apax
(Aaron Paxson)
March 5, 2026, 7:25pm
1
Hey everyone! First time posting here.
I’ve got two LoRa sensors talking with each other, sending data. Love it, and it works! YAY!
I’m curious if there is a way to save RSSI as a sensor entity? The only way I know to capture RSSI is via example code using logs during “on_packet” event. Hoping to somehow capture this data to a sensor so I can track the signal strength and noise over time.
# LoRa Radio Configuration (SX1262)
sx126x:
on_packet:
- lambda: |-
ESP_LOGD("lora", "Received packet RSSI: %.2f dBm, SNR: %.2f dB, Data: %s",
rssi, snr, format_hex(x).c_str());
Anyone have thoughts how to capture the variable data (‘rssi’ and ‘snr’) from “on_packet” event to a sensor template?
apax
(Aaron Paxson)
March 5, 2026, 7:46pm
2
It should be noted, that I did try to SET the state of a sensor, rather than reading a state. Doesn’t look like I can?
sx126x:
on_packet:
- lambda: |-
id(rssi).state = rssi;
unit_of_measurement: dB
Karosm
(Karosm)
March 5, 2026, 8:23pm
3
I’m not familiar with this component but give it a try like this:
unit_of_measurement: "dBm"
update_interval: never
on_packet:
- lambda: |-
id(lora_rssi).publish_state(rssi);
apax
(Aaron Paxson)
March 6, 2026, 4:20am
4
Karosm:
publish_state()
This is exactly what I needed! Thank you!
