Probably like this:
card_mod:
style:
hui-generic-entity-row:
state-badge {
{% if is_state('cover.[[blind]]','open') %}
--card-mod-icon: phu:blind-tilt-open;
color: green;
{% elif is_state('cover.[[blind]]','closed') %}
--card-mod-icon: phu:blind-tilt-closed;
color: beige;
{% else %}
--card-mod-icon: mdi:help-circle;
color: red;
{% endif %}
div.entity:nth-child(2) state-badge {
{% set percentage = states(config.entities[0].entity)|int(0) %}
{% set r, g, b = 0, 0, 0 %}
{% if (percentage <= 51) %}
{% set r = 255 %}
{% set g = (5.0 * percentage) | round | int %}
{% else %}
{% set g = 255 %}
{% set r = (505 - 4.89 * percentage) | round | int %}
{% endif %}
color: {{ "#%0x" | format( r * 0x10000 + g * 0x100 + b * 0x1 ) }};
Mngsps
January 11, 2024, 3:38pm
5770
Is this still up to date? In my case it successfully changes the colors but not the font-sizeā¦ Thank you, a lot, for helping!
In general - yes. Ofc you need to add ācard_modā keyword. And suggest to remove āha-cardā, no need in fact (but will work anyway).
If smth does not work - check with Code Inspector. Some DOM paths should be fixed probably.
Mngsps
January 11, 2024, 4:57pm
5772
This is my code:
- type: custom:mod-card
card:
type: vertical-stack
cards:
- show_current: true
show_forecast: true
type: weather-forecast
entity: weather.spieshome
forecast_type: hourly
card_mod:
style: |
ha-card {
--card-primary-font-size: 18px;
--card-secondary-font-size: 14px;
--card-primary-font-weight: normal;
background: none;
border: none;
.name-state .name {
color: orange;
font-size: 20px;
.name-state .state {
color: red;
font-size: 10px;
.temp-attribute .temp {
color: green;
font-size: 10px;
.temp-attribute .temp span {
color: blue;
font-size: 30px;
.temp-attribute .attribute {
color: cyan;
font-size: 20px;
.forecast .temp {
color: orange;
.forecast .templow {
color: blue;
.forecast div {
color: magenta;
- show_current: false
show_forecast: true
forecast_type: daily
card_mod:
style: |
ha-card {
background: none;
border: none;
card_mod:
style: |
ha-card {
background: #2A282D;
ha-card-box-shadow: 'inset 0px 0px 0px 0px var(--divider-color)';
border: 1px solid #37373D;
It does change color bot not font size. Same when removing
ha-card {
background: none;
border: none;
Any idea?
Same idea: check with code inspector as was suggested.
sebbaT
January 12, 2024, 1:53pm
5775
Iām trying to change the absolute positioning of a button within custom:expander-card
and canāt figure out the correct path for card-mod.
JS Path
document.querySelector(ābody > home-assistantā).shadowRoot.querySelector(āhome-assistant-mainā).shadowRoot.querySelector(āha-drawer > partial-panel-resolver > ha-panel-lovelaceā).shadowRoot.querySelector(āhui-rootā).shadowRoot.querySelector(ā#view > hui-view > grid-layoutā).shadowRoot.querySelector(ā#root > stack-in-card:nth-child(2)ā).shadowRoot.querySelector(āha-card > div > hui-vertical-stack-cardā).shadowRoot.querySelector(ā#root > expander-cardā).shadowRoot.querySelector(āha-card > div > buttonā)
Card-mod-helper
ābody>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>grid-layout$#root>stack-in-card:nth-child(2)$ha-card>div>hui-vertical-stack-card$#root>expander-card$ha-card>div>buttonā
Iād like to set right: 50%
to the .header-overlay class.
Iāve tried the below and multiple other variations.
card_mod:
style: |
ha-card > div.title-card-header-overlay > button {
right: 50% !important;
Try to just use button
instead. You might need to set the position to absolute or relative as well depending on your usecase.
card_mod:
style: |
button {
position: relative;
right: 50%;
sebbaT
January 13, 2024, 1:44am
5777
Thanks for your help. Unfortunately that doesnāt work.
No styles are shown in the card-mod dom either:
AleXSR700
(Alex)
January 13, 2024, 6:59am
5778
Is it possible to make an entities card show an input_text with like break (to ensure the entire content is shown)?
Or maybe even as an automatically scrolling text in case of overflow?
mcfly83
(Mcfly)
January 13, 2024, 9:12am
5779
I want to change the mdc-checkboxes from ToDo-List from square to round ones, for this i want to edit the border-radius to 64px. It works within the Browser-Tool, but if i add this to Card-Mod, it won`t work. Has someone an idea why?
card_mod:
style: |
.mdc-checkbox__background {
border-radius: 64px !important;
jmx
(Julian)
January 13, 2024, 4:01pm
5780
HA 2 week user - trying to modify icon colour based on temperature - below not working for this one entity (it works for all if I place the code at the top of my card flush left - but I want it to work on this entity only dealing with temp) - any ideas ? (I can save the code but the icon colour doesnt change on the entity) - thanks - Julian
type: entities
entities:
- entity: sensor.ac_loads
- entity: sensor.backup_state
- entity: sensor.battery_load
- entity: sensor.battery_percent
- entity: sensor.battery_remaining
- entity: sensor.battery_temp
- entity: sensor.battery_voltage
- entity: sensor.192_168_3_230_package_id_0_temperature
name: ProxMox PackID 0 - CPU Temp
card_mod:
style: |
ha-card {
{% if states('sensor.192_168_3_230_package_id_0_temperature') > '40' %}
--card-mod-icon-color: red;
{% elif states('sensor.192_168_3_230_package_id_0_temperature') < '30' %}
--card-mod-icon-color: blue;
{% endif %}
Comparing strings here.
Guess what is bigger: ābananasā or āappleā.
Need to convert to a number first:
if states('sensor.192_168_3_230_package_id_0_temperature')|float(default=0) > 40
Besides, do not use āha-cardā on a row level, use ā:hostā
jmx
(Julian)
January 13, 2024, 6:50pm
5782
thanks kindly - it works fine now with:
ā:hostā
Even with your wrong template ? )
jmx
(Julian)
January 13, 2024, 7:23pm
5784
oddly yes - I even changed the numbers for a test and saw the colour change accordingly - but what you suggested makes sense - Iāll improve my code to that - thanks again
Compare ā100ā & ā19ā then )))
jmx
(Julian)
January 13, 2024, 8:11pm
5786
ah yes - good point - that failed - corrected with below as per your suggestion:
card_mod:
style: |
:host {
{% if states('sensor.192_168_3_230_package_id_0_temperature')|float(default=0) > 50 %}
{% elif states('sensor.192_168_3_230_package_id_0_temperature')|float(default=0) < 40 %}
--card-mod-icon-color: green;
{% endif %}
AleXSR700
(Alex)
January 13, 2024, 11:31pm
5787
I want to switch from lovelace resource (normal installation via HACS) to frontend module by adding it as a package.
Is there a way of checking if the card-mod was loaded as lovelace resource or as frontend module?
I added a yaml file to my packages folder using
frontend:
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js
but I donāt know how to check if that worked and if anything changed. It is still listed as a resource under dashboards.
Well if itās listed, it was successful ā¦
