No no no, only when used for some element inside some cards and only when used alone (w/o additional selectors). In other cases it may be omitted and actually should not be used.
Great examples for using restriction-card in row mode. I need to use it with buttons, where the look gets very strange. I guess this is caused by restriction-card in combination with button-card.
The main issue is: it does not maintain / use the height like the other ânormalâ button cards do when being used in a grid.
- For testing purposes: the used
height: 300px;
is not respected at all. - And even if it would: I canât absolutely define the height in px, it must be something fluent/automatical like âmaximumâ or something like that.
Problem screenshot:
left one is restriction-card with button-card, right one is normal button card (mind the gap below the left one):
Full code (as minimal as possible)
type: custom:mod-card
card:
type: grid
columns: 1
square: false
title: ''
cards:
- type: markdown
title: ''
content: Infrastruktur
style:
ha-card {
background: none;
border: 0px;
box-shadow: none;
#padding: 0 !important;
ha-markdown {
font-size: 24px;
#font-weight: 500;
#letter-spacing: 3px;
width: max-content;
margin: 0 auto;
margin-top: 0px;
- type: grid
columns: 3
square: true
title: ''
cards:
- type: custom:restriction-card
row: false
card:
type: button
tap_action:
action: navigate
navigation_path: network
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:lan
show_name: true
show_state: false
show_icon: true
card_mod:
style:
ha-card {
height: 300px;
#border: 1px solid;
restrictions:
confirm: null
pin:
code: 9999
text: 'Gesperrter Bereich. PIN nötig:'
retry_delay: 0
max_retries: unlimited
max_retries_delay: 0
block:
text: Zugriff nicht erlaubt.
exemptions:
- user: abc
exemptions:
- user: xyz
style: |
:host {
--restriction-lock-icon-size: 18px;
--restriction-regular-lock-color: var(--accent-color);
--restriction-success-lock-color: green;
--restriction-lock-margin-left: 28px;
--restriction-lock-row-margin-top: 30px;
div#overlay {
align-items: center;
- type: button
tap_action:
action: navigate
icon: mdi:lan
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
card_mod:
style:
hui-grid-card:
.card-header {
#text-align: center;
#margin-top: -10px;
ha-card {
border: 1px solid grey;
padding: 5px;
background: none;
Please note the view is configured to use the grid (layout card)
, in case that is important (tested also with default/standard, which also gives different look):
Question (@Ildar_Gabdullin): Is there any possibility to get a button-card inside a restriction-card to use the maximum/same height as other elements (normal button cards) in that grid
This really is a mission-critical thing as this should be used all over my lovelace dashboards. Hope thereâs a solution to have the restriction-card features while at the same time keeping a nice and ânaturalâ/original design.
Try using â!importantâ.
ha-card {
height: 300px;
#border: 1px solid;
Do not use â#â to comment smth inside a string.
That worked, thanks. But now to the original question: HowâŠ
Because absolute values (px) donât work. It will make all look different on different devices/screens. So that is the main problemâŠ
In my test case the 1st card (which is inside ârestrictionâ) got the same height as the 2ns card (with â!importantâ).
And you used absolute value (like 150px
)? That wonât work on other devices/screen sizes. Absolute values are wrong here
E. g.:
- device 1, edit mode: looks good
- device 1, normal mode: already fails
- device 2, normal mode: fails too (buttons too high, no 1/1 ratio anymore)
You now see what I mean?
Since you specified âsquare: trueâ for the grid - all elements inside the grid are square, including the ârestriction-cardâ. But the button inside he restriction-card is not square. To force it - apply âaspect-ratio: 1/1â for the inserted button.
Btw, this whole part will not work:
style: |
:host {
since the card does not have ha-card element. As well as grid-card. Use mod-card then.
- Oohhhhhh GREAT! that âaspect-ratio: 1/1â seems to make the trick. I was already aware of this as the
custom:button-card
implements/offers it as native configuration option. Didnât know itâs a CSS thing Fabulous. This works, being applied to the button inside the restriction-card:
card_mod:
style:
ha-card {
aspect-ratio: 1/1
Full example
row: false
card:
type: button
tap_action:
action: navigate
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:lan
show_name: true
show_state: false
show_icon: true
card_mod:
style:
ha-card {
aspect-ratio: 1/1
restrictions:
- Thanks for that bonus information, I was already wondering. Will have a look at this too.
Update: For now I just remove them cause the benefit of that styling is not that important and does not outperform the added complexity of using additional mod-card.
Last one regarding the restriction-card:
Initially I had this one without restriction-card:
style: |
ha-card {
height: 220px;
card:
type: button
icon: mdi:checkbox-marked-circle
tap_action:
action: navigate
navigation_path: betriebsstatus
double_tap_action:
action: navigate
navigation_path: /lovelace/default_view
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
This applied the CSS before the card was shown, which is really fast.
So while this one is working âŠ
row: false
card:
type: button
tap_action:
action: navigate
double_tap_action:
action: navigate
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
card_mod:
style:
ha-card {
height: 220px !important;
restrictions:
confirm: null
pin:
code: 9999
retry_delay: 0
block: null
exemptions: null
âŠhere the CSS (height setting) is applied after the card is shown, which gives an ugly card for a second or two (depending on browser/device speed) until the card is resized.
So hereâs the question: how can I access the button card inside the restriction-card with the mod-card right from the beginning (to apply the height setting to the button card)? I was thinking of this, but it is not applied as it does not get down to the button-card. So a simple navigation thing is missing I guess :
style: |
ha-card {
card:
row: false
card:
type: button
tap_action:
action: navigate
double_tap_action:
action: navigate
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
restrictions:
confirm: null
pin:
code: 9999
retry_delay: 0
block: null
exemptions: null
In other words: how to get from mod-card down to button-card?
Thank you very much Ildar. I learned a bit again, quite complicated to understand how to navigate down to embeeded elements/cards.
Unfortunately, the end result applying the height this way is the same (small lag when loading the view, takes one second to resize the button), probably because itâs just another syntax/way (location) to apply the CSS, but the way it is applied is the same:
Load the view :
Wait a second until CSS is applied :
This was working very well without that glitch before using the restriction-card.
Not sure if that can be âfixedâ or worked around somehow?
Can it applied âbeforeâ the card is shown at all maybe?
Post your simplified code with the latest changes.
Check this:
type: grid
square: false
columns: 1
cards:
- type: markdown
content: xxxxxxxxxx
- type: grid
columns: 2
cards:
card:
<<: &ref_button
type: button
show_name: true
show_state: false
show_icon: true
card_mod:
style: |
ha-card {
aspect-ratio: 1/1;
- *ref_button
Zero glitches.
Sorry for late response. My glitch example is based on another view. This issue is not based on the initial/former height setting itself but the way it is applied in combination with restriction card (which now gives a delay when card-mod styles are applied). Hereâs the code:
- theme: Backend-selected
title: ABC
path: overview-domains
icon: mdi:vector-triangle
visible:
- user: abc
- user: xyz
layout:
grid-template-columns: 1fr 1fr 1fr 1fr 1fr 1fr
grid-template-rows: auto
mediaquery:
'(max-width: 650px)':
'(max-width: 1200px)':
'(max-width: 1600px)':
type: custom:grid-layout
badges: []
cards:
- type: custom:mod-card
style:
restriction-card $ div#card hui-button-card $: |
.type-button {
card:
row: false
card:
type: button
tap_action:
action: navigate
double_tap_action:
action: navigate
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
restrictions:
confirm: null
pin:
code: 9999
retry_delay: 0
block: null
exemptions:
- user: abc
- user: xyz
And with this exactly that happens:
Try to simplify the code - get rid of layout etc, see if the glitch happens with a single restriction card.
And why are you using âheight: xxxâ style? Earlier you said that the only reason to test with a height is a difference in heights between 2 buttons.
I did with a new view.
title: Test
path: test
visible:
- user: abc
badges: []
cards:
style:
.type-button {
card:
row: false
card:
type: button
tap_action:
action: navigate
double_tap_action:
action: navigate
hold_action:
action: none
show_name: true
show_state: false
show_icon: true
restrictions:
confirm: null
pin:
code: 9999
retry_delay: 0
block: null
exemptions:
- user: abc
- user: xyz
Same result, first the card is shownâŠ
âŠand after/within a second it gets updated (resized) to the final view (the look itself doesnât matter here, itâs just to show the difference and I canât provide a video of the animation/glitch itself):
Thatâs simple: Itâs another view, a slightly other use-case (still trying to merge the existing card-mod / mod-card base with restriction-card).
Is it possible to remove the header on a certain dashboard with the same theme or even change the theme for a specific dashboard?
Hi AhmadK
Have you found a way to use this (Icon-Hiding) for all entities in an entities-card without the need to write it for every entity?
type: entities
entities:
- entity: sensor.thermalcomfort_badgast_absolutehumidity
- entity: sensor.thermalcomfort_badgast_dewpoint
- entity: sensor.thermalcomfort_badgast_heatindex
- entity: sensor.thermalcomfort_badgast_simmerindex
- entity: sensor.thermalcomfort_badgast_simmerzone
- entity: sensor.thermalcomfort_badgast_perception
- entity: sensor.thermalcomfort_badbaga_absolutehumidity
- entity: sensor.thermalcomfort_badbaga_dewpoint
- entity: sensor.thermalcomfort_badbaga_heatindex
- entity: sensor.thermalcomfort_badbaga_simmerindex
- entity: sensor.thermalcomfort_badbaga_simmerzone
- entity: sensor.thermalcomfort_badbaga_perception
style:
hui-generic-entity-row:
state-badge {
display: none;
Can someone please tell me how to remove or change the plus icons of a grocery list? I donât know what to call it, Iâve tried right clicking and inspecting. I have card mod. Im using the OurGroceries Card, and trying to make i look as close to mushroom theme as possible.
hi can somone help me how to control the size of this grid cardâŠits soo big and even panel mode is false. i want it to look small . any way around with cardmod is it possible?
code:
square: false
columns: 1
type: grid
cards:
- square: true
columns: 3
type: grid
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_sleep
icon: mdi:television
show_state: false
hold_action:
action: call-service
service: script.remote_wakeup
data: {}
target: {}
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_arrow_up
icon: mdi:arrow-up
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.pressure_pump
icon: mdi:lightbulb-group-outline
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_arrow_left
icon: mdi:arrow-left
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_select
icon: mdi:checkbox-blank
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_arrow_right
icon: mdi:arrow-right
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_top_menu
icon: mdi:backburger
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_arrow_down
icon: mdi:arrow-down
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: script.remote_home
icon: mdi:home
card_mod: null
