Got that to workā¦ Apparently spin
doesnāt work, but rotation
does ā¦
If you rename rotation to spin, spin will work
@keyframes rotation {
0% {transform: rotate(0deg);}
100% {transform: rotate(360deg);}
Guess I didnāt really/fully understood CSS, as this works for mushroom . Thought spin was a CSS definition
type: custom:mushroom-entity-card
entity: sensor.sensor
card_mod:
style: |
ha-state-icon {
animation: 2s spin infinite linear;
some cards have several animations built-in.
However, if you use card_mod, you need to specify the animations as this isnt implemented in the card itself at that point.
Hello guys ,
Need a little help.
How to change icon based on state of an entity.
I need to use picture glance card. Tried the below code but its not working.
Kindly help
camera_view: auto
type: picture-glance
image: https://demo.home-assistant.io/stub_config/kitchen.png
entities:
- entity: switch.tv
icon: >-
{% if is_state('switch.tv','off') %}
mdi:school
{% else %}
mdi:sack
{% endif %}
- entity: light.s_1
As a starting point:
1st post - link at the bottom - picture-glance
Thank you so much
Hi everyone,
Iād really love some help on a card Iām trying to build with card_mod.
At the moment I have the below table. Iām trying to accomplish that everything is in a singular card (as if it were an entity card). This means I have to get rid of the spaces between the rows and columns, and put everything a lot closer together. Iāve tried a lot of different options but I seem to be unable to manipulate the grid-layout properly.
type: custom:layout-card
layout_type: custom:grid-layout
layout:
margin: "-4px -5px -4px -5px"
grid-template-columns: 15% 85%
grid-template-rows: auto
grid-template-areas: |
"left right"
cards:
icon: mdi:toggle-switch{{'-off' if states(entity) == 'off'}}
entity: switch.sprinklercontroller_backyard_group_1_include_in_cycle
fill_container: true
icon_color: "{{'amber' if states(entity) == 'on' }}"
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
view_layout:
grid-area: left
- type: custom:timer-bar-card
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
- entity: switch.sprinklercontroller_backyard_group_1
remain_time:
entity: sensor.sprinklercontroller_remaining_time_current_valve
units: seconds
duration:
entity: number.sprinklercontroller_backyard_group_1_duration
units: minutes
view_layout:
grid-area: right
entity: switch.sprinklercontroller_backyard_group_2_include_in_cycle
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
- entity: switch.sprinklercontroller_backyard_group_2
remain_time:
units: seconds
duration:
entity: number.sprinklercontroller_backyard_group_2_duration
units: minutes
entity: switch.sprinklercontroller_backyard_group_3_include_in_cycle
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
- entity: switch.sprinklercontroller_backyard_group_3
remain_time:
units: seconds
duration:
entity: number.sprinklercontroller_backyard_group_3_duration
units: minutes
entity: switch.sprinklercontroller_frontyard_include_in_cycle
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
- entity: switch.sprinklercontroller_frontyard
remain_time:
units: seconds
duration:
entity: number.sprinklercontroller_frontyard_duration
units: minutes
layout_options:
grid_columns: full
I might even start out with stack-in-card. This removes all the spaces in between and makes it look like a single card. check that out - maybe itās already what you are looking for. If not, then you have a better starting point to make granular adjustments.
Thanks!
Are you talking about the vertical-stack-in-card or the stack-in card. The latter doesnāt seem to have been updated in the last 4 years?
interesting ^^
stack-in-card actually mentions it is the replacement for vertical-stack-in-card. But you are absolutely right.
I have use both, both work fine and both will likely be fine in your case.
Iāve tried using the vertical-stack-in-card now.
Unfortunately documentation on this visual is really bad and it doesnāt explain how I can use the āstylesā parameter to resize the columns. If I can make it 10% 90% then I think Iām golden
Thatās where you need to get back to card_mod and handle it as you would any vertical stack
Iāve used a normal horizontal-stack in my example, but you should be able to apply this to your card in the same way with slight adjustments. If you run into issues, just give me your current code an I can try to look into it.
card stacks donāt create their own ha-card (see card_mod documentation for more details on this), so you need to wrap it into a type: custom:mod-card
, which will create that ha-card for you.
In my case Iāve used the flex tag to change the width of the first flex item by changing its flex-basis
to 60%. There are also other ways to achieve this, but this works in my case.
style:
hui-horizontal-stack-card$: |
mushroom-title-card {
flex: 0 0 60% !important;
card:
type: horizontal-stack
cards:
- type: custom:mushroom-title-card
title: HP OfficeJet Pro 8720 All-in-One
- type: picture
image: local/HPOfficeJetPro8720.webp
tap_action:
I assume you would need to adjsut the following:
- change to custom:vertical-stack-in-card
- set horizontal direction on the stack
- change the style tag from hui-horizontal-stack-card$ to whatever it is in your case
- adjust the css selector to select the second element in your stack
- change from 60% to 90%
maybe you also need to set min-widths or similar in order to make it responsive on smaller screens.
Thanks so much for helping
Canāt seem to get it to work. I think the name of the vertical-stack-in-card might be incorrect on line 3, but Iāve tried all different combinations.
style:
type-custom-vertical-stack-in-card$: |
mushroom-template-card {
flex: 0 0 90% !important;
card:
type: custom:vertical-stack-in-card
horizontal: false
cards:
- type: custom:vertical-stack-in-card
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
this doesnāt look right - try to check the element in your browserās dev tools, thatās where you can see the the name you need to put in there. just select the flexbox like this:
and make a screenshot starting at ha-card
all the way down to your content, like this:
in my screenshot you can see the hui-horizontal-stack-card
, which is what I had to put into my styles.
Pssst, look what I made:
Now all I need to do is put the rows (much) closer together, so it looks like an entity card if you will
Current code:
horizontal: false
cards:
- type: custom:mod-card
style:
flex: 0 0 15% !important;
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
sidenote: I would highly recommend looking into the streamline-card. This would save you a lot of code and repetition in case you want to change something.
especially with these additional adjustmentsā¦
you can likely reduce spacing even further if needed. To do so just use your browserās dev tools again to find where you have remaining unwanted paddings/margins. If you run into issues with this let me know.
other than that:
remove padding from icons:
card_mod:
style: |
ha-card {
padding: 0 !important;
remove padding from entity:
card_mod:
style: |
.card-content {
padding: 0;
I think weāre getting close.
Only issues I have now:
- Too much space below the last entity
- The icons (1st column) are now no longer properly aligned with the 2nd column, I believe I have to make the switch icons smaller, but not sure how.
I will look into the streamline card once I get this the way I want, thanks for the tip
Current code:
horizontal: false
cards:
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
card_mod:
style: |
ha-card {
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
card_mod:
style: |
.card-content {
padding-top: 0;
padding-bottom: 0;
padding-left: 0;
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
card_mod:
style: |
ha-card {
height: 20px;
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
card_mod:
style: |
.card-content {
padding-top: 0;
padding-bottom: 0;
padding-left: 0;
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
card_mod:
style: |
ha-card {
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
card_mod:
style: |
.card-content {
padding-top: 0;
padding-bottom: 0;
padding-left: 0;
style:
card:
horizontal: true
cards:
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
card_mod:
style: |
ha-card {
state_color: true
mushroom: null
tap_action:
action: toggle
bar_height: 10px
entities:
remain_time:
units: seconds
duration:
units: minutes
card_mod:
style: |
.card-content {
padding-top: 0;
padding-bottom: 0;
padding-left: 0;
thatās very odd: this is what itās looking like over here:
where is that spacing coming from in your setup? I have copied your exact code and have only replaced the entities - I do not have any spacing at all and everything is properly aligned.
It seems to be caused by the timer-bar-card
