I have a strange issue with the weather card. I canāt get the text in top part of the card to resize on my tablet. After applying styles, in a browser it shows fine but on my iPad when I refresh the dashboard it appears in the correct size for a split second but then gets resized back to the default size as if no styles have been added. It only seems to happen to the conditions and temperature text. All other text such as forecast resize without any issue. Anyone got any ideas?
Anyone know how to change the font size of the header section of ApexCharts?
I want to decrease the font size of those values (numbers) shown here. They are part of the header, which is part of HA, and not ApexChart. So, I think card-mod would be able to change that.
Hey,
Does installing card-mod makes the dachboard to load slowly/laggy?
thats what happend when i installed it, when i remove the integration everything go back to normal. any idea if this is normal or is there a way to fix it!
(even with no card mod styles it still makes dachboard laggy)
Can anyone help - I would like to change the padding at the top, but this seems to affect all of the padding, not just the top
Additionally, I am finding if I scale the badge, per here, the text on the label stays left aligned - is there any way to center it?
Actually, this is not exactly a padding ABOVE a badge - it is AROUND a badge.
The āpaddingā property accepts 1, 2, 3, 4 parameters to manage all 4 paddings separately - check CSS docs.
It was mentioned - āNote that the scaling does not change a nameās width.ā
Try combining with with styles for the ātitleā element.
Thanks - got the padding sorted but canāt seem to find how to do the label
I can see
--ha-label-badge-title-font-size: 7px;
--ha-label-badge-title-width: 48px;
mentioned above and they successfully work, but I see no mention of padding for the element
I tried
--ha-label-badge-title-padding
to no avail
Apologies if Iām missing something ā¦
Some styling may only be solved by a directs access to CSS properties, not by changing theme variables. May be this is your case. Open Code Inspector and experiment.
In inspector, if I make this change then the alignment does seem to automatically center (it changes some of the other padding too:
If I do
then it will also center it
What I donāt understand tho is how I get either of those added to my card code
type: custom:badge-card
badges:
- entity: person.vaderag
card_mod:
style: |
:host {
--label-badge-red: {% if is_state('person.vaderag', 'home') %} #5555FF {% else %} #df4c1e {% endif %};
--ha-label-badge-font-size: 28px;
This is how Iām doing it right now - how would i add that code?
Hello. Excuse my attempt to describe this. I donāt fully understand CSS or the terms to properly talk about it, but Iām hoping someone might be able to assist me with this. I have a vertical stack card configuration. At the top of the stack I have a template sensor. I made the font bigger with card mod but the font is clipped/cut off. I inspected the page and drilled down to get down to the div section where the text of my sensor exists. On the right side in the style tab there is an overflow property that when I unselect the sensor texts shows properly. So I suspect I need to somehow manipulate that with card mod but I am not having luck messing around with this.
I copied the JS path and used card mod helper to get this which is what I clicked through to get down to the sensor text. It shows the path but Iām at a loss on what to do next. Any assistance would be greatly appreciated. Thanks!
ā#view>hui-view>hui-masonry-view$#columns>div>hui-vertical-stack-card$#root>hui-glance-card$ha-card>div>div$divā
type: vertical-stack
cards:
- show_name: false
show_icon: false
show_state: true
type: glance
style: null
entities:
- entity: sensor.traffic_meter
state_color: false
card_mod:
style: |
ha-card {
font-size: 35px;
You basically have two choices, either make the card bigger or allow the overflow to show (e.g. let the text go outside of the boundaries of the div/card). Iād go with the former, so try to add height: 45px
to your code. If it doesnāt work, try with !important
trying so remove an entity completely from a glance card, to fake a fake card, I just learned instead of the 0px font-size, we can also use display: none;
card_mod:
style: |
state-badge {
display: none;
.name {
display: none;
:host div:not(.name) {
display: none;
the above is better than using
- entity: sun.sun
icon: ' '
show_state: false
tap_action:
action: none
because it actually removes the said properties, so the cursor doesnt respond to that.
maybe we can even hide the entity all together in a single mod, have to figure that out yet
Hi
Trying to change the background of my icon based on the state of the device .
I changed the color of the icon and the background but but not sure how to change itās icon background
Here is my code
card_mod:
style: |
ha-card {
background-color:{{'orange' if is_state('binary_sensor.XXX', 'on') else 'white'}};
--card-mod-icon-color: {{'white' if is_state('binary_sensor.XXX', 'on') else 'black'}};
--primary-text-color: {{'white' if is_state('binary_sensor.XXX', 'on') else 'black'}};
--secondary-text-color: {{'white' if is_state('binary_sensor.XXX', 'on') else 'grey'}};
this is what I have on some of my fans:
card_mod:
style:
div#wrapper: |
state-badge {
{% if is_state(config.entity,'on') %}
animation: rotation 2s linear infinite, colorize 5s linear forwards 1;
{% endif %}
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(360deg);
@keyframes colorize {
0% {
background: steelblue;
100% {
background: aquamarine;
Thanks but I have no idea how to use it
Isnāt there an attribute such as
ācard-mod-icon-background-color ?
this is how you use itā¦
you can strip all the animation and only use background in that template
card_mod:
style:
div#wrapper: |
state-badge {
{{'background: red' if states(config.entity) == 'off'
else 'background: green'}};
I should have mentioned I did try that and the box gets bigger but the font stays exactly the same.
Ok, so if I understand correctly, you donāt want the card to get bigger, but have the text fill it entirely, like in your screenshot?
If so, have you tried overflow: visible
trying to mod a glance cards border and use that card in a grid, there is the odd situation that using a border-top, simply add the height of the border to the picture-glance and takes the grid out of proportion.
I tried to make the top order be inline, but could not find the correct css for that. This does in fact create inline border, but only left and rightā¦
- type: picture-glance
entity: light.laundry_ceiling
state_filter:
'off': grayscale(72%)
image: /local/images/areas/bijkeuken.jpg
aspect_ratio: 100%
tap_action:
action: navigate
navigation_path: /ui-sub-views/bijkeuken
hold_action:
action: toggle
entities:
- entity: sensor.laundry_sensor_temperature
- entity: sensor.laundry_sensor_illuminance
card_mod:
style: |
ha-card {
border-inline: {{'medium solid red' if is_state('binary_sensor.laundry_sensor_motion','on')
else 'none'}};
would any of you modders around be able to help me out to either get the inline border on all sides, or only on the top border please?
thx
