Canvas-gauge-card not on center?
canvas-gauge-card not on center and not shows as half? Why?
Here is test:
align_center_problem
Here is my config:
type: horizontal-stack
cards:
  - type: custom:canvas-gauge-card
    entity: sensor.bathroom_esp_sensor_temperature
    card_height: 100
    background_color: '#FFF'
    gauge:
      type: radial-gauge
      borderShadowWidth: 0
      borderOuterWidth: 0
      borderMiddleWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
          color: rgba(200, 50, 50, .75)
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
      needleCircleOuter: true
      needleCircleInner: false
      animationDuration: 1500
      animationRule: linear
    card_height: 100
    gauge:
      type: radial-gauge
      borderOuterWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
    card_height: 100
    gauge:
      type: radial-gauge
      borderOuterWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
I used to have this issue periodically, one thing I found that fixes the problem is putting it as an element on a picture-elements card. This may not be the answer you are looking for but it helps with displaying on different types of displays such as from phone and desktop.
I have several examples here:
Canvas Gauge Backgrounds
Can you share example configuration?
The above link has several examples on GitHub along with the pictures.
Here is one example thou:
type: picture-elements
image: /local/gauge/AQI_Index.png
elements:
  - type: state-label
    style:
      top: 84%
      left: 50%
      box-shadow: none
      background-color: transparent
    entity: sensor.purpleair_description
    prefix: ''
    attribute: ''
    title: null
    entity: sensor.purpleair_aqi_a
    style:
      top: 50%
      left: 50%
      width: null
      heigth: null
      box-shadow: none
    gauge:
      type: radial-gauge
      title: AQI
      width: 230
      height: 230
      minValue: 0
      maxValue: 500
      startAngle: 40
      ticksAngle: 280
      valueBox: true
      majorTicks:
        - '0'
        - '50'
        - '100'
        - '150'
        - '200'
        - '250'
        - '300'
        - '350'
        - '400'
        - '450'
        - '500'
      minorTicks: 5
      strokeTicks: true
      highlights:
          to: 50
          color: rgba(104, 225, 67, .75)
          to: 100
          color: rgba(255, 255, 85, .75)
          to: 150
          color: rgba(239, 133, 51, .75)
          to: 200
          color: rgba(234, 51, 36, .75)
          to: 300
          color: rgba(140, 26, 75, .75)
          to: 500
          color: rgba(115, 20, 37, .75)
      borders: 'no'
      needleType: arrow
      needleWidth: 4
      needleCircleSize: 7
      valueBoxBorderRadius: 10
      colorValueBoxRect: '#222'
      colorValueBoxRectEnd: '#333'
      valueDec: 0
      valueInt: null
  - type: image
    image: /local/gauge/AQI_Logo.png
    style:
      top: 50%
      left: 50%
      width: 25%
      box-shadow: none
Example_AQI
I just reread your question and missed the part of the half, that is because your starting angle is 90.
Thx, I wanna display as half, but I have whole circle.
I wanna have look like this:
stevec
https://github.com/custom-cards/canvas-gauge-card
In that case you want to change your card_height: to 57 and see if that is what you want.
I try this but not working. I see no difference.
post your yaml again as it is now.
Ah, you might have to clear cache and reload after you change your settings for the gauge (sometimes you do, sometimes you don’t) try Ctrl-F5
Thx @GlennHA now is ok.
3_gauge
Was it the Ctrl-F5?
Yes :slight_smile:
Yep, that bits me every now and then. I make changes and I don’t see any changes, so I make more, then I realize…probably need to clear the cache and try it. I have almost just got in the habit of clear cache every change whether it worked already or not. Clear the cache on the phone apps sometimes needs to be done, which is a little more difficult (not hard, just a lot of sub sub sub sub menus).
I would still post your updated yaml so others can see the code and it might help them. You could edit and add it to the post with the pics above so it is all together.
Working card :slight_smile:
3_gauge
cards:
    card_height: 57
    gauge:
      type: radial-gauge
      borderOuterWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
    card_height: 57
    gauge:
      type: radial-gauge
      borderOuterWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
    card_height: 57
    gauge:
      type: radial-gauge
      borderOuterWidth: 0
      borderInnerWidth: 0
      width: 100
      height: 100
      minValue: 0
      maxValue: 100
      startAngle: 90
      ticksAngle: 180
      valueBox: false
      majorTicks:
        - '0'
        - '10'
        - '20'
        - '30'
        - '40'
        - '50'
        - '60'
        - '70'
        - '80'
        - '90'
        - '100'
      minorTicks: 2
      strokeTicks: true
      highlights:
          to: 100
      colorPlate: '#ddd'
      borders: false
      needleType: arrow
      needleWidth: 2
      needleCircleSize: 7
