Card Access Control System
I was wondering if anybody able to connect home assistant with Card Access Control System.
RFID Proximity Card Access Control System 125KHz RFID Keypad Card Access Control Door Opener + 60KG Electric Magnet Lock
https://www.aliexpress.com/item/KKmoon-RFID-Proximity-Card-Access-Control-System-125KHz-RFID-Keypad-Card-Access-Control-Door-Opener-60KG/32789394176.html?spm=2114.10010108.1000023.11.586a61be3vol3U
Old topic but I am getting into this now. Tasmota has added support for Wieland protocol (no formal release yet) I have ordered RFID readers and tags to see if this work.
The plan is to add electronic locks for a scouting building. This because they frequently loose keys.
A problem I see is how to decide to open the lock. A simple automation which triggers for the right code is probably less suited since I need > 25 ‘keys’ A file per lock which code can open them is probably easier to manage. Tips are appreciated.
Very old, and uncategorised. You will get better visibility by posting a new topic in the Configuration category.
Maybe it’s just me, but I don’t browse on category.
I have all topics in one long list sorted by time.
Just put them in an array and compare against the array.
Yes it will show up there, but if you click on the “New” posts link (like I do most of the time) then posts that are not categorised will not show up.
