Card for Water Leak Sensor
I have two Dome water sensors. I am looking for ideas as to showing their status on a card. I have tried most of the standard ones for entities. Just curious what others are using for their leak sensor cards. Ideally I would like to show status and battery %.
My sensors are not battery powered so no battery %, just a glance card showing the states:
water_leak_card
nothing flash:
battery is handled elsewhere via Howto create battery alert without creating a template for every device
Battery Config
sensor flood:
    sensors:
      flood_battery:
          friendly_name: Flood Detector Battery
          unit_of_measurement: "%"
          value_template: >-
                  {{ state_attr("zwave.flood_detector","battery_level") | round }}
Battery Card
     - type: gauge
        title: Flood Detector Battery
        unit_of_measurement: '%'
        entity: sensor.flood_battery
        severity:
          green: 70
          yellow: 50
          red: 0
Screenshot%20from%202019-08-15%2020-34-30
Flood Config Template
binary_sensor flood:
    sensors:
      flood:
        device_class: moisture
        friendly_name: Flood Sensor
        value_template: "{{ states('sensor.flood_detector_flood')|float > 0 }}"
Flood Detector Card:
  cards:
   - type: entities
     show_header_toggle: false
     entities:
      - binary_sensor.flood
Screenshot%20from%202019-08-15%2020-37-52
I use a custom:button-card for a hot water tank leak sensor. The sensor flashes Red when the water sensor is tripped.
Hey smish can you share your lovelace info and any custom sensors to make it work?
Hi, sure, sorry haven’t been on here for a bit, but here it is.
  - color: green
    color_type: card
    entity: binary_sensor.water_tank_water_sensor
    hold_action:
      action: more-info
    icon: 'mdi:water-off'
    name: Hot Water Tank
    state:
      - color: red
        icon: 'mdi:pipe-leak'
        styles:
          card:
            - animation: blink 2s ease infinite
        value: 'on'
    tap_action:
      action: more-info
    type: 'custom:button-card'
  - color: green
    color_type: card
    entity: binary_sensor.kitchen_sink_water_sensor
    hold_action:
      action: more-info
    state:
      - color: red
        styles:
          card:
        value: 'on'
    tap_action:
      action: more-info
Thanks. Have to figure this out. When I use what you shared and put in my own sensors I just get a straight black horizontal line and nothing else at all.
mine flashes the lights in said room until a double click that light switch
Just to confirm, did you install the custom:button_card?
