🔹 Card-mod - Add css styles to any lovelace card
Have you looked at custom:stack-in-card? Should join it all together so there isn’t any space between buttons. You could have 4 of them where you join the top and bottom together in each one, or you can make one big seamless stack with no spaces in between.
Thanks both for the pointers! Will check out both options.
I’m trying to fit in my home assistant kiosk on a Hyperpixel 4.0 square screen so i need to lower the height of an entity row avoiding a vertical scrollbar. For some reason i can’t get this to work, what i’m doing wrong?
My code:
  - type: entities
    entities:
      - entity: cover.rolluiken_slaapkamer_3
      - entity: cover.rolluiken_slaapkamer_2
      - entity: cover.rolluiken_slaapkamer_1
      - entity: cover.rolluiken_slaapkamer_0
      - entity: cover.sunscreen_1
      - entity: cover.sunscreen_2
      - entity: cover.sunscreen_3
    card_mod:
      style: |
        hui-generic-entity-row {
          height: 40px;
another option:
    - type: custom:mod-card
      card_mod:
        style: |
          :host {
            --grid-card-gap: 0px;
      card:
        type: grid
simply reduce the gap to 0 :wink:
or set that to the row in button-card directly:
    - type: custom:button-card
      styles:
        grid:
          - row-gap: 0px
1st post → link at the bottom
I would like to alter the look of the custom:weather-card fron Bram Kragten. I am an absolute beginner on this, and just start playing with the DOM Inspector after reading about this. I found the items i would like to change.
This is the card i want to change and below the card I changed via DOM inspector:
The changes are obvious in the header part of the card. This is the default code of the card:
type: custom:weather-card
entity: weather.home
number_of_forecasts: '5'
I made an overview of the items i would like to change:
The items are .icon_bigger, .title, .temp and .tempc
But i do’nt know how i put these with styles: in my card config.
I have the feeling i am almost there to understand how this works… But can anyone please tell me how i go further with this?
I found this in the Inspector:
You are doing it wrong!
card-mod.js?hacstag=190927524315:5 mod-card should NEVER be used with a card that already has a ha-card element, such as weather-card
OK, Does anyone knows how to change this Card? Perhaps @bramkragten the maker of this card?
Probably you tried to use mod-card with this weather card - which is wrong.
why dont you simply edit the card itself? You seem to know exactly what you want, go ahead and edit the resource file itself.
Hi @Mariusthvdb Marius,
You are right! I browsed the file weather-card.js and found the items to change. Success!
It was more the fear of the unknown; I have never done this before. AND I was hoping I could change this with the mod-card from Thomas Loven.
But it was actually quite simple. Looking back I feel myself a bit foolish… :slight_smile:
Thanks for putting me in the direction.
Why do you use :host in this and other examples?
Most probably these are very old examples…
In some cases I also used kind of “ha-card some_element”.
In most cases “:host” & “ha-card” will not harm - but they should be omitted, actually.
Ah o.k. Thought there is some magic 🧙‍♂️ behind. ha-card was/is fine. But :host is no html element/dom-path-selector, so most probably it was never necessary, but worked with it as well by chance.
Probably “:host” SHOULD be used only when it is the ONLY selector, like:
- entity: xxx
  card_mod:
    style: |
      :host { ... }
BTW, “:host” as a selector may be seen in Code Inspector:
just to clarify what it represents.
Also, In my first posts I used to use this construction:
element:
    element:
        element {...}
which will work but not optimal - see this.
Later I posted all styles with an optimized code (also, some old post were revised too).
Yes and no. :host is only a html pseudo class (as :after, etc.) not a dom structure element. So you can put styles for the shadow root in total.
But it is not there to derive the path as with (real) element in the html-tree.
Is there a way to use an if/else statement within CSS? Trying to get this to work:
[[[return `Status: <br><span style="color: lime;">{% if states('switch.pool_robot') ==='on' %} Cleaning {% else %} Sleeping {% endif %}</span>`]]]
It works fine with ${states[‘switch.pool_robot’].state}, but I’d rather it say Cleaning than just “on”, which is the true state.
Use search here for “{% if states(” string.
Got it!
[[[ if (entity.state === 'on') return `Status: <br><span style="color: lime;">Cleaning</span>`; return `Status: <br><span style="color: lime;">Sleeping</span>`; ]]]
still using that on various places. But not sure how to do without:
card_mod:
  style: |
    :host {
      --stack-card-margin: 0px;
card:
  type: vertical-stack
  cards:
and likewise:
    card_mod:
      style: |
        :host {
    card:
      type: grid
on a badge:
    - entity: person.marijn
      card_mod:
        style: |
          :host {
              --ha-label-badge-label-color: black;
            {% set zones = states.zone|map(attribute='name')|list %}
            {% set id = config.entity.split('.')[1] %}
            {% set activity = states('sensor.' ~ id ~ '_activity') %}
            {% set cc = state_attr('sensor.' ~ id ~ '_geocoded_location','ISO Country Code')|lower %}
            {% if cc and cc != 'nl' %}
              --label-badge-red: white;
            {% elif is_state(config.entity,'home') %}
              --label-badge-red: green;
              --ha-label-badge-label-color: gold;
            {% elif 'bij' in states(config.entity) %}
              --label-badge-red: gold;
            {% elif activity in ['Automotive','Cycling','Walking'] or
                    states(config.entity) in zones %}
              --label-badge-red: mediumslateblue
            {% else %}
              --label-badge-red: #636B75;
            {% endif %}
on an include filter in auto-entities:
          include:
            - attributes: {device_class: battery}
              options:
                secondary_info: last-updated
                style: |
                  :host {
                    --card-mod-icon-color: {% if states(config.entity)|int(-1) < 30 %}red
                                           {% elif states(config.entity)|int(-1) < 60 %}orange
                                           {%else%}green
                                           {%endif%};
and, eg on a plain entity:
      - entity: binary_sensor.backups_stale
        card_mod:
          style: |
            :host {
              --paper-item-icon-color:
                {% if states(config.entity) == 'off' %} green
                {% else %} red
                {% endif %}
and even worse:
      - entity: sensor.backup_state
        card_mod:
          style: |
            :host {
              --card-mod-icon:
                {% if states(config.entity) == 'backed_up' %} mdi:check-circle
                {% else %} mdi:alert-circle
                {% endif %};
                {% if states(config.entity) == 'backed_up' %} green
                {% else %} red
                {% endif %};
could you help me fix this, so I dont need the :host?
would be awesome,
You need :host there. And you are assigning things for :host. That is fne. I only wanted to address, that afaik we don’t need the :host in the path example above. and/or wanted to know if there is some unknown hidden magic behind it otherwise.
