I can see that it is more compact when lines are removed and I like it that way as well when height is smaller.
This is OK; my point was about a vertical alignment.
A section w/o a divider line is still a section; in my example with 2 same entities card there is a misalignment between 2 section lines caused by a hidden ādividerā element.
A possible way could be just making the divider transparent instead of removing it - this way keeps same height for a section.
Repeat, if you satisfied with your solution - itās OK.
I have had a card to display alarm status (green = disarmed, red/blinking = armed) but it has stopped working. Maybe with an update.
alarm_control_panel.9000_aaa_zone_1_alarm
get correct status update
Any idea what could be wrong?
type: vertical-stack
cards:
- show_name: false
show_icon: true
type: button
style: |
ha-card {
border-radius: 0px;
{% if is_state('alarm_control_panel.9000_aaa_zone_1_alarm', 'disarmed') %}
animation: none;
--state-alarm_control_panel-disarmed-color: green;
{% elif is_state('alarm_control_panel.9000_aaa_zone_1_alarm', 'armed_night') %}
animation: blink 1s linear infinite;
background-color: red;
--state-alarm_control_panel-armed_night-color: white;
{% elif is_state('alarm_control_panel.9000_aaa_zone_1_alarm', 'armed_away') %}
--state-alarm_control_panel-armed_away-color: white;
{% else %}
none
{% endif %}
@keyframes blink {
50% {opacity: 0;}
tap_action:
action: none
entity: alarm_control_panel.9000_aaa_zone_1_alarm
icon: mdi:shield-home
show_state: false
hold_action:
action: none
How do I change the font colour of the calendar events ?
type: custom:atomic-calendar-revive
view_layout:
grid-area: Calendar
card_mod:
style: |
ha-card {
border-style: none;
color: red;
font-size: 20px;
background: transparent;
enableModeChange: true
firstDayOfWeek: 1
maxDaysToShow: 300
maxEventCount: 5
refreshInterval: 60
showLocation: false
showMonth: true
showHiddenText: false
entities:
- entity: calendar.ical_home
Consider reading release notes before updating card-mod.
I donāt have the calendar loaded, but try adding these to card mod and see if adjusts the calendar text colors
--primary-text-color: green !important;
--secondary-text-color: blue !important;
view_layout:
grid-area: Calendar
card_mod:
style: |
ha-card {
border-style: none;
color: red !important;
font-size: 20px;
firstDayOfWeek: 1
maxDaysToShow: 300
maxEventCount: 5
refreshInterval: 60
showLocation: false
showMonth: true
entities:
I admit that I updated without reading but I saw that there were some changes.
Now I really have difficulty reproducing the animations that you gave us at the startā¦ Bumping, stretching, coloring icons etcā¦
Can you please give us one updated example of animated icon ?
Thanks for helping
best regards
You should first start with fixing in accordance to changes described in release note for 3.4.
Now the āstyleā option must be under ācard_modā keyword like here:
card_mod:
style: ...
As for examples for animations for button-card - check in the 2st post ā link at the bottom, it has examples for animations. But if your code were working before the recent changes - you should start with the fix I told above.
You have just admitted that you have not read the release note - and probably you should read it now at last.
Thanks, Ill try it.
Can you (or someone) explain the ā!importantā at the end of lines?
Is it just so I pay attention to the change?
may be found.
Haā¦you beat me to posting the same link
Thanks for your repply.
Dont worry i read changelog before posting, but i was missing something.
I managed to fix it, thanks
Very good! So, a small mistake may cause some headache(
Itās the very 1st link when googling āimportant cssā.
Also, this particular site is very good, as you know; I usually advise this site.
Between a few CSS sites, your guides as well as Dimitriās, I have learned a ton in a short time.
Yes, I should have read change notesā¦thanks for the lead and it is now working again
Guess it is much better to give a tiny lead & let a man to solve the issue by himself )))
Hi all,
I donāt manage to make my ha-icon rotating on a markdown card.
the card-mod works like a charm on the card (ha-card) itself but nothing works with ha-icon or ha-svg-icon even with the ā!importantā flag.
Can someone help me ?
My code :
type: markdown
card_mod:
style: |
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(359deg);
@keyframes colorize {
0% {
color: var(--primary-color);
50% {
color: green;
100% {
ha-card {
ha-icon {
color: red;
animation: rotation 10s linear infinite;
ha-svg-icon {
color: green;
content: >-
## The card Title...and code
Page 5054
And now? This link is in the first post of this topic as well and hundrets of posts are refering to this first post and this link.
