like corrupted SD card. Was able to copy some data off but trying a fresh install on same SD card kept failing and finally switching to a new SD card and restore worked.
