🔹 Card-mod - Add css styles to any lovelace card
Got it working with this.
 sonnen_battery_charging:
        friendly_name: Laddar
        icon_template: 'mdi:battery-charging'
        value_template: '{{ states.sensor.json_sonnen.attributes["BatteryCharging"]  }}'
But the color on the icon is standard yellow thou…
If i do this:
- entity: binary_sensor.sonnen_battery_charging
    icon: 'mdi:battery-charging'
    style: |
      :host {
        --paper-item-icon-color: {% if is_state(config.entity, 'on') %} green {% else %} red {% endif %};
Then it will turn red when off but yellow when on
Copy the same thing, and paste it again, but under --paper-active-item-color.
Got it to work with this:
    style: |
      :host {
        --paper-item-icon-active-color: {% if is_state(config.entity, 'on') %} green {% else %} null {% endif %};
Thanks for helping me!
Im trying to change the color slider in the HA thermostat card.
The color of the slider is --heat-color but using
      - type: thermostat
        entity: climate.home
        style: |
          ha-card {
            --heat-color: #62e3c8;
is not working, any ideas please.
Try !important
Thank you , that solved it but I cant find anything documented on using ‘!important’ so can you tell me what does it do for future reference. Regards.
You should probably learn CSS
https://www.w3schools.com/css/default.asp
but for what it actually does:
ha-card {
color: red;
color: blue !important;
The second one will override the first one. You can use this to override default styles.
Thats great, I will look into that. thanks again.
is it possible to change the color of only the values in an entity card?
24.7ºC, 48.6%, etc.
Thanks.
Yes it is, do you mean entities instead of entity?
Yes, entities cards. I want to change the color of the values text, 24.7ºC, 48.6%…
And keep the color text as it is (T.Dorm, H.Dorm).
I’m also trying to reduce the space between the icon and the text…
Do you know how can I achieve both changes?
Thanks in advance.
style:
  hui-sensor-entity-row:
      text-content {
        --primary-text-color: blue;
should work.
thanks for the info, but I’m not able to place it properly. This is my current entities card definition:
- type: entities
    style: |
      #states > * {
           margin: -14px -12px !important;
           box-shadow:none;
      ha-card {
        background: rgba(28,28,28,1);
        box-shadow: none;
        color: rgba(225,224,224,1);
        margin-right: -6px
    entities:
      - entity: variable.temp_dorm
      - entity: variable.humidity_dorm
        style: |
          :host {
            --paper-item-icon-margin: 0px 0px !important:
              {% if states(config.entity)|int < 40 or states(config.entity)|int > 70 %}
                red
              {% else %}
                rgba(68,115,158,1)
              {% endif %}
      - entity: variable.temp_nanos
      - entity: variable.humidity_nanos
        style: |
          :host {
                red
              {% else %}
                rgba(68,115,158,1)
              {% endif %}
      - entity: variable.temp_terraza
      - entity: variable.humidity_terraza
      - entity: variable.aire_terraza
    show_header_toggle: false
    state_color: false
    gridrow: 2 / 2
    gridcol: 1 / 2
Where shoudl I add that style?
    style:
      other stuff here i already posted
        #states > * {
           box-shadow:none;
        ha-card {
          box-shadow: none;
          margin-right: -6px
This way?
  - type: entities
    style:
          text-content {
        #states > * {
             box-shadow:none;
        ha-card {
          box-shadow: none;
          margin-right: -6px
Because it’s not working, the color remains the same. I’ve tried also chaging to hue-text-entity-row, but no luck
Swap out
text-content {
with
.text-content {
Make sure to reindent, and change blue to whatever color you want.
Finally I made it work! With your last advice and hue-text-entity-row it worked.
    style:
      hui-text-entity-row:
          .text-content {
        #states > * {
             box-shadow:none;
        ha-card {
          box-shadow: none;
          margin-right: -6px
Thanks!
I don’t know if I can achieve this with card-mod:
The media-player-card has the progressbar which gets hidden at a certain breakpoint.
I like to prevent that and have the progressbar always shown.
I tried many different combinations of selectors with display: block !important; but nothing has worked so far.
The complete path is
document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > hui-masonry-view").shadowRoot.querySelector("#columns > div > hui-conditional-card:nth-child(7) > hui-media-control-card").shadowRoot.querySelector("ha-card > div.player > paper-progress")
Is this possible and if yes, can someone push me in the right direction?
