Hereās an example. The alignment is needed when displayed in the mobile app. If I didnāt pull them closer to each other, Iād have to reduce the font size very muchā¦
Can you show, what you have tried? As the direct assignment is already working?
- type: picture-elements
image: /local/model_3_grey_wide.png
elements:
- type: state-icon
entity: binary_sensor.asleep
icon: mdi:sleep
style:
top: 1%
left: 1%
transform: none
card_mod:
style: |
state-badge { color: red; }
You can remove the margin-left of the second value:
card_mod:
style: |
.states.flex .state .state__value.ellipsis {
font-size: 21px;
align-self: center;
.states--secondary {
margin-left: 0px !important;
And BTW, there was a {} problem in your css above, too.
Thanks for the reply!
Unfortunately that code isnāt working⦠hmm⦠has there been a super-recent change to card mod or HA that would influence this? Iām running HA 2023.6.3, and the card_mod release from 4th of April on github.
I donāt have the exact code Iāve tried, but Iāve tried modifying var(--state-binary_sensor-active-color);, various --paper-icon-XXXX options, various :host {} options, and also some ha-card {} options.
Given that your suggestion above isnāt working for me, perhaps thatās pointing towards the true problem here.
Any ideas? What versions are you running?
(Thank you again for your reply
Thankyou, without me knowing how to identify those elements, Iāll take the question over to the mushroom topic.
This is, because every sensor class can build the DOM and color it in another way. Try this, because it is one level deeper and most probably more secure.
- type: state-icon
entity: sun.sun
icon: mdi:sleep
style:
top: 1%
left: 1%
transform: none
card_mod:
style:
state-badge:
ha-state-icon { color: red !important; }
And as for alexeiw123, just try to avoid manipulating the variables, which are used and set the colors directly to the element.
Thank you!
For anyone else in my boat, this solution works for non-conditional state-icon within picture-elements.
Conditional ones, however, donāt seem to work. Iāve spent an hour reading the underlying CSS/html but I donāt seem to understand why they should be any different
Thanks again
Where did you wrote before, that the requirement is a conditional one?
Anyway. Try invest you hours in looking, where the difference is and adjust then the examples accordingly. Here you can directly see, that with a conditional element, the element is just one level deeper.
- type: conditional
conditions:
- entity: sun.sun
state: above_horizon
elements:
- type: state-icon
entity: sun.sun
icon: mdi:sleep
style:
top: 1%
left: 1%
transform: none
card_mod:
style:
hui-state-icon-element:
state-badge:
Above with condition, below without
Any chance of some help here.
Iām trying to add a background colour to this column on the left. any idea how i would code card-mod for this?
Put a mod-card above/around the stack card and mod from there. the ha stack-card donāt have an ha-card element and canāt be modded without mod-card.
Can I not just access the hui-vertical-stack-card selector (highlighted area in the image)? The css in lovelace is baffling.
Iām reluctant to wrap the whole thing in a mod card as this breaks the GUI editing doesnāt it?
Not via card_mod in the card(s). Only when you are modding via card-mod-theme. But I would not recommend, because of different disadventages in loading order, etc.
So either this or mod-.card or custom stack cards like custom:vertical-stack-in-card
Has anyone noticed that since HA 2023.4.x card mod behaves very erratically? I need to style some mini-graph cards so that the temperature info is correctly visible on the mobile client.
Example card config:
type: custom:mini-graph-card
entities:
- entity: sensor.average_mi_bath_temperature
line_color: darkorange
card_mod:
style: |
font-size: 23px;
align-self: center;
However, ever since 2023.4.x when I open the mobile client the card mod styling is not applied at first. I have to exit the app and re-launch it (sometimes multiple times). i can also see the lack of styling on a desktop browser, where I need to refresh the page sometimes 2-3 times to see the correct styling.
Example - when opening the app:
Example - after closing and re-launching the app a few times (correct styling):
Since the github repo hasnāt been updated for months now, is there a fork that has maybe fixed this with newer HA versions? Thanks in advance!
Thank you kind sir!
(I never mentioned the requirement was conditional because it wasnāt to begin! Iāve been playing around with the cards and testing things and noticed this afterwards)
Appreciate your help. I hope it helps others as well
Sorry - Iām not sure that I get what you mean with the link??
I obviously have card-mod installed and Iām using it to style many elements, but I specifically needed to style the whole column on the left of the display.
I think he only want to show, what I have written already. No ha-card-element (as in build in stack cards), no direct card-mod. Only via card-mod theme, mod-card-wrapper or custom stack cards.
I posted it because youāre reluctant to follow the correct advice given to you ā so that you can see for yourself what the docs says.
Although I have no issues with styling mini-graph-card, I will ask anyway - why do you not use a native āfont-sizeā option of mini-graph-card?
Iām also styling some of them differently
, so i did both with card mod. I want to have a different colored borders based on certain conditions - on this, red if the heating is on, and white if the windows is open:
entities:
- entity: sensor.average_mi_office_temperature
line_color: darkred
card_mod:
style: |
ha-card {
border:
{% set sensor = states('input_boolean.office_temp_vs_heating_set_point') %}
{% set sensor2 = states('binary_sensor.office_window_sensor_contact') %}
{% if sensor == 'off' and sensor2 == 'off' %}
{% elif sensor == 'on' and sensor2 == 'off' %}solid 3px red
{% elif sensor == 'off' and sensor2 == 'on' %}solid 3px white
{% else %}solid 1px var(--ha-card-border-color,var(--divider-color,#e0e0e0))
{% endif %}
font-size: 23px;
align-self: center;
And the same can happen - Often the borders are not shown, and I have to refresh the page in the desktop app (or exit/relaunch the app) to have them show up, along with the reduced font size.
Now, the āifā statements might not be 100% neat, but they used to work perfectly before 2023.4 - and the frontend changes in HA.
