šŸ”¹ Card-mod - Add css styles to any lovelace card
Found the paddings were not very productive, so tried the margin-top :wink:
Iā€™ve set it to this now:
      - type: media-control
#         visibility:
#           - condition: state
#             entity: media_player.symfonisk
#             state_not: unavailable
        card_mod:
          style: |
            ha-card {
              height: {{'48px !important' if is_state(config.entity,'unavailable')}};
              font-size: 18px;
            .background.off {
              filter: unset !important;
            .player {
              margin-top: -4px;
which is gettin very close, if not exactly rightā€¦
that would be awesome , and yes, I did try to set it all on the ha-card element before. Unfortunately this is the result of that:
How do I wrap text in a dashboard card displaying the content of a text helper? For the life of me it refuses.
Manipulate only the content that is visible. Other elements are empty
type: media-control
entity: media_player.browse
card_mod:
  style: |
    ha-card .player {
      height: 48px;
      justify-content: center;
nice, niceā€¦ though the 3 dots are not centered ā€¦
like with this:
            .player {
              margin-top: -4px;
icon already has size 48px as header, but the .more-info class for the icon is indented 4px from the top. This will fit exactly including padding for the icon.
type: media-control
card_mod:
  style: |
    ha-card .player {
      height: 48px;
    .more-info {
      top: 0 !important;
Suggest you to name this card & post a code of your latest attempt.
is possible change color, based on multiple states of the same entity.
card_mod:
  style: |
    ha-card {
      background: {{ '#443EF4' if is_state('alarm_control_panel.alarmo', 'armed_home') else '#367202' }};
I would like to add (alarm_away) and (triggered) as well, with their respective colors
card_mod:
  style: |
    ha-card {
      {% if ... -%}
        background: ...;
      {%- elif ... -%}
        background: ...;
      {%- elif ... -%}
        background: ...;
      {%- else -%}
        background: ...;
      {%- endif %}
or for some cases - smth like:
      {% set mapper = {
                       'value_1': 'red',
                       'value_2': 'green',
                       'value_3': 'blue'
      {%- set VALUE = states(...) -%}
      {%- set COLOR = mapper[VALUE] if VALUE in mapper else 'yellow' -%}
      background: {{COLOR}};
you can get smart and use the theme variableā€¦
            {% set state = states(config.card.entity) %}
            .badge {
              border: 2px solid var(--state-alarm_control_panel-{{state}}-color) !important;
ofc this is but an example form another config, use the variable template inside your own card mod
that is, if you want to use those colorsā€¦ if you want your own set of colors, do as Ildar says :wink:
or adjust the theme colors in your theme and have them coherently system wide
Yes, I am keep forgetting about standard colors for some domains/classesā€¦
playing around with those variables:
    state-alarm_control_panel-armed_away-color: var(--red-color)
    state-alarm_control_panel-armed_custom_bypass-color: var(--warning-color)
    state-alarm_control_panel-armed_home-color: var(--warning-color)
    state-alarm_control_panel-armed_night-color: var(--red-color)
    state-alarm_control_panel-armed_vacation-color: var(--warning-color)
    state-alarm_control_panel-arming-color: var(--warning-color)
    state-alarm_control_panel-disarmed-color: var(--success-color)
    state-alarm_control_panel-disarming-color: var(--info-color)
    state-alarm_control_panel-pending-color: var(--orange-color)
    state-alarm_control_panel-triggered-color: var(--alert-color)
note I did shuffle some of the warning and alerting colors.
success, info, warning and alert are also built in colors, unless your theme modifies them. See eg Markdown card - Home Assistant for those
Iā€™m definitely getting the synthesis wrong. I tried like this
card_mod:
  style: |
    ha-card {
      {% if is_state('alarm_control_panel.alarmo', 'armed_home') -%}
        background: '#443EF4';
      {%- elif is_state('alarm_control_panel.alarmo', 'armed_away') -%}
        background: '#FE9900';
      {%- elif is_state('alarm_control_panel.alarmo', 'triggered') -%}
        background: '#D20103';
      {%- else -%}
        background: '#367202';
      {%- endif %}
thanks for the kindness, but i donā€™t understand where to use that code. Instead of the background: ?
well, not instead, but yes, in that same template mod:
card_mod:
  style: |
    ha-card {
      {% set state = states(config.entity) %}
      background: var(--state-alarm_control_panel-{{state}}-color);
if the entity of your card is the alarm_panel
if it isnt, simple replace the state setter and add the alarm_control_panel.alarmo in there
card_mod:
  style: |
    ha-card {
      {% set state = states('alarm_control_panel.alarmo') %}
try that template in your dev tools template and check if its returning a correct output:
As it was suggested - use Dev tools ā†’ Template for clearing out templating errors. (although my eyes do not see any errors here)
Also, try
background: #123456;
i.e. w/o quotes.
yes, is work fine.
thanks
in the dev panel, only the code work fine.
card_mod:
  style: |
    ha-card {
      {%- else -%}
      {%- endif %}
in the card but it stops working. I attach the whole code
type: custom:expander-card
gap: ""
padding: ""
clear: false
clear-children: false
title: "     ------ ! ! ----- Allarme ------ ! ! ----- "
overlay-margin: 2em
child-padding: ""
button-background: transparent
cards:
  - type: custom:alarmo-card
    entity: alarm_control_panel.alarmo
  - type: alarm-panel
    entity: alarm_control_panel.ezviz_alarm
card_mod:
  style: |
    ha-card {
      {%- else -%}
      {%- endif %}
Iā€™d try removing thisšŸ˜…
tried with and without, for correctness I attached all the code
Erm, a card-mod code from Card_A is not obliged to work with Card_B.
I never tested ā€œcustom:expander-cardā€, can say nothing about it.
