exus85
(Exus85)
September 26, 2020, 3:52pm
795
hi, I’m trying to use card-mod to change the height of a weather-card-chart
I should edit the chartTarget height
document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-panel-view > weather-card-chart").shadowRoot.querySelector("ha-card > div.card > ha-chart-base").shadowRoot.querySelector("#chartTarget")
can someone please help me? I tried many style: configurations without success
edit
nvm, I found the solution:
style:
ha-chart-base:
#chartTarget {
height: 380px !important;
finipini
(Finipini)
September 27, 2020, 12:58am
796
I don,t know if this the right place to ask, but i look all arround and didn,t see what i want:
Who can i make a entities card with an image in the background almost transparent? If i try to put opacity: 0.3
it afects all the elements in the card, and i just want to make that in the image.
KTibow
(Kendell R)
September 27, 2020, 1:11am
797
finipini
(Finipini)
September 27, 2020, 1:15am
798
Oh, that,s the only way? The image has to be already with that filter ?
Ok, thank very much !
KTibow
(Kendell R)
September 27, 2020, 1:16am
799
Well you can do it with :before
, but it’s easier to just change the opacity of the image.
finipini
(Finipini)
September 27, 2020, 1:22am
800
Ok. So if i have tis code:
type: entities
style: |
ha-card {
color: red;
background: url('/local/s80.jpg');
entities:
- light.luz_cozinha
- light.sala_tv
- light.sala_sofa
Where should i use the :before
KTibow
(Kendell R)
September 27, 2020, 1:24am
801
Something like this:
ha-card:before {
content: " ";
opacity: 0.2;
position: absolute;
left: 0px;
top: 0px;
width: 100%;
height: 100%;
z-index: -1;
finipini
(Finipini)
September 27, 2020, 1:29am
802
That,s exactly what i was struglling to find. That is not easy to find, i found some generic anwsers about that from css in generic use, but i didn,t know how to translate that to Home assistant.
Thank you very much for your help and time.
dowermyr
(Dowermyr)
September 27, 2020, 9:21am
803
Hi!
I want to change color and word attribute based on state in a glance card.
If sensor.something = true, then color red and the word yes instead of true.
Can i make that happen?
dowermyr
(Dowermyr)
September 27, 2020, 12:28pm
804
Can’t make this work:
entity: sensor.sonnen_batterycharging
icon: 'mdi:battery-charging'
style: |
:host {
--paper-item-icon-color:
{% if states(config.entity)| 'true' %}
green
{% else %}
null
{% endif %}
KTibow
(Kendell R)
September 27, 2020, 2:09pm
805
It should be a binary_sensor in that case.
Maybe this will work (It won’t change the text or color when off):
style: |
:host {
--paper-item-icon-color: {% if is_state(config.entity, 'on') %}
green;
{% endif %}
dowermyr
(Dowermyr)
September 27, 2020, 3:54pm
807
The Icon is just white now, instead of blue. In both states
KTibow
(Kendell R)
September 27, 2020, 4:13pm
808
Well is it a binary_sensor? It should be. If it isn’t, create a template binary_sensor:
binary_sensor:
sensors:
sonnen_battery_charging:
friendly_name: Sonnen battery charging
icon_template: mdi:battery-charging
value_template: |
{{ is_state('sensor.sonnen_batterycharging', 'true') }}
And then update the entity in the card to the binary one
dowermyr
(Dowermyr)
September 27, 2020, 5:40pm
809
still no luck…the binary sensor is always off for some reason…
KTibow
(Kendell R)
September 27, 2020, 7:09pm
810
Even when sensor.sonnen_batterycharging
(check for typos) is true
dowermyr
(Dowermyr)
September 27, 2020, 7:10pm
811
Yes, even when it’s true, the binary sensor is off
KTibow
(Kendell R)
September 27, 2020, 7:11pm
812
What does the template show in the template tab of Developer Tools?
KTibow
(Kendell R)
September 27, 2020, 7:33pm
814
What about
{{ states('sensor.sonnen_batterycharging') }}
Mind sending a screenshot?
