šŸ”¹ Card-mod - Add css styles to any lovelace card
Just apply
style: |
  div.player > paper-progress {
  your-css
to the card for styling.
Thatā€™s simpler than the things I tried.
But doesnā€™t work when I try
style: |
  display: block !important;
Either the CSS doesnā€™t work or there is sth. with the shadowroot or so where it has to be applied.
Can you try out putting it not in a conditional card?
Just tried, same behaviour.
How do I get this to work with the history-graph? Iā€™m trying to hide the chart header, and this is what I have done:
type: history-graph
entities:
  - entity: climate.front_bedroom
hours_to_show: 24
refresh_interval: 0
style: |
  .chartHeader {
  display: none;
But that does not seem to work. I think its probably because the content is being loaded after so the style is not applying?
Try !important
Any ideas for how I could test out this?
How you could test out if it works?
using !important does not make any difference. I have tried a few things, if I start at ha-card I can hide the entire card, and if I go down trying different things along the route the last item I can hide is state-history-charts, beyond that is state-history-chart-line but that does not want to be hidden.
As far as testing goes I guess you could set up a simple thermostat and have a look at it with the history-graph. Here is some simple config for a thermostat:
climate
  - platform: generic_thermostat
    heater: switch.front_bedroom_heater
    target_sensor: sensor.front_bedroom_temperature
    min_cycle_duration:
      minutes: 1
    hot_tolerance: 0.1
    cold_tolerance: 0.1
    away_temp: 10
You need a switch and a sensor to make it work
Hey! Look whoā€™s back!
After an extended absence I now have well over 100 unread messages in this thread alone.
To preserve my sanity, I therefore hereby declare ā€œmessage bankruptcyā€ and will be starting over - ignoring anything above this one.
I honestly believe thatā€™s best for everyone, but do not let this stop any ongoing discussions.
Anyway. Iā€™d like to take this opportunity to let you know that Iā€™ve been working a bit on documentation in the form of a few ā€œwikiā€ posts that can be found here:
Specifically, those describe how to get started with themes, and some cool tricks that could be useful.
Iā€™m planing to also write one soon on how to do the ShadowDOM navigation.
Great. I added a compact header to my theme, code here:
If youā€™re trusting, consider letting anyone edit the wiki.
I actually didnā€™t think that was possible with github.
Itā€™s done!
Thanks for your help in this topic and others, by the way!
I hate to ask just an hour after my last post, but as itā€™s above your bankruptcy I guess itā€™s ok :slight_smile:
Iā€™m having problems styling graphs in the history-graph card. Is there a secret to that card I need to know?
Edit for context, Iā€™m trying to hide the header and its not working.
type: history-graph
entities:
hours_to_show: 24
refresh_interval: 0
style: |
  .chartHeader {
  display: none;
Try display: none !important instead.
I did, when you suggested it earlier, and replied that it made no difference.
NOT TRUE: Itā€™s buried under multiple shadow roots. Card-mod doesnā€™t support this :confused:
Actually, it does. Just update it and use the new syntax below.
By the way card mod debug is broken.
no-header:
  card-mod-theme:  theme name (yourname) ??
  card-mod-root: |
    app-toolbar {
      display: none;
place in /config/themes/yourname/yourname.yaml ???
Yeah. Rename the theme name to no-header. If you want to add it to an already-existing one, just set card-mod-theme to the name of your theme, and add the card-mod-root part.
Yes it does.
However, the history-graph card adds things to itself long after the card is initially loaded, and that is not supported.
But the following should work if you load a view, go to another view, and then back:
style:
  state-history-charts$state-history-chart-line$ha-chart-base$: |
    .chartHeader {
      display: none;
Also note the new syntax (since 2.0.1) for going into shadowRoots.
