Car telemetry and Torque data
Hello i prepared small converter to this data. It is a lot of stuff so you can easly add it
@cunninr2 Hi Robert, if one doesn’t have an active connection to HA, would it still upload all the data once it has a connection again ? For example, on my driveway the android tablet i use it will have a connection through wifi, but once driving not.
When i come back, will it upload all the remaining data that torque put in the log file (as i believe your script polls the last line and sends of a Mqtt request for that). It seems i get just one mqtt message from when it was back home. Is that how you would expect it to work ?
If so, would you considered releasing a version that uploads all the data when has connectivity again (for those who don’t have data available or do not need realtime data) ? If not feasible, do you just allow everything through when using data or do you use something like data saver in android ? I find android to be quite data hungry…
Also - what do you use frontend wise for the automate sensor (the BT scan) and display occupants?
Many thanks!
need nodered
