🔹 Card-mod - Add css styles to any lovelace card
I gave you the link, there is only one link to a post, one “entities” section in the post
Sorry I am not able to find it how to change style of entity type section. Anyone else who can give me a hint with yaml code?
  1. Have you found this Entities section?
  2. It has a link - this link
  3. Scroll this post for the section style.
I am trying to get these cards transparent, but all I get is a white box. Can someone point me in the right direction? And if there is a base line tutorial on how to configure some of this CSS that you would recommend, I would appreciate it.
  - title: Home
    background: center / cover no-repeat fixed url('http://picsum.photos/1280/720?random')
    type: custom:grid-layout
    layout:
      max_cols: 3
      grid-template-columns: 426px 426px 426px
      grid-template-rows: 720px 720px 720px
    cards:
      - type: vertical-stack
        cards:
          - type: custom:digital-clock
            card_mod:
              style: |
                ha-card {
                color: black;
                height: 200px;
                font-size: 30px;
                border-style: none
                background: transparent
          - type: custom:gap-card
            card_mod:
              style: |
                ha-card {
                height: 120px;
                border-style: none
          - type: custom:atomic-calendar-revive
            card_mod:
              style: |
                ha-card {
                height: 240px;
                border-style: none
            enableModeChange: true
            firstDayOfWeek: 1
            maxDaysToShow: 300
            maxEventCount: 5
            refreshInterval: 60
            showLocation: false
            showMonth: true
            entities:
              - calendar.ical_home
        card_mod:
          style: |
            ha-card {background: transparent
        height: 200
        cards:
          - type: weather-forecast
            card_mod:
              style: |
                ha-card {
                height: 240px;
                border-style: none
            entity: weather.home
            show_forecast: true
            forecast_type: legacy
Have checked this code in Code Inspector by yourself?
Have you seen all styles applied in Code Inspector (i.e. not scratched out, w/o errors etc)?
Or this was just copy/pasted from somewhere?
I believe you need to properly close out the background line like this…
card_mod:
              style: |
                ha-card {
                height: 240px;
                background: transparent !important;
                border-style: none;
Whats Code Inspector ?
I was missing the semicolons at the end of the lines.
Immediately fixed it… Thanks for the tip…
Any suggestions how how to make a 20% opaque - or whatever - to make the text more readable on any image?
You can add color, font size and weight to start
card_mod:
          style: |
            ha-card {
            height: 240px;
            border-style: none;
            color: red !important;
            font-weight: 500;
            font-size: 1.1em;
It’s a tool to check are your styles applied or not.
Part of a browser.
In Chrome/FF it is called by F12.
You don’t have to go straight to a transparent background. This example dims a green back ground using rgba with the last value being the opacity (0.2)
card_mod:
          style: |
            ha-card {
            height: 240px;
            border-style: none;
            background: rgba(60, 179, 113, 0.2) !important;
            color: white !important;
            font-weight: 700 ;
            font-size: 1.1em;
This is a great starting point for understanding basic CSS
How to change color Up Down of input_number.
You’ll need to post the card code so it’s easier for folks to assist you.
This is my card for testing
type: entities
entities:
  • entity: input_number.index_when_play_repeat_music
    card_mod:
    style: |-
    :host {
    –paper-item-icon-color: lime;
    color: lime;
    ha-textfield {
    –mdc-text-field-idle-line-color: green;
    –mdc-text-field-hover-line-color: red;
    –mdc-text-field-outlined-idle-border-color: blue;
    –mdc-text-field-fill-color: rgba(82, 22, 8, 0.2);
    –mdc-text-field-ink-color: lime;
    –mdc-text-field_input: red;
Found it, thanks.
This is what I used:
  - type: section
    label: Water Sensors
    card_mod:
      style: |
        .divider {
          display: none;
Left - your style. Right - untouched.
Now check the bottom lines.
Do you accept this difference?
Yes, but bottom lines are because of Edit mode, they are not there when you save the change and exit Edit mode. Or Wait, it is not edit mode, I do not see bottom lines in my case.
No, I do not mean lines caused by Edit mode…
Check the last section line.
Your case cannot simulate the hidden issue.
Ok, here is the entire card in white. It is looking fine.
No, you missed the point. But this is probably not important for your setup.
