šŸ”¹ Card-mod - Add css styles to any lovelace card
Trying to decrease line spacing on an entities card that is using custom:template-entity-row. The posted code_mod code works on entity cards with standard entities, but not when using custom:template-entity-row.
Update: Changing the two values below in the CSS code allows the line spacing to change, but can’t figure out how to accomplish this in card_mod.
#wrapper { min-height: 25px;} Changed from 40 to 25
div#wrapper { height: 25px;} Added this line
> type: entities
> entities:
>   - type: custom:template-entity-row
>     entity: binary_sensor.htpc
>     icon: mdi:server-network
>     state: >-
>       {% if is_state('binary_sensor.htpc', 'unavailable')%} Off {% else %}
>       {{states('binary_sensor.htpc') | capitalize}} {%endif%}
>     active: '{{ is_state("binary_sensor.htpc", "on") }}'
>     card_mod:
>       style: |
>         hui-generic-entity-row {
>           height: 25px;
>     entity: binary_sensor.xbox_360_media_center_extender_2
>     icon: mdi:microsoft-xbox
>     state: >-
>       {% if is_state('binary_sensor.xbox_360_media_center_extender_2',
>       {{states('binary_sensor.xbox_360_media_center_extender_2') | capitalize }}
>       {%endif%}
>     active: '{{ is_state("binary_sensor.xbox_360_media_center_extender_2", "on") }}'
>     card_mod:
>       style: |
>           height: 25px;
This code worked:
card_mod:
      style: |
        div#wrapper {
          min-height:  10px;
        div#wrapper {
          height:  25px;
I’m trying to use the browser variable but obviously I’m doing something wrong :slight_smile:
Anyone that knows how to use it?
      {% if browser == 'pixel7-app' %}
        top: 2px;
      {% else %}
        top: var(--header-height);
      {% endif %}
Hi there,
does anyone know how to disable the slider row of this entry equal to the date-input entry?
Actually only the icon will be disabled when I click the ā€œinput_boolean.ui_kellerlichtā€ button but it would be very nice if the slider also is disabled.
Thx. Spartacus
type: entities
title: 'minimale Einschaltdauer:'
entities:
  - entity: input_number.auto_kellerlicht_offset
    type: custom:slider-entity-row
card_mod:
  style:
      :host {
          {% if is_state('input_boolean.ui_kellerlicht','off') %}
            color: var(--disabled-text-color);
            --paper-item-icon-color: var(--disabled-text-color);
            pointer-events: none;
          {% endif %}
         --mdc-text-field-fill-color: transparent;
         --mdc-select-fill-color: transparent;
         --ha-card-header-font-size: 20px;
         --ha-card-header-color:  #C0C0C0;;
Hey lads, I have been trying to find a solution to a problem I’ve had since yesterday and it’s the fact that I cannot change the mushroom slider color. It doesn’t work with any selector that has anything to do with the slider. Anyone ran into this issue or know a solution?
Ps: I have used card-mod-helper but neither that worked.
- type: custom:mushroom-media-player-card
    entity: media_player.niels_tv
    use_media_info: true
    show_volume_level: true
    media_controls:
      - play_pause_stop
    volume_controls:
      - volume_mute
      - volume_set
    collapsible_controls: true
    tap_action:
      action: toggle
    fill_container: false
    card_mod:
      style: |
          mushroom-slider {
            --main-color: var(--google-blue) !important;
            --bg-color: rgba(61, 90, 254, 0.2) !important;
            # --shape-color: rgba(137, 179, 248, 0.2) !important;
This code worked:
card_mod:
      style: |
        div#wrapper {
          min-height:  10px;
        div#wrapper {
          height:  25px;
is there a way to style the horizontal stack so all child items (mini graph card state) have the same color?
For now i could only figure out to style all child items on its own. Is this possible?
  type: horizontal-stack
  cards:
    - type: custom:mini-graph-card
      style: |
        .states {
          color: #467fcf;
      entities:
        - sensor.adguard_home_dns_queries
      style: |
        .states {
          color: #467fcf;
      entities:
1st post → link at the bottom → mini-graph
this is what i have done. But my question is if i can put my card styling into the horizontal stack instead of styling every mini graph card on its own.
Your case was explained too.
horizontal vertical and grid stack can’t have css card-mod but you can use ā€œlayout-cardā€ instead perhaps
i swear it wasnt there the first 3 times i red this section. but i found it. thank you!
Was added long time ago (1…2 years), let’s call it a magic)))
Hi I am trying to style my lovelace card
Lovelace
I am trying for the lowest 4 boxes to change the format as well.
type: statistic
period:
  calendar:
    period: day
stat_type: change
icon: mdi:flash
icon_color: orange
entity: sensor.envoy_122125010596_lifetime_energy_production
unit: Wh
card_mod:
  style: |
    ha-card {
      font-size: 14px;
      text-color: rgb(var(rgb red));
Who can ppoint me in the right direction
I think your top cards are mushroom cards. I would also make the HASS lovelace cards with mushroom. It is a lot of work to base a normal lovelace card on it.
I think the best idea is to grab a custom:mushroom-template-card and style it.
Example:
- type: grid
  columns: 2
  square: false
  cards:
    primary: Dag
    icon: mdi:calendar-today
    icon_color: blue
    layout: horizontal
    secondary: |-
      {{ states('sensor.envoy_122125010596_lifetime_energy_production') }} Wh
    primary: Week
    icon: mdi:calendar-week
    icon_color: blue
    layout: horizontal
    secondary: |-
    primary: Maand
    icon: mdi:calendar-month
    icon_color: blue
    layout: horizontal
    secondary: |-
    primary: Jaar
    icon: mdi:calendar-blank-multiple
    icon_color: blue
    layout: horizontal
    secondary: |-
Edit: With this configuration it is necessary to create a helper sensor for the days, weeks, months and years. The helper is called utility meter, and is meant for this very purpose.
Thanks!
stats
SORRY now in english.
How Can i Change the values of the helpers. Now they start counting from teh moment i created them.
Would you guys mind writing in English? This is english forum and others would also like to understand your problems and solutions…thanks!
Sure, i am sorry for the dutch language
I am quite unsure, though I am very certain there is a way to set up a sensor or modify it in such a way that you’d be able to pull the right data. I can’t help you with that though as I have only been using HASS for the last 2 weeks and don’t know enough :sweat_smile:
