Hi, I’m trying to set up a universal media player and I’m having some issues.
My goal is to have volume commands call the remote.send_command service if my TV is on, and just do their default behaviour otherwise. The default behaviour of course does nothing to my TV.
I thought templating would be my solution, but I can’t get it working in this specific part of the config. I found an old archived post complaining of the exact same thing - with no solution. That being said, I could just have a syntax error?
Here’s the relevant YAML (looks fine in the template editor btw):
media_player:
- platform: universal
name: Active Media Player
children:
- media_player.living_room_tv
- media_player.all_speakers
- media_player.living_room_speaker
- media_player.bathroom_speaker
- media_player.bedroom_speaker
commands:
volume_up: >
{% if is_state('media_player.living_room_tv', 'idle') %}
service: remote.send_command
entity_id: remote.universal_remote
device: TV
command: volumeUp
{% else %}
service: media_player.volume_up
entity_id: media_player.active_media_player
{% endif %}
browse_media_entity: media_player.living_room_tv
device_class: tv
unique_id: all_media_players
For reference, this is what the template editor shows on the right:
media_player:
children:
commands:
volume_up: >
device_class: tv
And this is the error I get trying to use this config:
Invalid config for 'universal' from integration 'media_player' at configuration.yaml, line 49: expected a dictionary for dictionary value 'commands->volume_up', got "{% if is_state('media_player.living_room_tv', 'idle') %} service: remote.send_command target:\n entity_id: remote.universal_remote\ndata:\n device: TV\n command: volumeUp\n{% else %} service: media_player.volume_up target:\n entity_id: media_player.active_media_player\n{% endif %}\n"
i haven’t done a media_player entity like this so i am hesitant about trying to just give you fully working code, however i would tell you that i don’t believe that you can use a template to output a block of text that looks like commands and have it be interpreted as commands.
if i were you, i would have your volume_up command call a script.
service: script.universial_volume_up
and in your script do your conditional properly (using proper yaml… not jinja).
btw, is
right? instead of
That’s actually exactly what I ended up doing! I guess I had some wrong ideas about how jinja works in HA. Calling a script is at least… valid! Still having some issues with getting it all working 100%, but I’ll be sure to post my yaml once I have it all ironed out.
Thanks!
cool. holler and post your yaml if you need help…
It’s been a while, but I did end up getting back to this and getting it working!
In case it helps anyone else, I’ll post some of my YAML:
media_player:
children:
commands:
volume_up:
service: script.volume_up_script
volume_down:
service: script.volume_down_script
volume_mute:
service: script.volume_mute_script
device_class: tv
And the scripts are all pretty similar, here’s the volume up one (Note that I have another universal media player named active_speaker, and I directly set the volume on it if the TV is not active)
volume_up_script:
alias: volume_up_script
sequence:
- choose:
- conditions:
- condition: or
conditions:
- condition: state
entity_id: media_player.living_room_tv
state: idle
- condition: state
state: 'off'
- condition: state
state: unavailable
sequence:
- if:
- condition: or
conditions:
- condition: state
entity_id: media_player.active_speaker
state: 'on'
- condition: state
state: playing
- condition: state
state: paused
- condition: state
state: buffering
then:
- service: media_player.volume_up
entity_id:
- media_player.active_speaker
data: {}
default:
- service: remote.send_command
metadata: {}
device: TV
command: volumeUp
mode: single
icon: mdi:volume-plus
