🔹 Card-mod - Add css styles to any lovelace card
I can not find. I was able to change the color of that part but not make the selection invisible. There’s no way to do it. :confused:
There is an “unofficial” rule here: if you say “I tried but failed” - you should have posted a code which demonstrates that you really tried. Goal is to bring up “learners”, not “consumers”.
The parts are mdc-tab and mdc-tab–active.
I have done several tests, the color can be changed and it works, the transparent one also works but not as I would like. The clearer selection when tapping with your finger remains, I was unable to eliminate it.
Please post the entire card’s code. Simple things like misplaced code, typos and column errors can cause the issues you are describing.
Link to pastebin
So I understand, what section are you trying to make clear. Where the red is?
When you tap it , the color comes back correct?
No, when you tap on a section, a lighter rectangle is formed around the icon, like this:
Then if I tap another section, the lighter rectangle moves to the other section. if I then tap on any other part of the dashboard the lighter rectangle disappears, like this:
I wish that rectangle wasn’t there
We are saying the same thing, so I see what you are looking for.
Try this:
type: custom:mod-card
card_mod:
  style: |
    tabbed-card {
      --mdc-ripple-color: transparent;
card:
  type: custom:tabbed-card
or w/o card-mod:
styles:
  '--mdc-ripple-color': transparent
Now it work, thanks!
So I have an issue, I tinkered with the code for a few days and got it to work. I accidentally deleted the card a few days later and for some reason my HA did not back up the card. So I went to create the new card, and now for some reason the slider disable option will not work. Any ideas why? I know I had to move some stuff arround but got it to work, and now I can’t figure it out. Code below
Thanks.
type: thermostat
entity: climate.thermostat
card_mod:
  style: |
    :host {
      --state-climate-cool-color: green;
      --state-climate-heat-color: red;
    .more-info {
      width: 0;
    ha-state-control-climate-temperature$:
      ha-control-circular-slider$: |
        g#interaction {
          display: none !important;
fighting with this…
this works:
  - type: custom:multiple-entity-row
    entity: sensor.studenten_hygro_temp_temperature
    card_mod: !include /config/dashboard/card_mods/temp_binnen_color.yaml
but how do I get that card_mod to work using the decluttering template:
card:
  entity: sensor.[[id]]_hygro_temp_temperature
  hide_unavailable: true
  state_header: Temp
  card_mod: '[[mod]]'
  entities:
    - entity: sensor.[[id]]_hygro_temp_humidity
    - entity: sensor.[[id]]_hygro_temp_battery
  secondary_info:
    entity: sensor.[[id]]_hygro_temp_signal_strength
and
  - type: custom:decluttering-card
    template: temp_humid_multiple_entity
    variables:
      - id: master_bedroom
      - name: Master Bedroom
      - mod: !include /config/dashboard/card_mods/temp_binnen_color.yaml
dont get how I should pass, or even need to, that mod from the card to the template and back again… cant we set the card_mod inside the decluttering and have it applied to all using that template?
even the example set by Ildar does not work so I suppose this is deprecated functionality…
really too bad, I would have loved to use the card
just adding to the above:
im not trying to have each listed entity use an individual mod. I need all entities to use the same mod (for temp icon color).
so, I figured to have that in the decluttering-template. it always works on all cards I have. decluttering was created to do this, prevent multiple copies of the exact same code, as Anchors do.
so the mod working on my top example should just work…on all of them… but it doesnt
wonder if we can somehow inspect the yaml all of these cards together make in the end to feed the dashboard. maybe its just not doing that correctly and we have a bug
it seems that the custom:mod-card uses a margin.
it is in a custom:layout-card which holds a grid (with mod-card) which was created from auto entities.
i hide empty auto entities but the margin of the mod card still shows.
how do i get rid of this margin?
my code is:
type: custom:layout-card
layout_type: grid
layout:
  grid-template-columns: 100%
  grid-template-rows: min-content 1fr
  grid-template-areas: |
    "lights"
    "vacuum"
    "media"
    "climate"
    "switch"
    "sensor"
    "binary"
    "fan"
    "select"
    "boolean"
cards:
  - type: custom:mod-card
    view_layout:
      show:
        mediaquery: '(min-width: 800px)'
      grid-area: lights
    card_mod:
      style:
        hui-grid-card:
            .card-header {
              color: #9b9b9b !important;
              margin: 0px !important;
              font-size: 1em !important;
              font-weight: 600 !important;
              padding: 0px !important;
    card:
      type: custom:auto-entities
      show_empty: false
      card:
        type: grid
        square: false
        columns: 4
        title: Lichter
      card_param: cards
      filter:
        template: >-
          {%- set entity_filter = '' %}  {%- set domains = states.light |
          selectattr('entity_id', 'in',area_entities('Wohnzimmer')) |
          map(attribute='domain')   | unique | list -%}   {%- for domain in
          domains  -%}        {% set entities = states   |
          selectattr('domain', 'eq', domain)  | rejectattr('entity_id', 'in',
          entity_filter) | list -%}
             {%- for entity in entities  -%}
                  {{{ 'type': 'custom:mushroom-light-card',
                      'entity': entity.entity_id,
                      'use_light_color': 'true',
                      'show_brightness_control': 'true',
                      'show_color_control': 'true',
                      'collapsible_controls': 'true',
                      'show_color_temp_control': 'true', }}},
             {%- endfor %}{%- endfor %}
    view_layout:
      show:
      grid-area: vacuum
    card_mod:
      style:
        hui-grid-card:
            .card-header {
    card:
      show_empty: false
      card:
        type: grid
        square: false
        columns: 4
        title: Media
      card_param: cards
      filter:
        template: >-
          {%- set entity_filter = '' %}  {%- set domains = states.vacuum |
    view_layout:
      show:
      grid-area: media
    card_mod:
      style:
        hui-grid-card:
            .card-header {
    card:
      show_empty: false
      card:
        type: grid
        square: false
        columns: 4
        title: Media
      card_param: cards
      filter:
        template: >-
change area_entities(‘Wohnzimmer’)) to area_entities(‘your_area_room’)) if you want to try it
EDIT: just had to add
          card_mod:
            style:
              hui-grid-card:
                  .card-header {
                :host {margin: 0px !important;}
Hey guys, does anybody know, how to hide the attribute of my humidifier?
type: entities
entities:
  - entity: humidifier.vocolinc_vhi_1fc973_humidifier
Wondering if anyone can help… I have spent hours trying to work out why this isn’t working…
I am trying to get a mushroom-number-card to be right justified with a small width value control (see pics) and everything is working except setting mushroom-state-item$ .container.horizontal {flex: unset!important;}
1st pic shows page on load and 2nd pic shows flex attribute unchecked (set to unset gives same results) with the mushroom number card in the 2 positions…
Here is my code:
          - type: custom:mushroom-number-card
            entity: input_number.energy_hours
            layout: horizontal
            display_mode: buttons
            icon: none
            icon_type: none
            # icon_color: primary
            fill_container: false
            primary_info: name
            secondary_info: none
            card_mod:
              style:
                mushroom-card$: |
                  .container {
                    justify-content: right !important;
                mushroom-state-item$: |
                mushroom-state-info$: |
                  .container {
                    align-items: end;
                    margin: 6px -6px 0px 0px;
                    justify-content: right;
                    flex: unset !important;
                mushroom-number-value-control$: |
                  mushroom-input-number {
                    --bg-color: transparent !important;
                    # --bg-color: red !important;
                    width: 90px;
                    display: block;
                  ha-card {
                    # width: 200px;
                    background: none!important;
                    # border: none!important;
                    # box-shadow: none!important;
                    # height: 20px!important;
                    margin: -4px -4px 0px 0px!important;
                    padding: 4px 0px 0px 0px!important;
                    --control-height: 32px;
                    # align-items: justify;!important
                    align-self: end;!important
                    # flex: unset !important;
Add these lines under your ha-card { You should also be able to delete some of you other mod settings.
                  ha-card {
                    position: relative;
                    float: right;
This is probably closer to what you are trying to achieve, but @Ildar_Gabdullin may be able to offer advice on streamlining the code.
entity: input_number.test_level_1
layout: horizontal
icon: none
icon_type: none
icon_color: none
primary_info: name
card_mod:
              style:
                mushroom-card$: |
                  .container {
                    flex: unset;
                  .container {
                    align-items: end;
                    display: block;
                  ha-card {
                    position: relative;
                    float: right;
                    width: 250px;
                    background: none !important;
                    border: none !important;
                    box-shadow: none !important;
                    height: 20px !important;
                    margin: -4px -4px 0px 0px important;
                    padding: 4px 0px 0px 0px important;
An unrelated remark:
since the whole “ha-card” part is a string (with line-breaks to look nice in a code) - you cannot comment it’s parts by using “#”.
I.e. this is wrong:
ha_card {
  #color: xxx;
  color: red;
Use “/* */” instead:
ha_card {
  /* color: xxx; */
  color: red;
There are semi-colons in-between !important too. I was still working on the code realizing it wasn’t right. Feel free to jump in.
Yes, we should point a user at these errors, let him/her correct them. Allowing to learn is better than giving a ready solution)
