Unfortunately, although I have âsecondary-text-color: #FFFFFFâ
the label is still dark
Isnât it mdc-select-label-ink-color
and is FFFFFF what you want to have ? ⌠you are not being very specific, âŚjust saying âŚ
maybe try : to add your âdesiredâ color to new line:
âmdc-select-label-ink-colorâ: âŚsecondaryâŚ
YES!!! Thatâs it. Itâs finally working! THANK YOU
All this is not related to card-mod. Can you ask/discuss all this in a seperate topic?
I would like to change the size of the moon icon with glance card, itâs a png image and not an icon.
with this code donât work:
- entity: sensor.moon_phases
style: |
ha-card {
--mdc-icon-size: 20px;
code:
header_cards:
cards:
- type: glance
columns: 6
entities:
- entity: alarm_control_panel.54ef44273cc1_alarm
- entity: group.grp_portes
style: |
ha-card {
--mdc-icon-size: 33px;
- entity: group.grp_fenetres
- entity: group.grp_lumieres
style: |
ha-card {
--mdc-icon-size: 27px;
- entity: sun.sun
style: |
ha-card {
show_name: false
show_icon: true
show_state: false
help please?
Thatâs your hint. Did you inspect the HTML?
Without the relevant HTML itâs very hard to offer any advice, but Iâm fairly sure that CSS variable are only relevant to ha-icon
tags and your PNG sits in some img
tag â hence my quote above. You need to find the correct path to that PNG image and set the style on that element.
does it help you?
<state-badge style="background-image: url("https://homeassistant.local:8123/local/moon_phases/waxing_gibbous.png");"></state-badge>
edit:
Iâve found with:
state-badge {
height: 27px;
width: 27px;
Thanks for directing me where.
Hello!
Does anyone know if the row-gap
and the column-gap
properties can be individually styled?
Most propably exactly as you have shown. Set it accordingly. row-gap and column-gap.
So far I have tried:
card_mod:
style: |
.modes {
gap: 8px;
row-gap: 8px;
column-gap: 8px;
Use
column-gap: 8px !important;
Thanks. I guess I was looking for padding.
This is how I styled the card:
card_mod:
style: |
ha-card {
--st-font-size-xl: 45px;
--st-spacing: 3.5px;
.modes > .mode-item {
border-radius: 12px;
.modes > .mode-title {
padding: 0px 5px;
font-weight: 400;
.modes.heading {
padding: 1px 5px 1px 5px;
This is without styling:
Has something changed with the use of mod-card
since 2022.3 or a recent card-mod
upgrade?
Yes, Iâve read the instructions and as the read-me says âI know what Iâm doingâ. In fact I have been using this successfully for well over a year.
Now I have upgraded to 2022.03 and I get this error
I have this in my configuration.yaml
frontend:
themes: !include_dir_merge_named themes/
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js
and have tried with and without this in my resources.yaml
(Do I need it or not?)
- url: /hacsfiles/lovelace-card-mod/card-mod.js
type: module
card-mod is obviously installed and working everywhere else.
Usual restarts, refreshes and clearing cache have been tried.
Any help please!
PS Edge browser desktop and phone if that makes a difference.
see: mod-card 'doesnt exist' on first load ¡ Issue #185 ¡ thomasloven/lovelace-card-mod ¡ GitHub and please chime inâŚ
I saw this with update to 2022.03 as well.
I took it as a sign that with constant changes to the frontend, the writing is likely on the wall for the mod_card
trick (I should underline of course that this is not official in any way), so I ended up replacing all my styled horizontal-stack
and vertical-stack
cards with Custom Stack In Card
It has a ha-card
element so can be more easily styled with the standard card_mod
approach.
I use a picture-glance (in a vertical stack card) for my camera and am pleased with the result in general.
The only downer is that it takes a short while before the image is loaded, but just enough to be annoying.
The picture-glance is the top card and just when you want to tap a button, the image is loaded and so the button jumps to a lower position in the screen.
I am wondering if itâs possible to somehow set a predefined height. Unfortunately am too new to the Card-mod to figure it out by myself. Anyone a suggestion how to solve it?
Try to find your solution here:
1st post -> link at the bottom -> post with styles -> post for Picture Glance card
If no solution is present then come back with a more detailed description.
I added (your) code for a picture-elements: Styling elements in Picture elements card: a small tutorial - #2 by Ildar_Gabdullin
That seemed to work.
thanks for this mod.
I want to create a simple card with big time numbers.
What Iâve tried is very simple. Color and weight change is working, but font and size donât work. Increasing the font size does result in a bigger space at the top of the card, but the size of the numbers stay the same. Any suggestion?
type: entity
entity: sensor.time
card_mod:
style: |
ha-card {
font-size: 150px;
font-family: Helvetica;
color: yellow;
font-weight: bold;
state_color: false
