šŸ”¹ Card-mod - Add css styles to any lovelace card
I use yaml mode, too.
But with that UI-integrated one. Not via ssh in external editor like Notepad++.
Well, seem that I have to change my behavior.
Stay Safe, crazy times we are living in.
Morning,
so since I updated somethings stopped working. I remember reading they were going to depricate something but I just can’t find the thread anymore. I’m pretty sure they wanted to depricate the paper item or something but what I’m kinda confused about is that that is still working, that’s not working is ā€œ.infoā€ I want to hide this part here:
it was working just fine with this:
    - type: entities
      entities:
        - input_text.documentation_content
      title: Weitere Dokumentation (optional)
      card_mod:
        style:
          '#states div':
            hui-input-text-entity-row$:
              hui-generic-entity-row$: |
                .info {
                 display: none;
                state-badge {
                 display: none;
              paper-input$: |
                paper-input-container iron-input {
                  --paper-input-container-shared-input-style_-_width: 55vw;
.info {display: none; } doesn’t work anymore, i tried digging deep into the css but nothing I’ve tried worked so far.
from the hui-generic-entity-row.ts
static get styles(): CSSResultGroup {
    return css`
      :host {
        display: flex;
        align-items: center;
        flex-direction: row;
      .info {
        margin-left: 16px;
        margin-right: 8px;
        flex: 1 1 30%;
      .info,
      .info > * {
        white-space: nowrap;
        overflow: hidden;
        text-overflow: ellipsis;
      .flex ::slotted(*) {
        margin-left: 8px;
        min-width: 0;
      .flex ::slotted([slot="secondary"]) {
        margin-left: 0;
      .secondary,
      ha-relative-time {
        color: var(--secondary-text-color);
      state-badge {
        flex: 0 0 40px;
      :host([rtl]) .flex {
        margin-left: 0;
        margin-right: 16px;
      :host([rtl]) .flex ::slotted(*) {
        margin-left: 0;
        margin-right: 8px;
      .pointer {
        cursor: pointer;
Any idea what I missed? Any hint would be appreciated.
fyi, adding the player to an entities card makes a difference. Perfectly aligned with the other cards, and exact height of a regular card-header (in my config):
  - type: entities
    entities:
      - type: custom:browser-player
        card_mod:
          style: |
            ha-card {
              height: 48px;
              box-shadow: none;
              margin: -16px;
            .card-content {
              padding-left: 8px;
              padding-top: 0px;
              justify-content: space-between;
            .device-id {
              padding-left: 20px;
              position: absolute;
              left: 0%;
              bottom: -5%;
adding:
        .placeholder {
          display: none;
widens the slider a bit, by taking out an empty placeholder, though still not as much as could be.
tried
 show_name: false
Where would it go? Since I don’t think this is an option for the configuration of Entitites and it’s not working as style option either.
Edit:
Thank you for the hint though, I made my life a lot easier and just used name
not the prettiest but it does the trick!
lol, was just about to suggest it, but coun’t find where i saw that :slight_smile:
… every ā€œtweakā€ counts … as long as it work :wink:
Sometimes I just like to make my life a lot harder than it has to be lol.
No idea why it’s so hard sometimes to see the easy stuff and so easy to get stuck on ā€œI have to do it this way!ā€
thank you, again :wink:
I ā€œblameā€ my lazy nature, gives me a lot of ā€œgoodā€ ideas :laughing:
Hi Marius … the red Clock in your player menu, is that a ā€œwake-upā€ function, starting the player at scheduled time ?
no, it’s just my custom navigation menu, pointing to the alarm clock view. Red means an alarm is active :wink:
Found a ā€œplaygroundā€ for CSS … came out with this:
position:relative; right:4px;
try it
PS: Sorry, i see now in your latest ā€œscreenshotā€ you already got id/speaker aligned
ahhh, i thought ā€œdamnā€ wake-up invention :grinning_face_with_smiling_eyes:
PS: i hate alarm-clocks :slight_smile:
tried
{flex-grow: 3;}
on slider (id) .placeholder , or what/how it is
could you please advise me how to edit the card?
I use this compass card and I would like to change the title of the card (Rychlost a směr větru) so that the title is in Araboto Normal font and size 20px. Keep the rest of the card original.
type: custom:compass-card
indicator_sensors:
  - sensor: sensor.lacrosse_tx141w_senzor_vetru_wd
    indicator:
      type: arrow_inward
value_sensors:
  - sensor: sensor.lacrosse_tx141w_senzor_vetru_ws
header:
  title:
    value: Rychlost a směr větru
language: cz
compass:
  north:
    show: true
try with
style: your CCS here
example above requires card-mod installed, and that you have ā€œAraboto fontsā€ … ( if Araboto fon’t are your preferred font’s i suggest you define ( Headers / Titles / Box text etc. in your Theme )
That is if you want to use these font’s in your cards, … if you already have a card with this font/size defined, it would be helpful to se the ā€œcodeā€
anyone seeing why this will not do its job anymore:
      - entity: sensor.backup_state
        card_mod:
          style: |
            :host {
              --card-mod-icon:
                {% if states(config.entity) == 'backed_up' %} mdi:check-circle
                {% else %} mdi:alert-circle
                {% endif %};
              --paper-item-icon-color:
                {% if states(config.entity) == 'backed_up' %} green
                {% else %} red
                {% endif %};
colors and icon are untouched…
edit
nvm. they came back. I had re=installed the add-on Google drive backup, to change the backup drives. apparently these sensor entities were deleted and recreated and the Frontend didnt like that.
A cache refresh and page reload brought it back
Hi, After the last update I have a problem with headings.
I tried to add to my theme.yaml: (RESOLVED WITH THIS:)
  mdc-select-label-ink-color: "#FFFFFF"
Thank you Arganto
maybe there is a ā€œheadingā€ line, or you could add one, that is if it really is a ā€œheadingā€ … if
1F1F28
is the color ā€œdefinedā€ or the color you want to change, it shouldn’t be so hard to find
Go through your Theme, change where you think it might be, maybe ā€œsecondary-colorā€ … or so , try change
Sorry, i can’t be more specific, as i did ā€œbackupā€ my theme, and after Updating HA, i went through it, thou i did wait until an ā€œupdateā€ came for the specific card, to see if that fixed it for me :), so i really did have to wait long before, it was ā€œauto-fixedā€ by update, only needed to change 1 place, in my Theme ( which by the way also was updated, so it was not hard to compare, updated Theme, with my current … before i ā€œappliedā€ the theme update
Edit: try secondy-text-color
@venca.kratky has the same problem as me it seems. I also couldn’t find the CSS to change the label.
before I had it under .info like this
card_mod:
  style:
    '#states div':
      hui-input-select-entity-row$:
          .info {
           display: none;
But that’s not working after the update anymore. I couldn’t find it anywhere btw so I rolled back to the version 02.9, as 03.03 basically destroyed my homeassistant.
Edit:
Oh I see it’s a theme, my bad. If you change it in general then secondary-text-color should work.
