A car remote start/lock/unlock for 2 cars using a spare keyfob. Simply pushing a button on the fob usually shortens 2 contacts and trigger the fob. The same thing can be done with a relay board and an esp8266. Esp must close the relay for 0.5 second for the first car and 1.5 seconds for the second car. The relay is wired normally open (obviously). My relay board is low trigger (bought by mistake) which means when the esp is not sending a command (switch turned off), the relay is triggering, hence, all switches outputs are inverted.
esphome:
friendly_name: keyfob-gate-garage
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
use_address: 192.168.2.xxxx
#ap:
#ssid: "Esphome-Web-099498"
#password: "xxxxxxxx"
captive_portal:
#Define sensors
- platform: wifi_signal
name: ${upper_devicename} Wifi Signal
update_interval: 60s
- platform: uptime
#Wifi status
binary_sensor:
- platform: status
#firmware status
text_sensor:
- platform: version
name: ${upper_devicename} ESPHome Version
#switches
switch:
- platform: gpio
pin: D4 #Internal LED switching
name: "NodeMCU Internal LED"
inverted: true
restore_mode: ALWAYS_ON
- platform: gpio
pin: D0
restore_mode: ALWAYS_OFF
inverted: true
on_turn_on:
- delay: 500ms
- switch.turn_off: BRUNLOCK
- delay: 500ms
- lock.unlock: Bravada
- platform: gpio
pin: D1
inverted: true
on_turn_on:
- delay: 500ms
- switch.turn_off: BRLOCK
- delay: 500ms
- lock.lock: Bravada
- platform: gpio
pin: D3
inverted: true
on_turn_on:
- delay: 1500ms
- switch.turn_off: RV4UNLOCK
- delay: 500ms
- lock.unlock: Rav4
- platform: gpio
pin: D2
inverted: true
on_turn_on:
- delay: 1500ms
- switch.turn_off: RV4LOCK
- delay: 500ms
- lock.lock: Rav4
- platform: gpio
pin: D6
name: "Rav 4 Gate"
inverted: true
on_turn_on:
- delay: 1500ms
- switch.turn_off: RV4GT
- platform: gpio
pin: D5
name: "Rav 4 remote start"
inverted: true
on_turn_on:
- delay: 1500ms
- switch.turn_off: remote
#just to fool home assistant into creating a lock entity
output:
- platform: gpio
pin: D8
inverted: true
- platform: gpio
pin: D8
inverted: true
lock:
- platform: output
output: dummybravada
on_lock:
- switch.toggle: BRLOCK
on_unlock:
- switch.toggle: BRUNLOCK
- platform: output
output: dummyrav4
on_lock:
- switch.toggle: RV4LOCK
on_unlock:
- switch.toggle: RV4UNLOCK
