andy_mk3
(andy)
June 24, 2023, 7:31pm
4857
Can anyone please help me to increase the font size for the Mushroom Thermostat card temperature control?
type: custom:mushroom-climate-card
entity: climate.bedroom_ac
layout: vertical
show_temperature_control: true
secondary_info: none
tap_action:
action: call-service
service: switch.toggle
entity_id: switch.bedroom_ac_toggle
data: {}
icon: mdi:snowflake
collapsible_controls: false
hvac_modes: []
fill_container: false
card_mod:
style: |
ha-card {
--card-primary-font-size: 1.6em;
Any help would be greatly appreciated.
Hi all!
I have a vertical-stack with a media-control card and a custom-button card. I have modified the size of the button so that it does not occupy the entire width of the column and my ultimate goal is to place the button on top of the control-card and align it after the next track button.
Below I show my code.
- type: custom:mod-card
card:
type: vertical-stack
card-mod:
style: |
ha-card {
display: flex;
justify-content: center;
cards:
- type: media-control
entity: media_player.musiccast_kitchen
- type: custom:button-card
icon: mdi:link-variant
styles:
card:
- width: 50px
- height: 50px
- position: relative
- transform: translate(100px, -100px)
The problem is that depending on the screen (mobile, tablet…) the relative position of the button with respect to the media-control card varies.
Is there a way to make this not happen?
If it’s not possible, how can I at least make the button appear centered in the column?
I’m totally new to card-mod, so I’d appreciate if someone could help me.
Start with fixing this:
When using mod-card - styles are supposed to be defined on mod-card level.
spunkt123
(Spunkt123)
June 26, 2023, 9:08am
4860
I would like to change the style “–grid-card-column-count” of a hui-grid-card.
<hui-grid-card style="--grid-card-column-count: 2;"></hui-grid-card>
I tried the following - but it does not work
type: grid
card_mod:
style:
hui-grid-card$: |
hui-grid-card {
--grid-card-column-count: {{ 1 if user == 'handy' else 2 }} !important;
Could please someone help?
Hi everyone,
I’ve noticed that the newer HA updates have added a box around my once boxless/shadowless card:
I can’t seem to figure out how to remove it.
I’ve tried:
ha-card-border: 0px
ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
ha-card-border-width: 0
with no luck.
Am I missing anything in the below code?:
card:
type: custom:mushroom-title-card
title: '{{ now().strftime(''%I'') }}:{{ now().strftime(''%M %p'') | lower }}'
subtitle: >-
{{ now().strftime('%A') }}, {{ now().strftime('%B') }} {{
now().strftime('%d') }}
card_mod:
style:
mushroom-title-card$: |
.header {
--title-padding: 12px 12px 3px;
.title {
font-size: 34px!important;
spacing: 100px;
.subtitle {
font-size: 25px!important;
ha-card {
height: 98px !important;
ha-card-border: 0px
Thanks in advance
spunkt123:
hui-grid-card.
Same as for the stack cards. Have a look in the developer tools of your browser. There is no ha-card element, which is needed for ingesting code via card-mod. So you have to place a mod-card around it here as well. See here .
Thanks for pointing me in the right direction. I have put the styles on mod-card level and tried to apply the style only for the custom:button-card but the code doesn’t work. Surely because the selector is not correct.
Please, could you tell me what I’m doing wrong.
card:
cards:
icon: mdi:link
card_mod:
style:
ha-card $:
hui-vertical-stack-card $:
div#root button-card$:
div#aspect-ratio ha-card: |
.button-card-main {
position: relative;
display: block;
margin: auto;
width: 60%;
Path must be defined in accordance to Code Inspector.
card:
cards:
entity: media_player.kodi_rpi_1
card_mod:
style:
hui-vertical-stack-card $ div#root button-card $: |
div#aspect-ratio .button-card-main {
Thank you very much for your help, the truth is that I am having a hard time understanding how to build the selector.
I have a question, why the selector you have indicated works and the following doesn’t?
hui-vertical-stack-card $ div#root button-card $ div#aspect-ratio: |
.button-card-main {
¯\_(ツ)_/¯
probably because this is how card-mod works)))
Sorry if my questions are too basic but, what means when you put div#aspect-ratio
in the next line? I am not supposed to follow the objects in the code Inspector?
Frankly speaking, from my experience I do not expect some 100% predicted behaviour.
Sometimes I need to do this:
xxx $:
xxx $: |
xxx {...}
sometimes it does not work and I have to do this:
xxx $ xxx $: |
xxx {...}
Next, instead of this:
xxx $ xxx $ xxx: |
xxx {...}
I usually use this:
xxx $ xxx $: |
xxx xxx {...}
but may be in some cases the upper variant can work, I am not sure ))).
Experiment!
Basically what Ildar said, but to add on a bit:
What you need to understand is that after the |
the CSS that follows will go into a <card-mod>
element inside the last element you navigated to with the part before the |
My guess here (without seeing the HTML) is that the .button-card-main
class sits on that last div
so you can’t apply the style inside it — it’s a done deal by that point. You must go up one level.
Also, that div
selector targets specifically a div
with ID #aspect-ratio
to disambiguate it from other divs there possibly might be at the same level.
The least frustrating approach for me to do things with card-mod is to add or change the CSS in a live page until I get what I want and then backwards to figure out how I must configure it.
Is there a way to make mushroom chip cards transparent? I can make other mushroom cards transparent with card mod using the following but it doesn’t work with chip cards
card_mod:
style: |
ha-card {
--paper-card-background-color: transparent;
--secondary-background-color: transparent;
background: transparent;
border: transparent;
box-shadow: none
Hi, I need some help with a conditional card that I need to configure with a max width.
type: conditional
conditions:
- entity: input_boolean.mail_to_collect
state: 'on'
card:
type: custom:mushroom-template-card
icon: mdi:mailbox
primary: Hay Cartas
content_info: name
icon_color: red
badge_icon: mdi:email
badge_color: red
tap_action:
action: more-info
card_mod:
style: |
:host {
max-width: 120px;
card_mod:
style: |
hui-conditional-card {
max-width: 5px;
hui-conditional-card:first-child {
max-width: 120px;
:host {
--column-max-width: 120px;
max-width: 120px;
#root {
max-width: 120px;
Could you help me, please? I want to configure the conditional card with a max width of 120 px.
type: custom:mushroom-chips-card
chips:
- type: menu
- type: back
- type: entity
- type: spacer
- type: light
entity: light.yeelight_lamp
- type: spacer
card_mod:
style: |
ha-card {
--chip-background: red; #in your case --chip-background: none;
--chip-border-width:0px;
--chip-box-shadow: none;
For mushroom card all, what you need is here:
Mushroom Cards - Build a beautiful dashboard easily - Share your Projects! - Home Assistant Community (home-assistant.io)
for example
You can with some simple CSS. This puts an image in the background of the template Chip. the image needs to be 36px square.
[chip]
chips:
- type: template
card_mod:
style: |
ha-card {
--chip-background: url( '/local/ls50.jpg' ) no-repeat center center;
- type: template
icon: mdi:speaker
guensen0
(Guensen0)
June 29, 2023, 6:45am
4874
your code is working, but not this one:
card:
show_name: true
show_icon: true
show_state: false
type: glance
style:
.entitiy:
state-badge {
margin: 0px !important;
background: pink;
margin-top: 0px;
margin-bottom: 0px;
columns: 24
state_color: false
card_mod:
style: |
ha-card {
background: rgb(0,0,0,0) !important;
.entity {
border-left: 0.1em solid #aaaaaa;
.entity:nth-of-type(24) {
border-right: 0.1em solid #aaaaaa;
{%- for i in range(1,25) -%}
.entity:nth-of-type({{i}}) {
padding: 0 0 7em;
margin: 0 0 7em;
{% endfor %}
card_param: entities
filter:
include:
- entity_id: sensor.forecast_new_h*
exclude: null
sort:
method: entity_id
numeric: true
show_empty: true
view_layout:
grid-area: header```
guensen0
(Guensen0)
June 29, 2023, 6:46am
4875
I cannot get rid of the margin in my code… could you help?
card:
show_name: true
show_icon: true
show_state: false
type: glance
style:
.entitiy:
state-badge {
background: pink;
margin-top: 0px;
margin-bottom: 0px;
columns: 24
state_color: false
card_mod:
style: |
ha-card {
.entity {
padding: 0 0 7em;
margin: 0 0 7em;
{% endfor %}
filter:
include:
exclude: null
sort:
method: entity_id
numeric: true
show_empty: true
view_layout:
KTibow
(Kendell R)
June 29, 2023, 1:52pm
4876
I can’t easily reproduce that card so I can’t help you beyond telling you that you misspelled entity.
