I’m just wondering if I should submit a bug report or if this is something I should fix on my end.
So changes made to my card’s YAML with card-mod show up in the Card Configuration preview immediately but the actual dashboard does not include these changes. If I re-open the Card Configuration again the preview no-longer shows correctly unless I make any additional changes to to the YAML, even just adding a space will update the preview correctly but it still doesn’t show properly on the dashboard after saving.
I’m not sure if my YAML is to blame or if this is a bug with card-mod or HA. Here is my card’s YAML:
type: custom:horizon-card
fields:
dawn: false
dusk: false
noon: false
sunrise: true
sunset: true
card_mod:
style: |
div.horizon-card-header {
margin-top: 0px !important;
margin-bottom: -1rem !important;
div.horizon-card-graph {
margin: 0px !important;
div.horizon-card-footer {
Versions:
Home Assistant 2023.4.2
Supervisor 2023.04.0
Operating System 9.5
Frontend 20230406.1 - latest
HACS: (Integration: 1.30.1), ( Frontend: 20220906112053)
card-mod: 3.2.2
I did have a similar issue with card-mod changes no-longer showing up on the dashboard after the page gets reloaded or refreshed but adding:
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js
to the configuration.yaml made the changes stick after each time the page loaded. That fixed that issue but not this one.
Does my YAML look correct, in other words should I submit a bug report? Anyone else have this issue or find a fix?
