šŸ”¹ Card-mod - Add css styles to any lovelace card
After upadate Core,the color of this icon doesn’t work. this is a bug or am i wrong?
type: horizontal-stack
cards:
  - type: tile
    entity: sensor.aria_pm25
    show_entity_picture: false
    card_mod:
      style:
        .icon-container .icon$: |
          .shape {
            border-radius: 15px !important;
            background:
              {% if states('sensor.aria_pm25')|float(0) >= 125|float(0) -%}
                rgba(255,0,0,0.6)
              {% elif states('sensor.aria_pm25')|float(0) >= 60|float(0) -%}
                rgba(255,165,0,0.8)
              {% elif states('sensor.aria_pm25')|float(0) >= 0|float(0) -%}
                rgba(60,179,113,0.6)
              {% endif %} !important;
  - type: tile
    entity: sensor.aria_voc_index
    icon: mdi:chart-bell-curve-cumulative
Noticed similar things occurring with tile card icons and animations since the update. Change:
with:
ha-tile-icon$
Has fixed some issues for me
I think the DOM path has changed slightly, so that the tile icon element no longer has the .icon class. Try this to see if it works for you (it does for me):
    card_mod:
      style:
        .icon-container ha-tile-icon $: |
Actually, not sure you really need the .icon-container bit. Try this alternatively:
    card_mod:
      style:
        ha-tile-icon $: |
EDIT: gbboy got there first!
yes, it is work!!! thank you
yes, this is the solution, it’s work! thanks
@hazio What card? Check out
Already answered what was changed.
Suggest you to use Code Inspector before posting issues in Github.
Now the repo is cluttered with plenty of ā€œbugsā€ (still open) which are ā€œusers’ errorsā€ in fact.
It’s for All cards, It needs to be applied system-wide, so I’d imagine it will be through themes.
Edit: Okay, I think I have figured it out
--state-icon-error-color: var(--error-state-color, var(--error-color)); --state-unavailable-color: var(--state-icon-unavailable-color
  1. Try to understand how to fulfil your task for one card.
  2. Then - how to do it globally.
If you disagree with pt.1 - then the question should be asked in a themes thread )))
i’m sorry, but i can’t work this out
the new update seems to have broken
card_mod:
          style: |
                ha-card {
                  --primary-text-color: white;
but only on one of my computers… which is why i am puzzled
any help would be appreciated
Does this fix it.?
card_mod:
    style: |
        ha-card {
          --card-primary-color: white !important;
What card?
And why not checking with Code Inspector by yourself?
Clean up cache everywhere.
If some style does not work on some device - it may happen because of:
– the device still have some old js-code in cache
– the device has a browser which does not support (or supports wrongly) some CSS attrs/features.
sorry for my error and thanks for the support.
No need to apologize; understanding these things is for YOUR success.
Hi, is there a way to remove the light gray background of the selected part?
If I then click elsewhere in the dash it disappears.
Is it possible to remove the highlighted selection?
Now it’s like this
I would like it that way
Use Code Inspector to find out which element’s background needs a change.
Currently I don’t have the possibility to use Code Inspector, but it should be the background when the mouse passes over it (but now I can only try from a smartphone). I tried a few times but failed.
mushroom custom title cards
and i tried but i am quite new to this and i am not really sure what i am looking for or at, which would be why i asked for help
i can still find primary-text-color in the css, but that is about where i got lost
it is the computer i cleared cache on where it no longer works
i am using the same browser on both so my guess is that is the issue there
Not using mushrooms.
Here is what you should do:
  1. If you need a ready answer:
    – post a SHORT code of your card;
    – explain what you want to achieve;
    – show what you tried.
  2. Or - using Code Inspector, localize the element you wish to style; then see in Code Inspector which property is used (which you want to override) and what value it is equal to. Then try to write a card-mod code with a defined path to the element. Post here in case of questions / failures…
@RatatoskRagnarok Mushroom uses specific nomenclature for title cards. I just answered this yesterday in the Mushroom forum found here:
type: custom:mushroom-title-card
title: Title
subtitle: Subtitle
card_mod:
  style: |
    ha-card {
      --title-color: red !important;
      --subtitle-color: blue !important;
For the remainder of Mushroom Cards you’ll use
card_mod:
    style: |
        ha-card {
          --card-secondary-color:  green !important;
In addition @Ildar_Gabdullin advice is exactly how I was able to learn how to edit rather quickly.
