Caperplus Q2 pH & TDS meter integration
Hello, this is a brief manual how to integrate Caperplus Q2 pH & TDS meter to HA.
As mentioned in another forum there is probably a possibility to sniff data between the device and mobile app, however I wasn’t able to do that, so I decided to flash onboard esp - for this purpose basic soldering skills and soldering iron pen type with a conical/sharp tip are required.
At first, to create original firmware backup and flash onboard ESP-12F, I soldered pins as described on this site and I used CP2102 USB-UART converter:
To create original firmware backup I used esptool with command (replace PORT for yours PORT of connected converter):
esptool -p PORT -b 460800 read_flash 0 0x400000 caperplus-orig.bin
Then I flashed esp with following code based on this configuration which also uses this library to decode data. Mentioned caperplus_q2_uart_sensor.h library need to be uploaded first to yours /homeassistant/esphome/ localization before code compilation.
esphome:
  friendly_name: esp-caperplus-q2
  includes:
    - ./caperplus_q2_uart_sensor.h
esp8266:
  board: d1_mini
# Enable logging
logger:
  baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
  encryption:
    key: "***"
ota:
  - platform: esphome
    password: "***"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp-Caperplus-Q2"
    password: "***"
captive_portal:
uart:
  rx_pin: GPIO3
  parity: NONE
  data_bits: 8
  stop_bits: 1
  baud_rate: 9600
  - platform: custom
    lambda: |-
      auto caper = new CaperPlusQ2UartSensor(id(uart_bus));
      App.register_component(caper);
      return {caper->temperature_sensor, caper->ph_sensor, caper->tds_sensor};
    sensors:
      - name: "Temperature"
        unit_of_measurement: "°C"
        accuracy_decimals: 1
        state_class: measurement
        device_class: temperature
      - name: "pH"
        unit_of_measurement: "pH"
        icon: mdi:ph
        accuracy_decimals: 2
      - name: "TDS"
        unit_of_measurement: "ppm"
        accuracy_decimals: 0
After flashing onboard esp, desoldering pins and powering device, it appears in HA :partying_face:
Logs esp-caperplus-q2.yaml
INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/esp-caperplus-q2.yaml...
INFO Starting log output from 192.168.1.144 using esphome API
INFO Successfully connected to esp-caperplus-q2 @ 192.168.1.144 in 0.006s
INFO Successful handshake with esp-caperplus-q2 @ 192.168.1.144 in 2.370s
[14:24:15][I][app:100]: ESPHome version 2024.12.2 compiled on Dec 27 2024, 11:00:18
[14:24:15][C][wifi:600]: WiFi:
[14:24:15][C][wifi:428]:   Local MAC: EC:64:C9:FC:CD:0E
[14:24:15][C][wifi:433]:   SSID: [redacted]
[14:24:15][C][wifi:436]:   IP Address: 192.168.1.144
[14:24:15][C][wifi:439]:   BSSID: [redacted]
[14:24:15][C][wifi:441]:   Hostname: 'esp-caperplus-q2'
[14:24:15][C][wifi:443]:   Signal strength: -56 dB ▂▄▆█
[14:24:15][C][wifi:447]:   Channel: 1
[14:24:15][C][wifi:448]:   Subnet: 255.255.255.0
[14:24:15][C][wifi:449]:   Gateway: 192.168.1.1
[14:24:15][C][wifi:450]:   DNS1: 192.168.1.1
[14:24:15][C][wifi:451]:   DNS2: 0.0.0.0
[14:24:15][C][logger:185]: Logger:
[14:24:15][C][logger:186]:   Level: DEBUG
[14:24:15][C][logger:188]:   Log Baud Rate: 0
[14:24:15][C][logger:189]:   Hardware UART: UART0
[14:24:15][C][uart.arduino_esp8266:118]: UART Bus:
[14:24:15][C][uart.arduino_esp8266:120]:   RX Pin: GPIO3
[14:24:15][C][uart.arduino_esp8266:122]:   RX Buffer Size: 256
[14:24:15][C][uart.arduino_esp8266:124]:   Baud Rate: 9600 baud
[14:24:15][C][uart.arduino_esp8266:125]:   Data Bits: 8
[14:24:15][C][uart.arduino_esp8266:126]:   Parity: NONE
[14:24:15][C][uart.arduino_esp8266:127]:   Stop bits: 1
[14:24:15][C][uart.arduino_esp8266:129]:   Using hardware serial interface.
[14:24:15][C][captive_portal:089]: Captive Portal:
[14:24:15][C][mdns:116]: mDNS:
[14:24:15][C][mdns:117]:   Hostname: esp-caperplus-q2
[14:24:15][C][esphome.ota:073]: Over-The-Air updates:
[14:24:15][C][esphome.ota:074]:   Address: esp-caperplus-q2.local:8266
[14:24:15][C][esphome.ota:075]:   Version: 2
[14:24:15][C][esphome.ota:078]:   Password configured
[14:24:15][C][safe_mode:018]: Safe Mode:
[14:24:15][C][safe_mode:019]:   Boot considered successful after 60 seconds
[14:24:15][C][safe_mode:021]:   Invoke after 10 boot attempts
[14:24:15][C][safe_mode:022]:   Remain in safe mode for 300 seconds
[14:24:15][C][api:140]: API Server:
[14:24:15][C][api:141]:   Address: esp-caperplus-q2.local:6053
[14:24:15][C][api:143]:   Using noise encryption: YES
[14:24:20][D][caperplus-q2:094]: Available bytes: 62
[14:24:20][D][caperplus-q2:100]: Found header!
[14:24:20][D][caperplus-q2:115]: pH: 9.16
[14:24:20][D][caperplus-q2:116]: TDS: 0
[14:24:20][D][caperplus-q2:117]: Temp: 21.8
[14:24:20][D][sensor:093]: 'Temperature': Sending state 21.80000 °C with 1 decimals of accuracy
[14:24:20][D][sensor:093]: 'pH': Sending state 9.16000 pH with 2 decimals of accuracy
[14:24:20][D][sensor:093]: 'TDS': Sending state 0.00000 ppm with 0 decimals of accuracy
[14:24:20][D][caperplus-q2:065]: Clearing Serial Buffer
To clear your doubts:
  • Caperplus mobile app is no longer working
  • physical calibration button still works as designed
Good luck!
Hey bro, can you specific how you connect the esp soldered wire to USB to TTL converter UART module CH340G CH340 3.3V 5V switch (this one I have)
Hi, there is a diagram in the link about soldering from my post
Thank you so much for your reply, I just finger out that it’s a lit bit tricky with Win 11 and Usb 3.2 on my mainboard, have to use though hub to fix it, now im in trouble with Custom component is stop supporting now, you have any idea ?
Updated:
Fixed with this support
