I want to show solar panel data. One card with three values for each panel, then those cards stuck in a vertical stack (or a view I guess would also be fine)
I can’t get the basic solar panel card to do what I want, I have more data on there than I want. My definition
entities:
- entity: sensor.solar_panel_1_active
- entity: sensor.solar_panel_1_current_watts
- entity: sensor.solar_panel_1_lte
show_header_toggle: false
title: Solar Panel One
type: entities
and what I get is:
And what I would like is just the values for those three sensors, not the name or custom name and alot of space. So in this case have it read ```ACTIVE, 0 watts, 12345 Watt/hours" . Any thoughts on if I can do that? ( I also notice if I click the sensor name, I get a graph for 30 minutes which isn’t really what I would want, but kind of don’t care a lot about that right now)
Additionally, I was going to make a status card with just the active status for all the panels on it. Green if they are ACTIVE / RED if they are not. Anything like that already exist I could leverage? I’m not super up on the UI components yet.
tom_l
February 19, 2020, 8:59am
2
You could use a glance card with show_name
and show_icon
set to false
if you want them stacked vertically set the number of columns
to 1.
perfect, just what I wanted thanks!
If anyone is curious I did the following:
columns: 4
entities:
- entity: sensor.solar_panel_1_name
- entity: sensor.solar_panel_2_name
- entity: sensor.solar_panel_2_active
- entity: sensor.solar_panel_2_current_watts
- entity: sensor.solar_panel_2_lte
- entity: sensor.solar_panel_3_name
- entity: sensor.solar_panel_3_active
- entity: sensor.solar_panel_3_current_watts
- entity: sensor.solar_panel_3_lte
- entity: sensor.solar_panel_4_name
- entity: sensor.solar_panel_4_active
- entity: sensor.solar_panel_4_current_watts
- entity: sensor.solar_panel_4_lte
- entity: sensor.solar_panel_5_name
- entity: sensor.solar_panel_5_active
- entity: sensor.solar_panel_5_current_watts
- entity: sensor.solar_panel_5_lte
- entity: sensor.solar_panel_6_name
- entity: sensor.solar_panel_6_active
- entity: sensor.solar_panel_6_current_watts
- entity: sensor.solar_panel_6_lte
- entity: sensor.solar_panel_7_name
- entity: sensor.solar_panel_7_active
- entity: sensor.solar_panel_7_current_watts
- entity: sensor.solar_panel_7_lte
- entity: sensor.solar_panel_8_name
- entity: sensor.solar_panel_8_active
- entity: sensor.solar_panel_8_current_watts
- entity: sensor.solar_panel_8_lte
- entity: sensor.solar_panel_9_name
- entity: sensor.solar_panel_9_active
- entity: sensor.solar_panel_9_current_watts
- entity: sensor.solar_panel_9_lte
- entity: sensor.solar_panel_10_name
- entity: sensor.solar_panel_10_active
- entity: sensor.solar_panel_10_current_watts
- entity: sensor.solar_panel_10_lte
- entity: sensor.solar_panel_11_name
- entity: sensor.solar_panel_11_active
- entity: sensor.solar_panel_11_current_watts
- entity: sensor.solar_panel_11_lte
show_icon: false
show_name: false
show_state: true
title: Solar Panels
type: glance
which uses the following sensor setup for the solar bridge data I am piping in:
# each row is a panel, each cell array has the following data
# 0 serial number
# 1 firmware
# 2 status
# 3 dc volts
# 4 watts
# 5 lte (watt hours)
# 6+ grid profile
sensors:
solar_panel_1_name:
value_template: "1"
solar_panel_2_name:
value_template: "2"
solar_panel_3_name:
value_template: "3"
solar_panel_4_name:
value_template: "4"
solar_panel_5_name:
value_template: "5"
solar_panel_6_name:
value_template: "6"
solar_panel_7_name:
value_template: "7"
solar_panel_8_name:
value_template: "8"
solar_panel_9_name:
value_template: "9"
solar_panel_10_name:
value_template: "10"
solar_panel_11_name:
value_template: "11"
- platform: mqtt
state_topic: "homeassistant/sensor/solar_panels"
value_template: '{{ value_json.rows[0][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[0][''cell''][4] | float }}'
unit_of_measurement: "Watts"
- platform: mqtt
value_template: '{{ value_json.rows[0][''cell''][5] | float / 1000 }}'
unit_of_measurement: "kWh"
- platform: mqtt
value_template: '{{ value_json.rows[1][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[1][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[1][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[2][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[2][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[2][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[3][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[3][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[3][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[4][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[4][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[4][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[5][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[5][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[5][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[6][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[6][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[6][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[7][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[7][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[7][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[8][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[8][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[8][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[9][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[9][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[9][''cell''][5] | float / 1000 }}'
- platform: mqtt
value_template: '{{ value_json.rows[10][''cell''][2] }}'
- platform: mqtt
value_template: '{{ value_json.rows[10][''cell''][4] | float }}'
- platform: mqtt
value_template: '{{ value_json.rows[10][''cell''][5] | float / 1000 }}'
# 0 serial number
# 1 firmware
# 2 status
# 3 dc volts
# 4 watts
# 6 grid profile
## Automation
# TODO
## Recorder/History
recorder:
include:
entities:
- sensor.solar_panel_1_active
- sensor.solar_panel_1_current_watts
- sensor.solar_panel_1_lte
- sensor.solar_panel_2_active
- sensor.solar_panel_2_current_watts
- sensor.solar_panel_2_lte
- sensor.solar_panel_3_active
- sensor.solar_panel_3_current_watts
- sensor.solar_panel_3_lte
- sensor.solar_panel_4_active
- sensor.solar_panel_4_current_watts
- sensor.solar_panel_4_lte
- sensor.solar_panel_5_active
- sensor.solar_panel_5_current_watts
- sensor.solar_panel_5_lte
- sensor.solar_panel_6_active
- sensor.solar_panel_6_current_watts
- sensor.solar_panel_6_lte
- sensor.solar_panel_7_active
- sensor.solar_panel_7_current_watts
- sensor.solar_panel_7_lte
- sensor.solar_panel_8_active
- sensor.solar_panel_8_current_watts
- sensor.solar_panel_8_lte
- sensor.solar_panel_9_active
- sensor.solar_panel_9_current_watts
- sensor.solar_panel_9_lte
- sensor.solar_panel_10_active
- sensor.solar_panel_10_current_watts
- sensor.solar_panel_10_lte
- sensor.solar_panel_11_active
- sensor.solar_panel_11_current_watts
- sensor.solar_panel_11_lte
history:
include:
entities:
and produces:
There are probably ways to make it look prettier, but that is compact which is what I wanted.
