šŸ”¹ Card-mod - Add css styles to any lovelace card
I am trying to make the icon spin on the simple-thermostat card.
So far I got it to change color depending on the state of an input_boolean, but no rotation, what am I missing?
type: custom:simple-thermostat
entity: climate.workroom
header:
  icon: mdi:fan
step_size: 1
control:
  hvac:
    'off':
      icon: mdi:fan
    fan_only:
    heat:
      icon: mdi:fire
    cool:
    heat_cool: false
    dry: false
layout:
  step: row
  mode:
    headings: false
    icons: true
    names: true
hide:
  state: false
decimals: 0
card_mod:
  style: |
    :host {
      {% if is_state('input_boolean.x1c_details', 'on') %}
        --card-mod-icon-color: yellow;
        animation: rotation 2s linear infinite;
      {% else %}
        --card-mod-icon-color: #03a9f4;
      {% endif %}
    @keyframes rotation {
      0% {
        transform: rotate(0deg);
      100% {
        transform: rotate(360deg);
As you donā€™t want to rotate :host (even not possible), you have to assign the rotation to the object you want to rotate.
seems to be working! thanks so much once again :slight_smile:
Got it working! :slight_smile:
card_mod:
  style: |
    {% if is_state('switch.inline_fan_fan', 'on') %}
    .header__icon {
    {% endif %}
      0% {
      100% {
Hey everyone. Looking to get some help on a the last few items for my setup. Iā€™ve typically been able to get things working through trial and error, but I canā€™t seem to figure these out. Any help would be appreciated.
The first are these circular buttons in the Frigate card. Iā€™m trying to change the background circle color, as well as the icon color:
Screenshot 2024-05-08 100049
For the background circle color, the card-mod helper output is
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>hui-masonry-view$#columns>div>hui-vertical-stack-card$#root>frigate-card$#ha-card>frigate-card-menu$div.matching>ha-icon-button:nth-child(1)"
with the property to change being background-color within ha-icon-button.button.
The icon color for it is within the same card-mod helper output, and the property is color, but this is not within ha-icon-button.button.
The last thing is the selected icon color within the controls in a tile card:
Screenshot 2024-05-08 103852
The card-mod helper output is:
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>hui-masonry-view$#columns>div>hui-vertical-stack-card$#root>hui-tile-card$ha-card>hui-card-features$hui-fan-speed-card-feature$div>ha-control-select$#option-off"
with the property being color within .option.selected
For all of these, Iā€™m able to get the property I want changed when inspecting, but canā€™t figure out how to format it properly for card-mod.
I am monitoring a fire-alarm panel, which used to work.
Log says: Template error: int got invalid input ā€˜Noneā€™ when rendering template ā€˜{{ state_attr(ā€œsensor.sensor_thingspeakā€, ā€œfield1ā€) | int}}ā€™ but no default was specified.
field1: "0"
Nothing has been changed lately, canā€™t see any errors :frowning:
afbeelding
type: picture-elements
card_mod:
  style: |
    @keyframes my-blink {
      from {opacity: 0;}
      to {opacity: 100;}
      from {opacity: 100;}
      to {opacity: 0;}
    ha-card {
      --my-fire-color: {% if state_attr("sensor.sensor_thingspeak", "field1") | int == 1 %} red {% else %} darkgrey {% endif %};
      --my-trouble-color: {% if state_attr("sensor.sensor_thingspeak", "field2")| int == 1 %} orange {% else %} darkgrey {% endif %};
      --my-rmh-color: {% if states('sensor.rookmelder_hal_smoke_amount')|int >= 5 %} red {% else %} darkgrey {% endif %};
      --my-rmo-color: {% if states('sensor.rookmelder_overloop_smoke_amount')|int >= 5 %} red {% else %} darkgrey {% endif %};
      --my-rmz-color: {% if states('sensor.rookmelder_zolder_smoke_amount')|int >= 5 %} red {% else %} darkgrey {% endif %};
      --my-co-color: {% if states('binary_sensor.co_alarm')=='on' %} red {% else %} darkgrey {% endif %};
      --my-test-color: {% if state_attr("sensor.sensor_thingspeak", "field5") |int==1 %} green {% else %} red {% endif %};
elements:
  - type: icon
    icon: mdi:circle
    style:
      top: 77%
      left: 26.2%
      color: lightgreen
      animation: my-blink 2s linear infinite
      transform: scale(.6,.6)
  - type: icon
    icon: mdi:circle
    style:
      top: 17.5%
      left: 26.2%
      color: var(--my-fire-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 17.5%
      left: 29.2%
  - type: icon
    icon: mdi:circle
    style:
      top: 29%
      left: 26.2%
      color: var(--my-trouble-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 17.5%
      left: 7.7%
      color: var(--my-rmh-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 29%
      left: 7.7%
      color: var(--my-rmo-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 41.5%
      left: 7.7%
      color: var(--my-rmz-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 53%
      left: 7.7%
      color: var(--my-co-color)
  - type: icon
    icon: mdi:circle
    style:
      top: 17.5%
      left: 72%
      color: var(--my-test-color)
image: /local/images/bmc.png?v=7.0
Try using a format similar to thisā€¦
--my-fire-color: {{ 'red' if state_attr('sensor.sensor_thingspeak', 'field1') | int == 1 else 'darkgrey' }};
I assume the code was AI generate?
Nope, no AI here, just googlingā€¦
Iā€™ve changed all the color lines, at least the blinking is back but the icons remain black
is there any way to change tile card featuresā€™ buttonā€™s icons?
I tried to dig using inspector but nothing seems to work.
Depending on the card, yes. This a good thread to review.
I have the hover over icons working but it doesnā€™t seem to work when hovering over labels. I tried a few things but couldnā€™t quite get it. Is there a way to do this with the label: attribute? Thanks.
Code
type: custom:mod-card
card_mod:
  style:
    tabbed-card $: |
      mwc-tab:hover {
        --mdc-theme-primary: red;
        --mdc-tab-color-default: red;
card:
  type: custom:tabbed-card
  attributes:
    icon: mdi:circle
  tabs:
    - card:
        type: entities
        entities:
          - sun.sun
      attributes:
        icon: mdi:numeric-1-circle
    - card:
        type: entities
        entities:
          - sun.sun
      attributes:
        icon: mdi:numeric-2-circle
    - card:
        type: entities
        entities:
          - sun.sun
      attributes:
        icon: mdi:numeric-3-circle
    - card:
        type: entities
        entities:
          - sun.sun
      attributes:
        icon: mdi:numeric-4-circle
    - card:
        type: entities
        entities:
          - sun.sun
      attributes:
        icon: mdi:numeric-5-circle
Hi all !
Iā€™m trying to blinking an icon, where the state of an entity, on the picture element with card_mod, but doesnā€™t work :
- type: picture-elements
  image: /local/rlKlbf6LYE.png
  elements:
    - type: state-icon
      entity: cover.ikea_of_sweden_praktlysing_cellular_blind_volets
      style:
        left: 13%
        top: 47%
      tap_action:
        action: toggle
      card_mod:
        style: |
          :host {
             {% if ( states('sensor.ikea_of_sweden_praktlysing_cellular_blind_batterie') | int ) < 20 %}
               animation: blink 2s linear infinite;
               color: red;
             {% endif %}
Iā€™ve made several searches but I canā€™t get the icon to flash red.
Update, i found myself :slight_smile: :
card_mod:
  style: |
    :host {
        --card-mod-icon-color: red;
      {% endif %}
    @keyframes blink {
      50% {opacity: 0;}
Hi, I have a custom button card with a entity picture image ( the currently playing cover). It is possible to fade in the image every time that change? Now load without any transition. Is possible with card-mod?
Thanks in advance
hi,
can anybody tell me how to change the color of the icon inside a custom secondaryinfo-entity-row depending on a sensors state?
i have tried nearly everythingā€¦
the bird should be yellow if motion ia detected and the slider turns the guest mode on or off
thx in advance
Can you show your not working code/your tries?
state_color: true
type: custom:secondaryinfo-entity-row
secondary_info: '[[ binary_sensor.bewegungsmelder_bad.state ]]'
card_mod:
    style: |
      ha-card {
        {% if states('sensor.bewegungsmelser_bad') = 'on' %}
          --card-mod-icon-color: var(--amber-color);
        {% else %}
          --card-mod-icon-color: grey;
        {% endif %}
this was the last code.
i also tried without card-mod at the beginning, because i read about a breaking change not to use this anymore.
i used --paper-item-icon-color instead
inserted the color without template
and tried to use a kind of this
    card_mod:
      style:
        hui-generic-entity-row $: |
          .info.pointer .secondary ha-relative-time {
            {% if is_state('sensor.bewegungsmelder_bad', 'on' %}
              color: red;
            {% endif %}
works alright here in any combination with or without icon using this:
card:
  card_mod:
    style:
      tabbed-card:
            mwc-tab:hover {
              --mdc-theme-primary: var(--power-color);
              --mdc-tab-color-default: var(--power-color);
            mwc-tab-bar {
              background: {{'var(--lovelace-background)'
                            if states('input_select.theme')|regex_search('(ight|Dark|Matrix)')
                            else 'var(--primary-color)'}};
          mwc-tab:
              mwc-tab-indicator $: |
               .mdc-tab-indicator__content--underline {
                  border-color: var(--active-color);
                .mdc-tab {
                  min-width: 80px;
                .material-icons {
                  display: contents !important;
                .mdc-tab--active {
                  --mdc-icon-size: {{states('input_number.active_icon_size')}}px;
                  /*background: var(--text-color-off) !important;*/
  card:
  #   attributes:
  #     isFadingIndicator: true
    styles:
      --mdc-tab-horizontal-padding: 4px;
      --mdc-theme-primary: var(--active-color)
  #     --mdc-theme-secondary: var(--text-color-off) # not functional
      --mdc-tab-color-default: var(--text-primary-color)
    tabs:
      '[[tabs]]'
Note I did some other tab mods, so I had to change the Dom path a bit, maybe its just what you need
I apologize @Mariusthvdb, I should have explained myself better. Currently when hovering over the active tab the icon, label text, and underline are all highlighted. However, when hovering over an inactive tab only the icon is highlighted. Since I donā€™t use icons on the tabs and only the label text is displayed, when I hover Iā€™d like the label text to highlight.
Recording 2024-05-13 170452(1)
Yes, that is what I tested and see happening with the mod I posted. Text only label gets highlighted when hovered
Is there a way to target the ha-sortable element inside of the drag-and-drop sections ?
Iā€™ve tried several ways to add this but I canā€™t find the right selectorsā€¦
What Iā€™m trying to reproduce:
Here is the exact thing Iā€™m trying to target (but any above element could do):
Iā€™ve tried to add this to that specific section:
  card-mod:
    style: |
      ha-sortable$: |
          .card {
              padding: 20px 17px;
              background-color: white;
              border-radius: 1em;
Without much luckā€¦ tried also a few other selectors like hui-grid-section but nothing seems to work :frowning:
Maybe this? But no luck either
    card_mod:
      style:
        hui-section$: |
          .container {
            padding: 20px 17px!important;
            background-color: white !important;
            border-radius: 1em !important;
