Capteur Z2M qui ne se met pas à jour
Bonjour,
J’ai acheté ce capteur de température et d’humidité Tuya SM0201 control via MQTT | Zigbee2MQTT
Je l’ai ajouté sur mon home assistant sur zigbee2mqtt
Mais il ne se met pas à jour régulièrement. Pour preuves les logs et la capture d’écran.
Par exemple, pourquoi entre le 2024-10-24 20:11:24 et le 2024-10-25 18:25:31, il indique 77.7% d’humidité ?
A noter que je suis allé appuyer sur le bouton de synchro à 18h25 ce qui a permis d’obtenir une MàJ avec la valeur 73.3 qui est bonne.
[2024-10-23 18:48:51] info: 	z2m: temp_hum_sdb (0x8cf681fffef482b3): SM0201 - Tuya Temperature & humidity sensor with LED screen (EndDevice)
[2024-10-23 18:48:52] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb/availability', payload '{"state":"online"}'
[2024-10-23 18:48:52] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":74.4,"last_seen":"2024-10-23T16:38:58+02:00","linkquality":131,"temperature":19.3,"voltage":null}'
[2024-10-23 18:49:22] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":74.4,"last_seen":"2024-10-23T16:38:58+02:00","linkquality":131,"temperature":19.3,"voltage":null}'
[2024-10-23 18:51:56] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":74.4,"last_seen":"2024-10-23T18:51:56+02:00","linkquality":134,"temperature":21.5,"voltage":null}'
[2024-10-23 18:51:56] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":85,"last_seen":"2024-10-23T18:51:56+02:00","linkquality":134,"temperature":21.5,"voltage":null}'
[2024-10-23 19:29:06] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":85,"last_seen":"2024-10-23T19:29:06+02:00","linkquality":134,"temperature":22.5,"voltage":null}'
[2024-10-23 19:29:53] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":88.2,"last_seen":"2024-10-23T19:29:53+02:00","linkquality":142,"temperature":22.5,"voltage":null}'
[2024-10-23 19:39:51] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":88.2,"last_seen":"2024-10-23T19:39:51+02:00","linkquality":138,"temperature":23.5,"voltage":null}'
[2024-10-23 19:43:50] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":85.2,"last_seen":"2024-10-23T19:43:50+02:00","linkquality":131,"temperature":23.5,"voltage":null}'
[2024-10-23 19:50:16] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":82.1,"last_seen":"2024-10-23T19:50:16+02:00","linkquality":134,"temperature":23.5,"voltage":null}'
[2024-10-23 19:50:42] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":82.1,"last_seen":"2024-10-23T19:50:42+02:00","linkquality":138,"temperature":22.5,"voltage":null}'
[2024-10-23 20:03:47] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":82.1,"last_seen":"2024-10-23T20:03:47+02:00","linkquality":142,"temperature":21.5,"voltage":null}'
[2024-10-23 20:03:47] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-23T20:03:47+02:00","linkquality":142,"temperature":21.5,"voltage":null}'
[2024-10-23 20:41:51] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-23T20:41:51+02:00","linkquality":145,"temperature":21.5,"voltage":null}'
[2024-10-24 00:06:07] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-24T00:06:07+02:00","linkquality":138,"temperature":21.5,"voltage":null}'
[2024-10-24 00:06:07] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-24T00:06:07+02:00","linkquality":134,"temperature":21.5,"voltage":null}'
[2024-10-24 00:44:25] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-24T00:44:25+02:00","linkquality":134,"temperature":21.5,"voltage":null}'
[2024-10-24 04:46:48] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-24T04:46:48+02:00","linkquality":134,"temperature":21.5,"voltage":null}'
[2024-10-24 07:07:23] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.6,"last_seen":"2024-10-24T07:07:23+02:00","linkquality":134,"temperature":19.5,"voltage":null}'
[2024-10-24 07:07:23] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T07:07:23+02:00","linkquality":134,"temperature":19.5,"voltage":null}'
[2024-10-24 08:49:14] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T08:49:14+02:00","linkquality":134,"temperature":19.5,"voltage":null}'
[2024-10-24 11:09:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T11:09:44+02:00","linkquality":127,"temperature":19.5,"voltage":null}'
[2024-10-24 11:09:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T11:09:44+02:00","linkquality":134,"temperature":19.5,"voltage":null}'
[2024-10-24 11:09:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T11:09:44+02:00","linkquality":138,"temperature":19.5,"voltage":null}'
[2024-10-24 12:52:19] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T12:52:19+02:00","linkquality":142,"temperature":19.5,"voltage":null}'
[2024-10-24 16:55:21] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T16:55:21+02:00","linkquality":138,"temperature":19.5,"voltage":null}'
[2024-10-24 18:45:56] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":72.5,"last_seen":"2024-10-24T18:45:56+02:00","linkquality":134,"temperature":21.8,"voltage":null}'
[2024-10-24 18:45:56] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":83.2,"last_seen":"2024-10-24T18:45:56+02:00","linkquality":134,"temperature":21.8,"voltage":null}'
[2024-10-24 19:03:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.2,"last_seen":"2024-10-24T19:03:57+02:00","linkquality":131,"temperature":21.8,"voltage":null}'
[2024-10-24 19:29:35] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":83.8,"last_seen":"2024-10-24T19:29:35+02:00","linkquality":142,"temperature":21.8,"voltage":null}'
[2024-10-24 19:38:42] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":83.8,"last_seen":"2024-10-24T19:38:42+02:00","linkquality":138,"temperature":22.8,"voltage":null}'
[2024-10-24 19:42:23] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":80.8,"last_seen":"2024-10-24T19:42:23+02:00","linkquality":138,"temperature":22.8,"voltage":null}'
[2024-10-24 20:11:24] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-24T20:11:24+02:00","linkquality":138,"temperature":22.8,"voltage":null}'
[2024-10-24 20:23:24] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-24T20:23:24+02:00","linkquality":138,"temperature":21.8,"voltage":null}'
[2024-10-24 20:58:14] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-24T20:58:14+02:00","linkquality":112,"temperature":21.8,"voltage":null}'
[2024-10-25 00:25:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T00:25:44+02:00","linkquality":116,"temperature":21.8,"voltage":null}'
[2024-10-25 00:25:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T00:25:44+02:00","linkquality":112,"temperature":21.8,"voltage":null}'
[2024-10-25 01:00:43] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T01:00:43+02:00","linkquality":112,"temperature":21.8,"voltage":null}'
[2024-10-25 05:03:51] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T05:03:51+02:00","linkquality":112,"temperature":21.8,"voltage":null}'
[2024-10-25 09:06:16] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T09:06:16+02:00","linkquality":120,"temperature":21.8,"voltage":null}'
[2024-10-25 13:08:41] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T13:08:41+02:00","linkquality":123,"temperature":21.8,"voltage":null}'
[2024-10-25 17:11:54] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T17:11:54+02:00","linkquality":123,"temperature":21.8,"voltage":null}'
[2024-10-25 18:25:31] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":77.7,"last_seen":"2024-10-25T18:25:31+02:00","linkquality":123,"temperature":20.4,"voltage":null}'
[2024-10-25 18:25:31] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_hum_sdb', payload '{"battery":null,"humidity":73.3,"last_seen":"2024-10-25T18:25:31+02:00","linkquality":123,"temperature":20.4,"voltage":null}'
Hi, welcome. Bienvenue. This is an English only forum. We are all kinds of nationalities here (I’m Dutch), so we need a common language in order for us all to be able to understand one another. If you want to only speak French, there are alternatives such as:
But I welcome you to translate it for us (using a translation service or mnual) so we do not all need to do the same.
