šŸ”¹ Card-mod - Add css styles to any lovelace card
I see, the image is not removed.
Check this:
The upper is with card-mod.
Image is not removed, it just became less visible))))
I see no difference between my & your variant:
(modded your variant a bit by using ā€œnot()ā€)
I compared to my simplification:
card_mod:
  style: |
    .player.no-image {
      background-color: var(--state-unavailable-color);
which removes the image ā€¦
Confirm, it removes:
because it is overlaying it, check with a transparent color:
So, this ā€œ.playerā€ variant may be used to mark an adult content ))))
Iā€™m trying to increase the size of the font for the events in ā€œlistWeekā€ view of the built-in calendar card. I think I donā€™t understand how to get down to the proper class. Iā€™ve tried all manner of things. I think .fc is inside #calendar, and I know that #calendar is in the shadow-root of ha-full-calendar, but I canā€™t figure out how to access it. The highlighted line in the screenshot below changes the text size in the developer panel. Current code, after many many iterations:
          ha-full-calendar$: |
              .fc {
                font-size: 2em;
I filmed it using your mod. Some colors work, some dont.
I suppose I am seeing my primary-color when not modding, but since the card seems to be applying some filter, it changes my primary-color so something toned down, making the image appear. (and making the color no longer fit my theme
I suspect your example with red also isnt showing a true red, but a red with opacity, just check it without anything further, and compare
Mar-05-2024 22-29-42
this brings the true color:
type: media-control
entity: media_player.googlehome_hub
card_mod:
  style: |
    .player {
      {{'background: grey'
         if is_state(config.entity,['off','idle'])}};
and solves the complexer path, but, ofc, it again covers the imageā€¦
can even set it to use my main gradient in the theme:
type: media-control
card_mod:
  style: |
    .player {
      {{'background: radial-gradient(var(--primary-color),var(--card-background-color))'
building on that:
type: media-control
card_mod:
  style: |
    {% if is_state(config.entity,['off','idle']) %}
    .player {
      background: var(--lovelace-background)
    .controls {
      color: var(--no-power-color);
    .top-info {
    {% endif %}
I would think not even this.
Something is above this color. If it is another with opacity or a image with opacity, you can search. Donā€™t have the time now.
E.g. if your assign red #ff0000 and take the color picker afterwards, you will get #f3121b and then #e81c28 if you do it again, ā€¦
I stumbled onto a variable that controls this, that I can reference under ha-card to achieve this result. The code below adjusts the font size for the event times and descriptions (ā€“paper-font-body1_-font-size), and for the weekly heading (ā€“paper-font-headline-_font-size) at the top of the card. It adjusts the font size for the day (.fc-list-day-text) and date headings (.fc-list-day-side-text) for each section. It also adjusts for the height of the scrollable portion of the list view.
      card_mod:
        style:
          ha-full-calendar:
              .fc-list-day-text {
                 font-size: 24px !important;
              .fc-list-day-side-text {
            ha-card {
            border: none;
            align-items: center;
            height: 900px !important;
            background-color: rgba(0, 0, 0, .1);
            --paper-font-body1_-_font-size: 20px;
            --paper-font-headline_-_font-size: 32px;
            ha-full-calendar {
               --calendar-height: 750px !important;
Last step is to increase the font size for the Day and Date Labels for each event section of the card. I cannot find a variable that controls these font sizes, so I need to reference these objects directly and adjust the font-size parameter. Based on what I see in the developer console, which is pasted below, I really think this code should work, but it doesnā€™t. What am I missing?
          ha-card {
            ha-full-calendar {
              .fc-list-day-text {
                font-size: 40px !important;
Adjusting the font size here in the developer console works:
Here is the structure in the developer console:
Compare your code with any other working code here in the exmaples and thread and you will directly see, that yours ist completley wrong syntax.
I guess thatā€™s why Iā€™m here. Iā€™ve tried many iterations of syntax. It appears to me that ha-full-calendar is under ha-card, and that .fc-list-day-text is inside the shadow-root of ha-full-calendar, so thatā€™s the reason for the $ to traverse. Is that correct? Syntax is definitely wrong in the above screenshot due to a copy paste error. The code still doesnā€™t work and probably the syntax is still wrong, but here it is at the moment. Iā€™ve not found other examples of such nexted objects unfortunately.
          ha-card {
            ha-full-calendar$ {
              .fc-list-day-text {
Help to help yourself: As said compare to others, who did it. Here a random example from this thread, I have just scrolled a little bit up. But why is it not possible to search at least a little bit on your own?
- type: entities
    entities:
      - type: custom:multiple-entity-row
        entity: sensor.phase_3
        unit: false
        card_mod:
          style:
            hui-generic-entity-row:
                state-badge {
                  display: none;
                .info {
                  margin-left:0 !important;
                  display: none;
So remove the ha-card in your case (not needed here) and format the rest according to the given example.
Just try it without your first styles from the post before. And I imagine, then the next question will be, ā€œhow to combine the two of themā€. Therefore already the anser: First thread. Link to Ildars examples. And there you will find an entry how to combine such shadow root things with other styles on other levels. .:| will be your friend.
Thank you for the direction. I did not know about specific syntax for combining elements. This is my current code, and it is working. Would you suggest any modifications?
      card_mod:
        style:
          ha-full-calendar:
             .fc-list-day-text {
            ha-card {
            border: none;
            ha-card {
              ha-full-calendar {
Last part. Use this. without nesting {}, which are here wrong as well.
Thank you very much for your help.
After upgrading to 2024.3.0 not all modifications are stll working. For some reason the margins, border width are back to normal. Anyone else noticed this and has a fix for it?
type: custom:mod-card
card_mod:
  style:
    hui-vertical-stack-card $: |
      div#root > * {
        --ha-card-border-width: 0px;
      hui-vertical-stack-card {
        --vertical-stack-card-margin: 1px;
      ha-card {
        box-shadow: var(--ha-card-box-shadow);
        border: var(--ha-card-border-color,var(--divider-color,#e0e0e0)) solid var(--ha-card-border-width,1px);
Because this var seems to be not used any more for margins - they are set by a ā€œgapā€ now.
Thank you, problem solved:
--vertical-stack-card-gap: 1px;
How can i change the spacing in the dropdown card to match that of the first pic? I would also like to keep the title of dropdown in the center.
Code:
type: custom:collapsable-cards
cards:
  - type: horizontal-stack
    cards:
      - type: custom:mushroom-light-card
        fill_container: true
        use_light_color: false
        show_brightness_control: true
        show_color_temp_control: false
        show_color_control: false
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        collapsible_controls: true
        icon: mdi:lightbulb-group
        double_tap_action:
          action: none
        entity: light.living_room_lights
        card_mod:
          style: |
            ha-card {
            --control-height: 15px;
            --icon-size: 40px;}
            ha-card {
               {% if is_state(config.entity, 'on') %}
                  background: rgba(255, 152, 0, 0.1);
               {%- else -%}
               {%- endif %}
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        icon: mdi:light-recessed
        double_tap_action:
          action: none
        entity: light.kitchen_main_lights
        card_mod:
          style: |
            ha-card {
            --icon-size: 40px;}
            ha-card {
                 {%- else -%}
                 {%- endif %}
    cards:
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        double_tap_action:
          action: none
        entity: light.kitchen_table_lights
        card_mod:
          style: |
            ha-card {
            --icon-size: 40px;}
            ha-card {
                 {%- else -%}
                 {%- endif %}
        icon: mdi:track-light
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        double_tap_action:
          action: none
        entity: light.kitchen_sink
        card_mod:
          style: |
            ha-card {
            --icon-size: 40px;
            ha-card {
                 {%- else -%}
                 {%- endif %}
    cards:
        entity: light.dining_room_lights
        card_mod:
          style: |
            ha-card {
            --icon-size: 40px;
            ha-card {
                 {%- else -%}
                 {%- endif %}
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        entity: light.garage_lights
        icon: mdi:lightbulb-fluorescent-tube-outline
        tap_action:
          action: toggle
        hold_action:
          action: more-info
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
               {%- else -%}
               {%- endif %}
Not sure if itā€™s right place to ask, but please help me to reduce space between icon and text. TY
type: custom:stack-in-card
mode: vertical
cards:
    cards:
        primary: First Floor
        icon: mdi:home-floor-1
        icon_color: teal
        card_mod:
          style: |
            ha-card {
               --card-primary-font-size: 1rem;
               border: none;
               box-shadow: none;
               background: rgba(0,0,0,0);
               margin-top: rem;
               margin-left:5rem
    cards:
      - type: custom:button-card
        show_name: true
        show_icon: true
        icon: mdi:sofa
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.living_room_lights') == 'on' %}
              box-shadow: 0px 0px 5px 5px #CBC3E3 !important;
              {% else %}
              box-shadow: 5px 10px 5px -3px rgba(0,0,0,0.75);
              {% endif %}
              {% if is_state('light.living_room_lights','on') %}
              background: rgba(255, 152, 0, 0.1) !important;
              {% endif %}
              font-size: 10px !important;
        tap_action:
          action: navigate
          navigation_path: living-room
        layout: icon_name
        theme: ios-dark-mode
        show_name: true
        show_icon: true
        icon: mdi:pot-steam
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.kitchen_lights_2') == 'on' %}
              {% else %}
              {% endif %}
              {% if is_state('light.kitchen_lights_2','on') %}
              {% endif %}
        tap_action:
          action: navigate
          navigation_path: kitchen
        layout: icon_name_state
    cards:
        show_name: true
        show_icon: true
        icon: mdi:hat-fedora
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.hallway_lights') == 'on' %}
              {% else %}
              {% endif %}
              {% if is_state('light.hallway_lights','on') %}
              {% endif %}
        tap_action:
          action: navigate
          navigation_path: hallway
        show_name: true
        show_icon: true
        icon: mdi:bathtub
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.light') == 'on' %}
              {% else %}
              {% endif %}
              {% if is_state('light.light','on') %}
              {% endif %}
        tap_action:
          action: navigate
          navigation_path: my-bathroom
    cards:
        show_name: true
        show_icon: true
        icon: mdi:go-kart
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.garage_lights_light') == 'on' %}
              {% else %}
              {% endif %}
              {% if is_state('light.garage_lights_light','on') %}
              {% endif %}
        tap_action:
          action: navigate
          navigation_path: garage
        show_name: true
        show_icon: true
        icon: phu:outside
        color: teal
        card_mod:
          style: |-
            ha-card {
              {% if states('light.outside_lights') == 'on' %}
              {% else %}
              {% endif %}
              {% if is_state('light.outside_lights','on') %}
              {% endif %}
        tap_action:
          action: navigate
          navigation_path: outside
card_mod:
  style: |
    ha-card {
      background-size: 100% 100%;
      background-image: url({{/local/png/weather/cloudy.gif}});
TY
