🔹 Card-mod - Add css styles to any lovelace card
You’re already inside the shadow-root. Just do
style: |
  span.title {
    put-your-styling: here !important;
So I’m a little stuck. I’m using the gauge card for some entities with severities enabled (red-yellow-green), but would also like to color the gauge red when the value exceeds the maximum, so the style becomes red-yellow-green-red.
The style code looks like this:
<ha-gauge style="--gauge-color:var(--label-badge-green);">
  <style> (inside #shadowroot)
    :host {
      position: relative;
    .dial {
      fill: none;
      stroke: var(--primary-background-color);
      stroke-width: 15;
    .value {
      fill: none;
      stroke-width: 15;
      stroke: var(--gauge-color);
      transform-origin: 50% 100%;
      transition: all 1s ease 0s;
    .gauge {
      display: block;
    .text {
      position: absolute;
      max-height: 40%;
      max-width: 55%;
      left: 50%;
      bottom: -6%;
      transform: translate(-50%, 0%);
    .value-text {
      font-size: 50px;
      fill: var(--primary-text-color);
      text-anchor: middle;
  </style>
</ha-gauge>
I’ve used the following card code:
style:
  ha-gauge:
      .value {
        stroke: {% if states(config.entity)|int > 2000 %} var(--label-badge-red) {% endif %};
This works fine on Firefox. <ha-gauge style="--gauge-color:var(--label-badge-green);"> doesn’t get changed, but the bar turns red due to the stroke fill. However, on Chrome and mobile devices, this does not work, so I assume I need to get <ha-gauge style="--gauge-color:var(--label-badge-green);"> styled anyway. I’ve tried various options to no avail, so I’m reaching out for help.
How would I accomplish this feat cross-browser?
Has anyone figured out how to mod the new calendar card (which is part of 115)? I want the date text to be smaller and color the view buttons. I can’t get it to work unfortunately.
The span.title part made the trick work. In my old config I used .title only
What’s the idea / thought of the .span part?
style: |
span.title {
Probably that if you’re more specific, then you can override styles more. I don’t remember exactly what I was thinking when I wrote this post…
Thanks,
I want to set the background-color conditionally.
But this does not work? Do you have any idea?
      style:
          ha-card > div.box {
            background-color: {% if is_state('camera.entrance', 'recording') %} rgba(255, 0, 0, 0.6) {% else %} rgba(0, 0, 0, 0.6) {% endif %}
            justify-content: center;
          ha-card > div.box div ha-icon.state-on {
            fill: var(--paper-item-icon-active-color);
I have the following style that makes the alarm panel badge background colour change depending on the state of the alarm:
style:
  ha-label-badge.armed_away:
      .label-badge {
      background: rgba(255,64,64,0.1) !important;
  ha-label-badge.disarmed:
      .label-badge {
      background: rgba(64,255,64,0.1) !important;
It works but requires a a page refresh to show up. Any idea why?
Armed (correct):
Screenshot_2020-09-24 Mobile View - Home Assistant
After disarming (incorrect):
Screenshot_2020-09-24 Mobile View - Home Assistant(1)
Refresh (correct):
Screenshot_2020-09-24 Mobile View - Home Assistant(2)
After arming (incorrect):
Screenshot_2020-09-24 Mobile View - Home Assistant(3)
Refresh (correct):
Screenshot_2020-09-24 Mobile View - Home Assistant(4)
I still don’t have any idea / solution on how to fix this. :slightly_frowning_face:
Me too. I think debug_cardmod is broken.
Okey, I finally made it. I’m using Dwains theme.
Not sure what he is using, but I need to do some raw stuff in order to use template syntax…
    - type: picture-glance
      title: Entrance
      camera_image: camera.entrance
      camera_view: live
      #debug_cardmod: true
      style:
          ha-card > div.box {
            {% raw %}
              background-color: rgba(255, 0, 0, 0.6);
            {% endif %}
            {% endraw %}
          ha-card > div.box > div.row:nth-child(3) {
            {% raw %}
            {% if is_state('switch.camera_entrance_record', 'on') %}
              animation: blink 2s linear infinite;
            {% endif %}
            {% endraw %}
          @keyframes blink {
            50% {opacity: 0;}
And the result:
Transparent red border with blinking record button, when I’m recording any footage. Record and stopp can be executed from the card itself.
Hi everybody,
I try to apply CSS to image in picture-entity, but i don’t find how to call img in css :confused:
Exemple :
          - type: picture-entity
            entity: sensor.59_weather_alert
            attribute: Vent violent
            show_name: false
            show_state: false
            aspect_ratio: 50x50
            image: /local/meteo/vent.png
            style: |
              img #image {
              {% if state_attr('sensor.59_weather_alert', 'Vent violent') == "Vert" %}filter:  brightness(30%) grayscale(100%);
              {% elif state_attr('sensor.59_weather_alert', 'Vent violent') == "Jaune" %}filter: brightness(50%);
              {% elif state_attr('sensor.59_weather_alert', 'Vent violent') == "Orange" %}filter: brightness(50%);
              {% elif state_attr('sensor.59_weather_alert', 'Vent violent') == "Rouge" %}filter: brightness(100%);
              {% else %}filter:  brightness(0%) grayscale(0%);{% endif %}}
i have try with :
  • img
  • #image
Any idea ?
They’re buried underneath shadow-roots.
What is declared in “shadow-roots” cannot be overloaded?
Yes they can. Thomas explained how here: 🔹 Card-mod - Add css styles to any lovelace card (read his notes in red on the picture).
Thx @tom_l ! :slight_smile:
If I understand correctly you have to place the $: | instead of shadowroots, except I still can’t reach the image: '(
            style: |
              hui-image:
                    #image {
              {% if state_attr('sensor.59_weather_alert', 'Canicule') == "Vert" %}filter:  brightness(30%) grayscale(100%);
              {% elif state_attr('sensor.59_weather_alert', 'Canicule') == "Jaune" %}filter: brightness(50%);
              {% elif state_attr('sensor.59_weather_alert', 'Canicule') == "Orange" %}filter: brightness(50%);
              {% elif state_attr('sensor.59_weather_alert', 'Canicule') == "Rouge" %}filter: brightness(100%);
An idea ?
Couple of fixes:
            style: |
              hui-image:
                    #image {
My “}” was at the end of my {% else %}.
I have try with your code and same result: /
oops…
style: |
style:
Yeah it’s work !
Very thx :wink:
