https://github.com/danielwelch/hassio-addons repository
18-04-03 11:40:25 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/bestlibre/hassio-addons repository
18-04-03 11:40:25 WARNING (MainThread) [hassio.addons.data] Can’t read /data/addons/git/53caca22/base_debian/config.json: required key not provided @ data[‘boot’]. Got None
required key not provided @ data[‘startup’]. Got None
18-04-03 11:40:25 INFO (MainThread) [hassio.addons] Load addons: 76 all - 0 new - 0 remove
18-04-03 11:57:35 INFO (SyncWorker_12) [hassio.docker.interface] Update docker 0.65.6 with homeassistant/intel-nuc-homeassistant:0.66.1
18-04-03 11:57:35 INFO (SyncWorker_12) [hassio.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag 0.66.1.
18-04-03 11:58:00 ERROR (SyncWorker_12) [hassio.docker.interface] Can’t install homeassistant/intel-nuc-homeassistant:0.66.1 -> 404 Client Error: Not Found (“no such image: homeassistant/intel-nuc-homeassistant:0.66.1: No such image: homeassistant/intel-nuc-homeassistant:0.66.1”
Mine will upgrade, and then after a reboot, it downgrades. I’ve gotten no help here so far unfortunately.
Don’t know about HASS.IO and why it is complaining, but the 0.66.1 for Intel NUC is there. See Docker
Is there any way to run “docker pull homeassistant/intel-nuc-homeassistant:0.66.1” on the host machine directly?
no idea, but I am still stuck at 65.6
same error
still have this error, any way of fixing this?
