my question was not for you
even the post of the ask, it already was doing nothing, and thats not a good thing with mod-card
I know it wasnāt for me. I was agreeing it was an issue.
Can I hijack tthis?
Iām using the minimalism theme and per card css works,
The theme already uses it, my (global) css wonāt come up
minimalist-desktop:
# Journal
state-icon-color: "rgb(var(--color-theme))"
border-radius: "20px"
# THEME-CSS
card-mod-theme: "minimalist-desktop"
card-mod-view-yaml: |
"*:first-child$": |
#columns .column > * {
padding-left: 5px;
padding-right: 5px;
padding-bottom: 5px;
# MY-CSS
card-mod-card: |
ha-card .heating #item1 .ellisis {display: none;}
ha-card .type-custom-simple-thermostat header .heating .header__title { color: red !important; }
For testing purposes alll titles should be red x)
I cant believe I overlooked this all of those yearsā¦ because of another thread, I just realized we can set an icon on core entities cardā¦
since entities isnt my main card for the most used views in my config, I suppose I didnt give it as much attention, and simply jotted my card-header class to them all.
However that icon detail is kind of nice. Ofc, when using that, one immediately wants to be able to make it dynamic
which is just as simple:
type: entities
title: Tijd
icon: [] # could probably also set a default here, but the template below has that already, so just the placeholder is required
card_mod:
class: class-header-margin # my overall entities header mod
style: |
.card-header {
{% set up = states('sun.sun') == 'above_horizon' %}
--card-mod-icon-color: {{'gold' if up else 'var(--card-background-color)' }};
--card-mod-icon: mdi:weather-sunset{{'-down' if not up}};
entities:
or
--card-mod-icon: mdi:weather-sunset{{'-up' if up else 'down'}};
--card-mod-icon: mdi:weather{{'-sunny' if up else '-night'}};
nice touch (although thereās a bit too much space around the icon for my taste. Maybe set the padding/margin there, need to experiment a bit more)
given this is the default style:
a quick fix there could be:
.card-header .icon {
padding: 0;
or just a bit more:
padding-left: 0px;
padding-right: 4px;
which to my eyes has a better balance.
so, let me try and add that to a card-mod classā¦
ha-card.class-header-icon .card-header .icon {
padding-left: 0px;
padding-right: 4px;
in card-mod-theme and now add that to the other class:
type: entities
title: Tijd
icon: []
card_mod:
class:
- class-header-margin
- class-header-icon
style: |
.card-header {
works beautifully!
Never knew we could list classes like that either, so TIL, twice
Do I implement it right or could you show me where Iām failing?
# THEME_MODS
"*:first-child$": |
padding-left: 5px;
padding-right: 5px;
# MY_CSS
card-mod-card: |
Crossposted on github as I donāt know if this has to do with the vertical stack Iām using
So I am searching for hours now to find the correct css command to edit this slider.
Right now the slider looks like this:
And I want it to have thin lines like this:
But I canāt find out the right css names to edit the pixel width for the stroke. Can someone help me?
It is the stroke-width you have to adjust in the different path elements/css classes
Thought I would share here too - since the main part of the video is card-mod!
If your not already using fonts on your dashboard, its an easy way to really make an impact! Check out my tutorial - if you find it useful and would like to see more make sure to like, comment and subscribe to help the channel grow!
Hi everyone,
Been reading a ton of docs and slowly learning my way around, is there a way with card-mod that i can somehow style a container like a sidebar which is made from a vertical stack? I want to have an exact height of 100vh applied to the container (vertical stack) and then have my entities inside it
Iād like to apply this globally across my entire dashboard using my theme, rather than having to manually add it to each card.
Could someone assist me in finding a solution?
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background: none !important;
have a switch with 3 states (On, Off, āAuto (off)ā) but i cant get it working
- entity: sensor.relay_no_1_filterpumpe_state
card_mod:
style: |
.header .icon {
{% if is_state(config.entity,'Off') %}
color: var(--paper-item-icon-active-color);
{% else %}
color: red;
{% endif %}
you havenāt defined a card in your code.
but this does what you describe.
type: entity
entity: automation.empty_dehumidifier
card_mod:
style: |
.header .icon {
{% if is_state(config.entity,'on') %}
color: green;
{% elif is_state(config.entity,'off') %}
color: red;
{% else %}
color: white;
{% endif %}
hope this helps
Thank you Frosty. To be honest i dont see the difference, where have i not defined the ācardā
And it does not work, still showing in the standard color
Add state_color: false
type: entity
entity: light.pc_lights
state_color: false
card_mod:
style: |
.header .icon {
color: green;
color: red;
{% else %}
color: white;
{% endif %}
Really strange, it does not show any color, even change the else
to red to enforce any different color in case switch states would be misspelled
type: entities
entities:
- entity: sensor.ph_sensor
secondary_info: none
- entity: sensor.redox_sensor
- entity: sensor.temperature_no_2_pool
state_color: false
card_mod:
style: |
.header .icon {
color: green;
color: red;
{% else %}
color: red;
{% endif %}
- entity: sensor.relay_no_2_kugelhahn_state
- entity: sensor.relay_no_5_poolbeleuchtung_state
- entity: sensor.temperature_no_3_aussentemp
For the entities card you need different it needs to be coded a little different. Give me a fewā¦
Whatās the third state shown in developer tools?
options: auto, on, off
attribution: Data provided by your Pool Digital ProCon.IP (https://www.pooldigital.de)
icon: mdi:toggle-switch-variant
friendly_name: Relay No. 1: FilterPumpe
Letās test thisā¦
type: entities
entities:
state_color: false
card_mod:
style:
hui-generic-entity-row:
state-badge {
color: {{ iif(states(config.entity) == 'on' ,'green', iif(states(config.entity) =='off','yellow',iif(states(config.entity) == 'auto','red')))}};
We may need to adjust because itās a sensor entity.
