🔹 Card-mod - Add css styles to any lovelace card
Hi there,
A little bit of help please.
I was using the following code on some cards:
card_mod:
  style:
    ha-tile-icon$: |
      .shape {
        border-radius: 15px !important;
        height: 60px !important;
        width: 60px !important;
        margin-top: 10px !important;
        margin-bottom: 2px !important;
    ha-tile-info$: |
      .primary {
        font-size: 16px !important;
        font-weight: bold !important;
      .secondary {
        font-size: 15px !important;
    style: |
      ha-card {
        color: red;
        height: 80px !important;
It does what I want however the page is ok when loaded but after some seconds get stuck and in need to reload the page.
This only happed when I have the
  style: |
      ha-card {
part included. If I took it out it’s ok.
This happens whatever the code I have on that part.
Anyone can help?
Thanks!.
card-mod must have ONE “style” keyword.
go to 1st post of the thread → link at the bottom → other stuff → combining
Thank you very much for the pointer :ok_hand:
card_mod:
  style:
    ha-tile-icon$: |
      .shape {
    ha-tile-info$: |
      .primary {
      .secondary {
      ha-card {
        color: red;
Is it possible to change aspects of the new “sections” ? I would like to change the font size and padding for the style h2.title. Is this something that can be done?
A bit tweaked version of a very interesting card - fluid-level-background-card:
repo
related issue fixed by this tweak
dedicated thread in Community
type: custom:mod-card
card_mod:
  style:
    fluid-level-background-card $: |
      div#container {
        border: none;
        box-shadow: none;
      .type-custom-fluid-level-background-card {
        border: none;
        box-shadow: none;
      fluid-background {
        border-radius: var(--ha-card-border-radius,12px);
card:
  type: custom:fluid-level-background-card
  card:
    type: glance
    entities:
      - entity: sun.sun
  entity: input_number.test_level_1
  fill_entity: input_boolean.test_boolean
  level_color: [242,142,28]
az
That has so many card application possibilities. Awesome!
I saw a few backgrounds like this with rain drops, spraying water droplets etc…when researching sprinkler animation.
Would be great to have these animations shared somewhere!
Did somebody manage to get the pointer-events: none working?
I want to change the pointer-events: to “none”
The full JS path is document.querySelector(“body > home-assistant”).shadowRoot.querySelector(“hui-dialog-edit-card”).shadowRoot.querySelector(“ha-dialog > div.content > div.element-preview > hui-card-preview > hui-vertical-stack-card”).shadowRoot.querySelector(“#root > hui-vertical-stack-card”).shadowRoot.querySelector(“#root > hui-entities-card:nth-child(1)”).shadowRoot.querySelector(“#states > div > slider-entity-row”).shadowRoot.querySelector(“div > ha-slider”).shadowRoot.querySelector(“#end”)
If i run it trough Card Mod Helper i get this string:
“body>home-assistant$hui-dialog-edit-card$ha-dialog>div.content>div.element-preview>hui-card-preview>hui-vertical-stack-card$#root>hui-vertical-stack-card$#root>hui-entities-card:nth-child(1)$#states>div>slider-entity-row$div>ha-slider$#end”
I cant find the code to alter pointer-events on the place I show in the screenshot on the right side.
I’ve been on it for days and completely clueless, can somebody help me?
Have you tried just entering it under ha-card? Your post want clear you were asking about the custom:slider-entity-row
type: entities
title: Pointer
entities:
  - entity: sun.sun
card_mod:
 style: |
   ha-card {
     pointer-events: none;
I’ve embedded this:
card_mod:
  style: |
    ha-card {
      {% if is_state('media_player.speakers_tim_bed','off') %}
      {% endif %}
at the bottem of the vertical-stack where the sliders are located. Is i run the above code trough the tester the output is:
card_mod:
  style: |
    ha-card {
This does nothing for me.
For good mesure, I also tried to add it into the card within the vertical-stack
type: entities
title: Front Left
entities:
  - type: custom:slider-entity-row
    entity: input_number.speakers_bed_front_left_niveau
    full_row: true
card_mod:
  style: |
    ha-card {
      --ha-card-header-font-size: 14px;
      {% endif %}
This also didnt work for me
You want no action on the slider if speaker is off, correct?
Yes correct
I’ll let you know if I get it. You can stop it in the dev tool, but struggling to execute in card_mod.
For troubleshooting I made a new card, more basic:
type: entities
entities:
  - input_number.speakers_bed_front_left_niveau
card_mod:
  style: |
    ha-card {
This results in the red part being non-clickable but the green part being clickable:
Thanks man! appreciate the time and effort you put into this!
Is it possible to add border highlight to each floor and also a room when lights is on to Vertical Stacked Navigation Card ?
Like this:
type: custom:stack-in-card
mode: vertical
cards:
  - type: vertical-stack
    cards:
        primary: Basement
        icon: mdi:home-floor-b
        icon_color: teal
        card_mod:
          style: |
            ha-card {
               --card-primary-font-size: 1rem;
               border: none;
               box-shadow: none;
               background: rgba(0,0,0,0);
               font-weight: bold;
               margin-top: rem;
               margin-left:5rem
      - type: horizontal-stack
        cards:
            primary: Basement
            secondary: null
            icon: mdi:escalator-down
            icon_color: teal
            card_mod:
              style: |
                ha-card {
                  {% if states('light.basement_lights') == 'on' %}
                  box-shadow: 0px 0px 5px 5px #CBC3E3 !important;
                  {% else %}
                  box-shadow: 5px 10px 5px -3px rgba(0,0,0,0.75);
                  {% endif %}
                  {% if is_state('light.basement_lights','on') %}
                  background: rgba(255, 152, 0, 0.1) !important;
                  {% endif %}
                  --card-primary-font-size: 10px;
                  --card-primary-font-weight: bold;
                  width: 150px;
                  margin-left: 5px !important;
            tap_action:
              action: navigate
              navigation_path: basement
            fill_container: true
            layout: horizontal
            multiline_secondary: false
            primary: Laundry
            secondary: null
            icon: mdi:tumble-dryer
            icon_color: teal
            card_mod:
              style: |
                ha-card {
                  {% if states('light.laundry_vanity_light_light') == 'on' %}
                  {% else %}
                  {% endif %}
                  {% if is_state('light.laundry_vanity_light_light','on') %}
                  {% endif %}
                  width: 150px;
            tap_action:
              action: navigate
              navigation_path: laundry
            layout: horizontal
        cards:
            primary: Utility Room
            secondary: null
            icon: mdi:water-boiler
            icon_color: teal
            card_mod:
              style: |
                ha-card {
                  {% if states('light.utility_room_light_light_2') == 'on' %}
                  {% else %}
                  {% endif %}
                  {% if is_state('light.utility_room_light_light_2','on') %}
                  {% endif %}
                  width: 150px;
            tap_action:
              action: navigate
              navigation_path: utility-room
            layout: horizontal
            primary: HA Info
            secondary: null
            icon: ios:cpu
            icon_color: teal
            card_mod:
              style: |
                ha-card {
                  width: 150px;
            tap_action:
              action: navigate
              navigation_path: ha-information
            layout: horizontal
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
card_mod:
  style: |
    ha-card {
      --vertical-stack-card-gap: 10px;
      background: url('/local/MyPictures/rock wall.jpg');
      background-size: 100%;
to this:
type: custom:vertical-stacked-navigation-card
nav_name: 🏡
nav_items:
  - name: First Floor
    icon: mdi:home-floor-1
    sub_nav_items:
      - name: Living Room
        icon: mdi:sofa
        destination: living-room-1
        active: false
      - name: Kitchen
        icon: mdi:pot-steam
        destination: kitchen
        active: false
      - name: Hallway
        icon: mdi:hat-fedora
        destination: hallway
      - name: My Bathroom
        icon: mdi:shower-head
        destination: my-bathroom
      - name: Garage
        icon: mdi:go-kart
        destination: garage
      - name: Kids Room
        icon: mdi:teddy-bear
        destination: kids-room
      - name: Outside
        icon: phu:outside-temp
        destination: outside
    active: false
    unfolded: false
  - name: Second Floor
    icon: mdi:home-floor-2
    destination: ''
    sub_nav_items:
      - name: Upstairs
        icon: mdi:escalator-up
        destination: upstairs
      - name: Master Bedroom
        icon: mdi:bed-king
        destination: master-bedroom
      - name: Sonia's Room
        icon: mdi:zodiac-leo
        destination: sonia-room
      - name: Artem's Room
        icon: mdi:zodiac-taurus
        destination: lovelace
  - name: Basement
    destination: ''
    sub_nav_items:
      - name: Basement
        destination: basement
      - name: Laundry
        destination: laundry
      - name: Utility Room
        destination: utility-room
      - name: HA Info
        icon: mdi:cpu-64-bit
        destination: ha-information
custom_styles:
  colors:
    text:
      main: White
      sub: White
    hover:
      main: Teal
      sub: Teal
    active:
      sub: orange
    background:
      main: Transparent
      sub: Transparent
  font_size:
    text:
      main: 25px
      sub: 20px
card_mod:
  style: |
    ha-card {
I want each floor to light up a border when lights in any room on this floor is ON and also see which room it is
Thank you
I’m wondering if someone can provide some advice for combining card-mod styles that are set up using the “|” after “style:” and ones that don’t. For example, I can get both of these card-mod styles to work on their own, but I haven’t found a way to integrate them together into the one set of instructions.
card_mod:
  style: |
    ha-card {
      background: var(--tile-color) !important;
      border-radius: 5px !important;
    ha-tile-icon {
      --tile-color: white;
card_mod:
  style:
    hui-card-features$:
      hui-light-brightness-card-feature$:
        ha-control-slider$: |
          .slider {
            --control-slider-color: white !important;
            --control-slider-background: white !important;
Both of the above work, but how do I combine them so I can use both at once?
Actually, I was able to work it out…
card_mod:
  style:
    hui-card-features$:
          .slider {
      ha-card {
        --primary-font-size: 20px;
        --primary-font-weight: normal;
      ha-tile-icon {
Yes sir, that’s the way!
