I have the minimalist theme and I use the ācustom:time-picker-cardā
How can I change the font of the card so it matches the theme ?
Where can I find the font used ? and where can I correct it for the custom:time-picker-card ?
the only checker you need for you jinja templates is the dev tools/template
did you test it there?, because that syntax is really not compliantā¦ (and that is a very friendly understatementā¦)
card_mod:
style: |
ha-card {
--primary-color:
{{'red' if now() - states('sensor.russ_s_echo_spot_next_timer') | int(0) <= 10 else 'blue' }};
--dark-primary-color: white;
background: none;
this would be proper syntax. though, I am not correcting you invalid comparison on the timer itself, because that wil throw a type error
Thanks, Iām still learning and yes I tried it in Dev/Template this is failing because I donāt have the
Part down yet, and thanks again for very friendly understatement, Iāll keep on trying!
Can someone please help me change the font color of the Play Movie Button. I tried doing inspect element. I was able to change the color toggling the checkmarks in my browser, but cantā get the code right.
type: custom:stack-in-card
cards:
- type: entities
entities:
- entity: input_text.plex
type: custom:text-input-row
card_mod:
style: |
ha-card {
margin: 0px -6px 10px -6px;
- type: entities
entities:
- type: call-service
icon: mdi:plex
action_name: Play Movie
service: script.plex_stream_living
card_mod:
style: |
ha-card {
--card-mod-icon-color: grey;
--card-mod-button: grey;
padding: 0px 10px 0px 0px;
margin: -30px 0px -10px 0px;
mwc-button.text {
color: red;
1st post - link at the bottom - entities
But your code for Entities is wrong.
Iāve looked through that doc as well, and cant figure it out. Itās been plenty helpful for me with other things. I just canāt find this part.
Also what do you mean that itās wrong? I only ask because it plays plex movies just find upon click the play movie button after I type something in.
Cannot point exactly since answering from phone.
Open docs for Entities; find ātype: buttonĀ» row.
As for card- mod. Open styles fir Entities card as was suggested, find styles for button row.
You can test if all is well by replacing the now() by a number . Letās say first use 1 and next use 20.
Something that allows you to check the dynamic timer being either smaller or bigger .
If that works all you have to do is figure out what you really want in the template because now u are comparing a date time with a number and that is not very useful
I got it working. Finally found it in that first link
Thank you
Guru Ildar, do you know how to make this cool additional info work for custom:slider-entity-row
I thought it should be something like
card_mod:
style:
hui-generic-entity-row $: |
.span.state::after { #also tried.div::after
content: " ("{{state_attr(config.entity,'elevation')}}")";
color: magenta;
/html/body/home-assistant//hui-dialog-edit-card//ha-dialog/div[1]/div[2]/hui-card-preview/auto-entities/hui-entities-card//ha-card/div/div[1]/slider-entity-row//hui-generic-entity-row/div/span
Hey.
Need some expert help here. Had two things working but now with latest update in went sideways.
Background-image is set in themes.yaml
Should look like this:
content: |
# HA Network
style:
ha-markdown:
ha-card {
background-color: transparent !important;
box-shadow: none !important;
border: none;
h1 {
font-size: 25px;
# font-weight: bold;
text-align: center;
letter-spacing: '-0.01em';
type: markdown
columns: 3
entities:
- entity: binary_sensor.zigbee2mqtt_running
- entity: binary_sensor.z_wave_js_running
- entity: binary_sensor.node_red_running
- entity: binary_sensor.esphome_running
- entity: binary_sensor.grafana_running
- entity: binary_sensor.home_assistant_google_drive_backup_running
show_name: false
style: |
ha-card {
--ha-card-background: rgba(50,50,50,0.0);
background-repeat: no-repeat;
background-size: 100% 100%;
border: solid 2px rgba(100,100,100,0.5);
border-radius: 20px;
box-shadow: 3px 3px rgba(0,0,0,0.4);
overflow: hidden;
type: glance
How do I correct theese codes?
Thanks.
Didnāt have that deep look into you problem, but did you update recently to the new card-mod version? If ye, you might have missed the change.
Whereas you should have used it in the past already. It was outdated for years.
Yes, I saw this and tried but must have been a typo somewhere. Now its working again. =)
THANKS.
Well, sometimes I forget to read the instructions.
How would I add a horizontal divider with card-mod only? thanks
on the update to card-mod to 3.4.0, does anyone else see this:
happening for fold-entity-rowā¦ which is by the same author
happening on all
card_mod:
style: |
.label {
margin-left: 0px !important;
which would still be the correct mod, and not affected by the new dom path changes in the 3.4.0 update?
What is this in āsee thisā?
It was the new 3.4.0 logging an issue with another card. Fold-entity-row.
I believe Thomas has already fixed it
Yes, I can confirm the āissueā is fixed in v 3.4.1
This is probably basic for the experts here, but Iām struggling to find an example.
badge_icon: mdi:motion-sensor
badge_color: >-
{{ iif(is_state('binary_sensor.presence_sensor_living_room_presence', 'on'),
'blue', '') }}
card_mod:
style: |
mushroom-badge-icon:before {
content: 'sensor_door';
font-size: 0.9em;
font-family: 'Material Icons';
position: absolute;
display: flex;
justify-content: center;
align-items: center;
right: 32px;
width: var(--mush-badge-size, 16px);
height: var(--mush-badge-size, 16px);
border-radius: var(--mush-badge-border-radius, 50%);
Iām trying to add a second badge to this mushroom-template-card. It works, but the suggested āMaterial Iconsā used as font are too limited. Iād like to use the typical mdi from HA. AFAIK theyāre icons, not a font, so I cannot use them as content in CSS.
Instead of Material Icons sensor_door
Iād like to use mdi:door-open
, for example.
But I should be able to use them as background image? Not sure about the syntax or anything tbh. My tests have not resulted.
Many thanks!
I dont believe that is possible to use an mdi as a background.
But have you tried the door_open
google mdi?
Its certainly a lot closer to the existing mdi:door-open
than what you currently have.
EDIT: Might be possible if you have the svg values for the icon you want to use.
