Staff19
(Francesco Staffieri)
March 14, 2023, 4:35pm
4459
Pease help me,I would like the cards to be of the same size and the title āConsumo Istantaneoā to be in the centre of that card, here is my code:
type: custom:mod-card
style:
hui-horizontal-stack-card$: |
#root {
margin: 15px !important;
card:
type: horizontal-stack
cards:
- type: weather-forecast
entity: weather.forecast_meteonetwork
show_current: true
show_forecast: false
secondary_info_attribute: humidity
- type: custom:button-card
entity: sensor.date
show_name: false
show_icon: false
show_state: true
styles:
grid:
- grid-template-areas: '"s" "ora" "event"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
state:
- justify-self: center
- align-self: center
custom_fields:
ora:
- font-weight: bold
event:
custom_fields:
ora: |
[[[ return `<span>${states['sensor.time'].state}</span>` ]]]
event: |
[[[ return `<span>Appuntamenti calendario</span>` ]]]
- type: custom:bar-card
title: Consumo Istantaneo
show_icon: true
max: 4100
positions:
indicator: inside
value: inside
unit_of_measurement: W
severity:
- color: '#1e90ff'
to: 3299
- color: Orange
to: 3500
- color: red
to: 4100
style: |
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 10px;
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--paper-item-icon-color: 'var(--text-primary-color';
--ha-card-box-shadow: 'none';
ha-card .card-header .name {
text-align: center;
entities:
- entity: sensor.sensore_potenza_casa_w
Try to simplify the issue - get rid of card-mod for embedded cards & other complex code and concentrate on these 2 tasks. You are asking for a help a posting a code with lots of unrelated details.
Staff19
March 14, 2023, 5:01pm
4461
i need this, i donāt know how to explain it
For bar-card - here is how to center a title:
title: title
entities:
- entity: sensor.processor_use
card_mod:
style:
.card-header {
text-align: center;
As for button-card - probably better to ask in the button-card thread.
Staff19
March 14, 2023, 5:39pm
4463
Thanks but it doesnāt work for me, maybe i need to change the rest of the css code. Iāll try asking in the button-card thread.
Staff19:
What does not work?
Styling for bar-card works.
But if you already have some styling for bar-card - you need to COMBINE your & new styles (1st post ā link at the bottom ā other articles ā navigation hints).
This is not related to button-card. For the button you only need to find out how to adjust itās height to the stack.
ztorm
March 17, 2023, 9:09am
4465
Iām trying to figure this out as well. Could you show your whole card_mod config for the active tab color?
Thanks in advance!
kbrown01
(Kbrown01)
March 17, 2023, 5:11pm
4466
@ztorm Key is CSS for āactiveā ā¦ mwc-tab[active]
Here ya go:
- type: custom:mod-card
card_mod:
style:
tabbed-card $: |
mwc-tab {
background: var(--ha-card-background, var(--card-background-color, white) );
border-color: var(--ha-card-border-color, var(--divider-color, #e0e0e0) );
border-width: 2px;
border-top-left-radius: 20px;
border-top-right-radius: 20px;
border-style: solid;
overflow: hidden;
width: 25%;
mwc-tab[active] {
background: #EBFFD8 !important;
card:
type: custom:tabbed-card
Results showing MLB->Standings->Divisional are the selected tabs.
yesterday, finally found the easiest (?) way of spreading some entities in a glance card, and use the width better.
I use this inside an entities card, so thats why the hui-element is used, and the default mod for setting the margin and eliminating box shadow. Its the second mod for padding that makes it happen:
- type: custom:hui-element
card_type: glance
card_mod:
style: |
ha-card {
margin: 0px -16px -16px -16px;
box-shadow: none;
ha-card .entities {
padding: 0px;
resulting in:
opposed to:
which feels so much more restricted.
Itās remarkable HA Frontend does this with entities, because eg when using a grid with mushroom cards there, it simply adjust to the available space
card_mod:
style: |
ha-card {
card:
type: grid
columns: 5
cards:
in fact, I had these both in my card, and that was why I noticedā¦
i couldnāt find this simple mod in the posts above for Glance, so thought to add here.
moving from š¹ Card-mod - Super-charge your themes! - #1331 by Ildar_Gabdullin
looking for a way to change the icon of button in an entities card footer
consisting of these:
footer:
type: buttons
entities:
- entity: input_boolean.loop_sound_bite
name: Loop Soundbite
- entity: script.play_sound_bite
name: Speel soundbite
icon: mdi:play
and suggested generic mod is:
card_mod:
style:
hui-buttons-header-footer $ hui-buttons-base $ .ha-scrollbar:
ha-chip:
.mdc-chip {
border: 1px solid red !important;
border-radius: 4px !important;
ha-chip:nth-child(3) {
{% if is_state('input_boolean.test_boolean','on') %}
--ha-chip-background-color: lightgreen;
{% else %}
--ha-chip-background-color: cyan;
{% endif %}
I dont need the first section, as my buttons are modded/styled in the card-mod-theme already, only need the icon to change.
compare a custom:button-card config like
card_type: horizontal-stack
cards:
entity: input_boolean.loop_tune
<<: &style_boolean
show_name: false
show_label: true
label: >
[[[ var loop = (entity.state === 'on') ? 'Aan' : 'Uit';
return 'Loop: ' + loop; ]]]
aspect_ratio: 4/1
icon: >
[[[ return (entity.state === 'on') ? 'mdi:restart' : 'mdi:restart-off'; ]]]
styles:
icon:
- color: >
[[[ return (entity.state === 'on') ? 'green' : 'var(--text-color)'; ]]]
card_mod:
style: |
ha-card {
box-shadow: none;
entity: script.play_tune
<<: &style_script
show_name: false
show_label: true
label: >
[[[ return (entity.state === 'on') ? 'Stop' : 'Speel'; ]]]
aspect_ratio: 4/1
icon: >
[[[ return (entity.state === 'on') ? 'mdi:stop' : 'mdi:play' ]]]
styles:
card:
- box-shadow: none
icon:
- color: >
[[[ return (entity.state === 'on') ? 'red' : 'var(--text-color)'; ]]]
tap_action:
action: call-service
service: script.toggle
service_data:
entity_id: entity
haptic: light
hold_action:
action: more-info
haptic: light
ā¦
Styling buttons-row in a footer (+ dependently on a state)
Similarly to buttons-row in Entities card :
code
type: entities
title: footer
entities:
- input_boolean.test_boolean
footer:
type: buttons
entities:
- entity: sun.sun
show_name: true
show_icon: true
- entity: sun.sun
show_name: true
show_icon: true
- entity: input_boolean.test_boolean
show_name: true
show_icon: true
- entity: sun.sun
show_name: true
show_icon: true
card_mod:
style:
hui-buttons-header-footer $ hui-buttons-base $: |
ha-assist-chip:nth-child(3) {
--ha-assist-chip-filled-container-color: lightgreen;
{% else %}
--ha-assist-chip-filled-container-color: cyan;
{% endif %}
border: 1px solid red;
border-radius: 4px;
before 2023.12
card_mod:
style:
ha-chip:
.mdc-chip {
--card-mod-icon: mdi:card;
{% else %}
--card-mod-icon: mdi:account;
{% endif %}
card itself
type: entities
title: footer
entities:
footer:
type: buttons
entities:
- entity: sun.sun
show_name: true
show_icon: true
show_name: true
show_icon: true
show_name: true
show_icon: true
- entity: sun.sun
show_name: true
show_icon: true
I really dislike these nth-child mods, they are so fragile. add/remove an item and its broken
ā¦ I had hoped to set a mod directly on the entity itself
You cannot style a button inside a button I guess.
Ildar_Gabdullin:
card_mod:
style:
ha-chip:
.mdc-chip {
{% else %}
{% endif %}
can confirm
- type: entities
title: Soundbites
card_mod:
class: class-header-margin
style:
ha-chip:
ha-chip:nth-child(2) {
{% if is_state('script.play_sound_bite','on') %}
--card-mod-icon: mdi:stop;
{% else %}
--card-mod-icon: mdi:play;
{% endif %}
to work ok!
can we also touch the name? Like I did in the label of the button-card?
btw, inspector reveals some really odd texts:
including the tap and hold action inside the title?
better use config-template-card
Fifthy
(P.Hill)
March 18, 2023, 3:14pm
4474
I canāt figure this one out, any help would be greatly appreciated.
yeah, probably.
well, Iāll leave it with the button icon for now. this getting way too complicated for such a small detail in the interface, trying to fix the inflexibility of core Frontend (lack of) options.
If I need more, I guess I just have to fall back to use custom:button-card.
Tarcisio
(Tarcisio Alves de Menezes)
March 18, 2023, 3:43pm
4476
Hello my friend! Did you find a solution for that??
I saw your post on GitHubā¦
Thank you!!
vertical-stack needs a custom:mod-card
to do things like:
card_mod:
style: |
ha-card {
margin: -16px;
box-shadow: none:
:host {
--stack-card-margin: 0px;
card:
type: vertical-stack
did you try that?
Fifthy
(P.Hill)
March 18, 2023, 4:13pm
4478
Unfortunetly it didnāt work, this is my code with your suggestion.
card_mod:
style: |
.card-header {
padding: 6px 16px 2px !important;
card:
