šŸ”¹ Card-mod - Add css styles to any lovelace card
You are right. This was only to help him understand the DOM navigation.
And with the refresh you are right as well, but this is happeing only in some cases of loading order, etc. MY way is to go as detailed as possible and go only more general, if there are problems as described by you.
Although your question was to Arganto, I will answer:
  1. A ā€œlevels codeā€ could be more clear for ā€œbeginnersā€. Most of my examples from ā€œ1st post → link at the bottomā€ are like this ā€œnot optimizedā€.
  2. But there is also some info from Thomas in his repo & my hints as well (ā€œother stuffā€ section) exactly about navigation & optimization. Let’s say this is for ā€œadvanced usersā€.
https://matt8707.github.io/card-mod-helper/
Hi There, can anyone please assist with why the spacing has changed since the Dec HA update? I have everything updated including card_mod via HACS. Before and after plus code :slight_smile:
here is a great helper from Mattias
you have the wrong indentation…
card_mod: null
style: |
  ha-card {
use this
  card_mod:
    style: |
      ha-card {
Hey everyone,
I paused working on my dashboard for nearly 3 months now. After I installed missing updates for HA and the frontend modules I noticed that the styling for ā€œhui-elementā€-cards are not working anymore.
Did something change besides starting with ā€œcard_mod:ā€ and then adding the styles?
These lines used to work but are not anymore:
          - type: custom:hui-element
            card_type: custom:mushroom-template-card
            icon: mdi:arrow-left
            icon_color: white
            tap_action:
              action: navigate
              navigation_path: /dashboard-test/2
            card_mod:
              style: |
                ha-card: {
                  padding: 0px;
                  --icon-size: 800px;
                  height: 50px;
                  width: 50px;
                  --mush-chip-icon-size: 80px;
                :host {
                  left: 50px;
                  top:  35px;
                  --icon-color: white;
                  --icon-animation: none;
                  --shape-color: none;
                  --shape-color-disabled: rgba(var(--rgb-disabled), 0.2);
                  --shape-animation: none;
                  --shape-outline-color: transparent;
what for do you need to wrap a custom card into hui-element?
Also, hui-element do not have ha-card.
Thanks for the advice. I fixed that, just some copy paste issue.
As it seems are the style elements now different. I never noticed the ā€œ.elementā€ and ā€œelement.styleā€.
I am wrapping elements into a picture elements card to freely move my cards around. So I need the hui-element to make them work and the left, right, top commands to move them around.
But I have no clue how to find out where to put the values now. Any quick tip?
Fixed what? Custom card inside hui-element (there is no sense to do it)?
That’s what I meant by fixing. It is no hui-element anymore.
If you really want to be helped - then consider helping people to help you.
In this particular case suggest to post the FINAL code w/o any already fixed errors with which (i.e. code) you have some issues.
Hi! I’m really interesting in ajdusting slider thickness as described in your post. I’m curious if you successfully got the correct code working?
And for @Stefan2 as well.
I did it and this is my code
      card_mod:
        style:
          hui-card-features$:
            hui-cover-position-card-feature$: |
              ha-control-slider {
                --control-slider-thickness: 20px !important;
If you want to adjust the button as well, add:
            hui-cover-open-close-card-feature$: |
              ha-control-button-group {
                --control-button-group-thickness: 20px !important;
As a result:
And on my mobile phone:
Read somewhere that I should use em instead of px, better on mobile but I’m happy with my result.
This is exactly what I’m looking for! I have tried the code string on different levels, but can’t get it working. Do you see what’s wrong?
hui-cover-position-card-feature is because it is a cover.
you probably have to replace that part with something related to light
I see on you screenshot
hui-light-brightness-card-feature
Thanks for helping! I got it working! Cheers!
I’ve gone through the last few weeks of posts and noticed that quite a few people have noticed that there have been elements that have stopped working since the most recent updates. Like many others, I’ve updated to card-mod 3.4.0 & 3.4.1 (along with HA 2024.1)
I have previously had a bunch of glance cards inside a vertical stack in card that were too high for my tablet due to the excessive spacing, so to combat this I have used card-mod to reduce the spacing/margins using the following code:
type: custom:vertical-stack-in-card
view_layout:
  column: 2
cards:
  - type: glance
    card_mod:
      style:
        .entities:
          .entity:
              state-badge {
                margin-top: 20px;
                margin-bottom: -5px;
              .name {
                margin-top: 0px !important;
                margin-bottom: -10px !important;
              div:not(.name) {
                margin-bottom: 0px !important;
    entities:
      - entity: camera.frontroad
        show_state: false
      - entity: camera.frontdoor
        show_state: false
      - entity: camera.frontdriveway
        show_state: false
  - type: glance
    show_name: false
    card_mod:
      style:
        .entities:
          .entity:
              state-badge {
                margin-top: -20px;
                margin-bottom: 0px;
              .name {
              div:not(.name) {
    entities:
      - entity: binary_sensor.frontroad_person_occupancy
        show_name: false
        show_last_changed: true
      - entity: binary_sensor.frontdoor_person_occupancy
        show_name: false
      - entity: binary_sensor.frontdriveway_person_occupancy
        show_name: false
  - type: glance
    card_mod:
      style:
        .entities:
          .entity:
              state-badge {
                margin-top: 20px;
                margin-bottom: 0px;
              .name {
              div:not(.name) {
    entities:
      - entity: camera.garage
        show_state: false
      - entity: camera.sidegarage
        show_state: false
      - entity: camera.backdoor
        show_state: false
      - entity: camera.backyard
        show_state: false
  - type: glance
    show_name: false
    card_mod:
      style:
        .entities:
          .entity:
              state-badge {
                margin-top: -20px;
                margin-bottom: 0px;
              .name {
              div:not(.name) {
    entities:
      - entity: binary_sensor.garage_person_occupancy
        show_name: false
      - entity: binary_sensor.sidegarage_person_occupancy
        show_name: false
      - entity: binary_sensor.backdoor_person_occupancy
        show_name: false
      - entity: binary_sensor.backyard_person_occupancy
        show_name: false
This resulted in this card:
2024-01-08-78b
However, the problem now, is that when HA automatically updates the cards, it changes the spacing and removes those reduced margins and I end up with this instead after a few seconds:
2024-01-08-77b
I hope the explanation makes sense and someone can see something obvious I am missing or have done incorrectly.
Likewise, I am happy for feedback if there is an easier/better way to achieve the same result. Thanks :slight_smile:
I used to have a card that blinked, but none of the CSS seems to work anymore.
card:
entity: sensor.dagen_papier
default: 0
states:
  '1':
    type: custom:mushroom-entity-card
    layout: horizontal
    icon_type: entity-picture
    hide_state: true
    style: |
      ha-card {
        border-radius: 12px;
        box-shadow: 0 4px 6px 0 rgba(0,0,0,0.2);
        --card-primary-font-size: 35px !important;
        animation: blink 1s 4;
        text-align: center;
        padding: 15px;
        background-color: var(--card-background-color);
      @keyframes blink {
        50% {
          background-color: var(--primary-color);
what could I be doing wrong? it worked fine for months.
I need help!
Repository ā€˜thomasloven/lovelace-card-mod’ exists in the store.
It’s in folder /homeassistant/www/lovelace-card-mod/card-mod.js.
Why don’t I see it in hacs?
