I’ve got a ZTE 4G Modem/Router which I have to use because the provider doesn’t allow me to use any other.
That ZTE thing is -the least to say- not very nice to set up. It can only do a limited amount of fixed IP’s in the DHCP pool and its WiFi is failing every time. (second unit, so I guess it’s a product issue).
I’ve connected a FritzBox 7360 to the ZTE device and configured that as a cascaded router. It works fine, Wifi issues resolved, I can fix IP addresses as I like etc. but there’s two issues with HA:
I’m using ZeroTier for remote access. Once I’m in a different network, I’m not able to get to HA anymore.
When I’m in the same network I can connect to HA using ZeroTier.
Google backup generates errors: Unable to reach token2.habackup.io,
However, when I go into settings and open the Google UI, click re-authorize it works fine (and I can do backups)
Once I leave the UI it logs errors as soon as a backup is scheduled.
The setup worked fine without the cascaded router, so I’m pretty convinced I’m doing something wrong, but I can’t figure out what.
ZTE IP Range: 192.169.0.x
FritzBox IP on the ZTE: 192.168.0.4
FritzBox IP Range: 192.169.0.x
What am I doing wrong?
